Syncro - to lift or not to lift, that is the question.
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10
mrshrimp
mrshrimp is offline
PostPosted: Sat Mar 01, 2014 4:59 am    Post subject: Reply with quote
Jabah -
Thanks for the info and discussion offer. I just went ahead and ordered the D/P springs with a fresh set of OMEs. I had emailed Steve awhile back and got this info from him, not all too different from the discription on his sight but might be useful for this thread. (I dont think he'll mind me posting this PM as nothing is confidential and is only good things) :
"Although there are slight variations from van to van due to different set ups, etc., the Syncro Westy D/P springs will give a ride height on a stock syncro of roughly 19" - give or take 1/4" or so. My syncro is just a hair above 19" and i have had the springs on since the beginning of October. (I had the O/Rs on my van before that). I have one shim on the left rear about 1/4" to level it due to the westy lean. I have to check it again to see if I may need a thin leveling ship up front on the left, too. But it has been very close left to right so far. They should be fully seated by now.If you want more height than that, it is easy to shim it higher. But I am finding after all the testing I have done that right around 19" is a pretty good height for dual-purpose. Pavement handling suffers a little as you go higher - unless you also go stiffer - but then you lose the benefit of supple springs and off-road performance. The suspension also tops out easier, too. The extra inch of travel is noticeable performance wise and height wise. You will definitely notice a difference. [/i]
Now all I have to do is figure out how to install them! Maybe I'll PM with some questions.
-Keith
SyncroScott
SyncroScott is offline
PostPosted: Thu Apr 03, 2014 9:31 am    Post subject: Reply with quote
Jon_slider wrote:
"It uses current issue GW +2 American Progressives. Here is a photo of my passenger rear spring. It uses 2.5" of shims to produce a ride heigh of 21"
And here is tdwestys SVX powered Silver Tintop Syncro, also at 21" ride heigh, uses GW Progressive +2's, HR issue, with 1.5" of shims, uses 29.5" BFG Mud Terrains
And here is ubercools 1.8T powered Silver Syncro Westy Camper, also GW's H&R +2 Progressives, only .5" of shim, to get to a 20" ride height. Uses 28" BFG AT KO
I believe tdwesty and I have similar vehicle weights of about 5200lbs but you can see that I need 1 more inch of shims to get to the same ride height. I think if ubercool was to raise to 21" like tdwesty and I, he might need 1" of shims, or possibly 1.5, not sure. I dont know his vehicle weight, but he travels heavily loaded.
guesstimated motor weights, confirm them
wbx 2.1 280 lbs
your subaru 2.5, 285 lbs
1.8t 320 lbs
SVX 435 lbs
AEL TDi 575 lbs"
Hey Jon, thanks for the pics, the ride height data, as well as the motor weights. Very helpful!
I have a couple questions for you and your buddy TDWesty in particular since you guys are riding @ 21". I am just finishing up my rebuild of a tin-top that started about 6 years ago (family+moving+procrastination+lack of a decent workspace = TOO LONG!). At that time the GW springs were about all there was for lifted options so at least for the moment that's what I have mine sitting on. I'm also @ 21"(though the interior & heavy accessories has yet to go back in it). I've got the beefed up axles and Porsche CVs so I'm hoping that mitigates those issues. BUT, I was wondering what you guys did to get your alignments in spec with the higher lift, as well as what other issues you may have come across that I need to look out for as I start to drive this thing?
Although I wasn't quite aiming for that much lift, I thought I'd ask for the input of some guys who, apparently from the shimming, did aim for 21". If the mechanics/physics of that height work out for you guys, then it might only be the ride comfort that would force me to get different springs if need be (and that can be put off for a while I hope).
Thanks for any insight,
-Scott
'90 Flat-top Syncro
‘17 Golf Wagon
'18 Golf
BCE56
BCE56 is offline
PostPosted: Fri Jan 02, 2015 1:21 pm    Post subject: tintop syncro suspension choice Reply with quote
Hello everybody-
My Syncro tintop has a Frankenmotor, spare in stock front location. Weighs right at 1000 lb at each corner, lightly loaded, 1/2 tank of gas. When traveling, I load my gear on the floor, not on the roof or the back, to maintain balance. Front suspension rebuilt with stock rubber bushings.
Alignment to specs based on ride height (see below.) Stock brakes, VC, rear locker.
Mostly used on pavement, w/ a little dirt roading when possible.
I did not want to depart too much from factory specs. Tire dia, gear ratios, and brake efficiency are factors, as well as axle/CVJ concerns.
And, of course cost is always a factor.
After considerable research, this is the combo I selected for my Syncro:
Stock springs (160000 miles) net ride height = 18.5" to 18 3/4" as loaded
OME shocks (availability) Boges might also work well.
215 75 BFG at/at, 35psi, on Rheins (Thanks, V.C.)
Results:
Shocks/springs appear to be a good match with these wheels.
Firm ride, not stiff on pavement, and not too harsh on dirt roads.
Nose dive @ braking minimized.
Good manners over potholes and speed bumps.
I notice a bit of "thunk" at full extension of front shocks.
Quiet on highway as tires are brand new.
No clearance issues with these tires and rims.
Little if any difference on acceleration and braking.
I am happy with this setup, and can recommend it to Syncro owners w/ similar needs. I hope this helps...
The next step up might be the Traimaster system, at considerably higher cost.
I now have 5 GW alloys w/ 16" Geolandars for sale.
davevickery
davevickery is offline
PostPosted: Mon May 02, 2016 6:46 pm    Post subject: Re: Syncro - to lift or not to lift, that is the question. Reply with quote
I read here and a couple other posts that you could put 2wd springs in the front of a syncro. There is some conflicting info though on ride, spring rates, and spring length. So here is my experience.
The spring rate of the 2wd spring was said to be the same as the syncro spring, very close to 450 lbs (80 kg/cm if that is the correct unit of measure). I measured the thickness and I don't think they are exactly the same. My original 2wd 87 Westy front springs (with 2 brown dots) have 16mm wire. The syncro spring is a little thicker at 16.6mm and agrees with prior posts. So the 2wd springs are probably a bit softer than the syncro. How much, I don't know, maybe just a bit (16.6/16.0 is only 3.75%). 430 maybe? Close enough to be worth trying.
But the 2wd spring is much longer, maybe 14.75. The stock syncro springs that came out are 12.5" or maybe a bit more. A previouos posting said they are supposed to have a free length of 12.8 or 12.9, so that sounds like normal sag.
Anyway, I think these 2wd springs have to be cut. I didn't install them all the way so I don't know what the final ride height would be, but it looked much too high. Maybe the Carat springs would have been a direct fit. There is conflicting info on the Carat springs specs too, but reading several posts it looks like they are about the same length as the syncro springs but with a higher spring rate. Maybe someone can find the specs.
So currently I have cut off 1.25 coils, which seems to be about 1.25 inches in height. It is a little hard to measure because neither end is flat, especially the cut end. I cut the bottom, figuring the metal spring perch could handle the cut end better than the top rubber piece.
I'll post up more details and ride height when it's done. In the end, I may wind up with Syncro.org springs, but this isn't costing me anything but try. I am a little curious how a slightly softer spring will feel up front and if I guesstimated the right amount to cut off.
Dave
davevickery
PostPosted: Wed May 04, 2016 1:27 pm    Post subject: Re: Syncro - to lift or not to lift, that is the question. Reply with quote
Well that did not work. As I said above, I cut 1 1/4 coils off the stock 87 Westy front 2wd springs. They seemed like they were gong to be way too long, but they were probably OK. Now the van sits about 3/4" lower than it did with the stock syncro springs. If I had not cut them I'm guessing it would have lifted it a 1/2" or so which is what some original posts about doing this said.
The ride felt pretty good though. It felt like I had taken 10 psi out of my tires. If I drove it more I might have noticed more sway and bobbing with the softer springs but just a quick drive around town and it felt more cushy.
Now to buy some actual lift springs (and a spring compressor).
Dave
artacoma
artacoma is offline
PostPosted: Wed May 04, 2016 1:32 pm    Post subject: Re: Syncro - to lift or not to lift, that is the question. Reply with quote
I bought the tintop trail master set from Van Cafe for about 1 1/4" lift and it installed easily without spring compressors. I had the wheels at full droop to install and carefully jacked up to tighten stuff up.
Cheers
Rik
86 Syncro Tintop
2.5 Subie
86 Doka
2.5 Subie
Sodo
Sodo is offline
PostPosted: Wed May 04, 2016 10:11 pm    Post subject: Re: Syncro - to lift or not to lift, that is the question. Reply with quote
Dave the way springrate works....is.... Cutting coils off stiffens the spring. Lets say that spring had 12.5 coils. Cutting 1.25 coils off made it about 10% stiffer. So if you stuffed it on there full length
<Edit>it would have had some initial preload but the RATE ride <Edit>
would have been significantly softer. 10% softer.
'87 Tintop, EJ25, cooled filtered (original) gearbox
....KTMs, GasGas, SPOT mtb
All Vanagons should do this:
Add direct starter-to-chassis cable THEN delete ground strap at front transaxle mount.
The best time to do this mod was in 2010. The second best time is TODAY.
If your starter is slow, this is MORE important.
davevickery
PostPosted: Thu May 05, 2016 7:09 am    Post subject: Re: Syncro - to lift or not to lift, that is the question. Reply with quote
Cutting springs doesn't seem to work well anyway. The springs ends are squared off with the last coil bend back in, but cutting it leaves the end sticking down a lot. There must be a lot of pressure on the strut perch right at that point and it made it harder to line up the shock bolt with it not sitting flat. I got it in and it flattened out with weight on it, but I would not cut a spring again unless I had a way to bend the pigtail flat.
I just ordered Syncro.org springs. I also ordered a clamshell type MacPherson strut spring compresso ($86 on ebay). I am not up for struggling again like I did the first time.
That Maas lift kit that Van-Cafe sells looks pretty nice, similar to the GW Progressives with Fox shocks but cheaper. But $1200 is still out of my price range at the moment. I am also wary of the sagging I have been hearing about. I don't think I have heard that about the SS springs.
T3Syncrohammer!
T3Syncrohammer! is offline
PostPosted: Tue Jun 25, 2019 10:01 am    Post subject: Re: Syncro - to lift or not to lift, that is the question. Reply with quote
Hi, I am getting ready to do a Bilstein B6 HD for 16” shock install on my Syncro Adventurewagen (Weekender set up. No cabinets or roof bed instead a hammock up top!) Aka
Syncrohammer!
I was gonna go GoWesty 2” lift springs but read several people who found that to be not a good pairing? And After reading this thread on to lift or not to lift ?
https://www.thesamba.com/vw/forum/viewtopic.php?t=538751
I have decided to go the spacer route. As many people chimed in and would not go through the effort of lifting it over again!
Currently in the mid to low 17” range front and mid to low 18” in the back.
Want to bring it up to 19.5” stock early Syncro hardtop range or possibly a mild lift beyond that. Considering the limit of potential lift with washer or cutting board spacers (risk of spring shifting position) and the expense of custom made spacers that retain spring position (often times costing the same as buying lift springs!) I did a lot of research and found what appears to be a good reasonably priced solution!
These have an internal neck that retains the springs position and come in 20mm and 30mm shim height.
Roughly 5.2 inch diameter
Roughly 3.9 inch internal neck
See the attached chart below. Wondering what other people think of this idea?
And if there is any reason it is not a good solution?
Or would not work?
Page 10 of 10
