Bret Young Samba Member
Joined: August 26, 2006 Posts: 760 Location: Turlock, CA
Posted: Fri Mar 21, 2014 7:02 pm Post subject: Installing door panels |
Yes....yes.....I know. With screws. Had to get that one out of the way.
So I have a new set of panels from Clara. I want to use the screw holes that are currently in the doors since they are in good shape. Im just trying to figure out how you all match up the screws to their holes behind the panel. Gotta do it right the first time, or you have ugly holes in your finished panel.
Any methods that work well?
I wonder if there is a good way to do some sort of transfer from the door to the inside of the panel to use as a guide....
Any helpful info would be greatly appreciated. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52731 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Mar 21, 2014 7:15 pm Post subject: |
Google Rivet hole finder, if you don't want to make one yourself (2 hacksaw blades) most aircraft tool suppliers sell them for cheap. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4770 Location: St Charles, MO
Posted: Fri Mar 21, 2014 7:22 pm Post subject: |
Yeah! I'll be doing this soon too, and was gonna have to figure out a way to transfer the pre-existing holes in the doors and walls to the new panel set for my '59 DC. The panel set I'm using is a stored-away set of WW panels bought about 15 years ago. I'd like to get the holes drilled correctly the first time. I'll probably treat the backsides of each panel with some sort of coat of water-proofing.
Thanks for any ideas and experience that anyone can share on how to do this the best way with the east amount of mistakes.
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Fri Mar 21, 2014 7:34 pm Post subject: |
I have not tried this yet but this is the idea I came up with for when I do mine
put 2" blue painter tape along the edges of the door where the holes are and poke holes in the tape where the holes are then take the tape off and hold it to the panels and transfer the marks  _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Fri Mar 21, 2014 9:38 pm Post subject: |
I've done almost all my panels (except for the corners) in my Kombi with Clara's panels... she will probably chime in, because she has a ton of tips for installing them. In the beginning, I was using the tape method Joe mentioned....and it works. But by the end, I was eyeballing it. It really is that easy. You'll find that most of the corner holes are so hogged out from over sized screws...or just vibrating over the years, that you'll most likely have to drill a new location anyways. (I know...not the purist answer you were searching for...but only YOU will know that there is an extra hole there). Clara and Greg recommend putting a vapor barrier (clear plastic like the new cars have) behind the panel...but I haven't done that yet.
I was hoping that the panels alone would quiet things down a bit...but I still need to put up strips of dynamat or the equivalent. Her panels are spot on...corners line up everywhere! It does help to have an extra set of hands to get them placed where you want them on the first few holes though.
Scott |
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Sat Mar 22, 2014 5:34 am Post subject: |
Taken from this thread:
http://www.thesamba.com/vw/forum/viewtopic.php?p=3248627
Thanks to 57palm:
You just need to use a hole finder. it is used extensively in aircraft sheet metal and other applications and easy to make yourself. Here is how it goes to make your own.
take two hacksaw blades lay them on top of each other and screw one end together through the holes. The holes in the other end should line up perfectly. Now in one blade hole on the other end fix a small screw or rivet that will fit in the door screw holes. do not make it long or you will not get it in under the panel. Now fix you door panel to the door with a few screws. use the hole finder for the rest by sliding the one blade behind the panel and get the rivet in the hole. Line the other blade up with the one in the hole. The hole in the outside blade will perfectly locate the screw hole for you. Do this for all holes and voila!! no mistakes.
Or you can just buy one from an aircraft tool vendor.
I've used the hacksaw blades. It works. _________________ Tim |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1802 Location: Fortuna Calif.
Posted: Sat Mar 22, 2014 6:52 am Post subject: |
Wow I never there was such a tool. When I did mine I used the OG holes not an easy task, it took me a week (no kidding ) to install the front cards and cargo door cards.  |
66uno Samba Member
Joined: December 05, 2006 Posts: 603 Location: maryland
Posted: Sat Mar 22, 2014 8:52 am Post subject: |
I think the vapor barrier is a good idea too but for mine I finished the inside of the panel as well with spar varnish, several coats. That way, if water should find its way on the inside of the vapor barrier, it will just run down the surface. |
Clara  Samba Member
Posted: Sat Mar 22, 2014 10:39 am Post subject: |
The cab doors are designed so water runs through them when it rains.
I recommend a vapour barrier under the front door panels.
Generally I cut up a shower curtains from the dollar store.
tape it to the door, and tuck the bottom into the door:
or tape the plastic to the door panels:
Do not bother with a vapour barrier anywhere else except under the front door panels.
some tools I used to install the panels:
-Vise grips - to remove old bolts that were leftover from a previous long gone hideous shag carpet interior.
- Hammer and punch - to flatten puckered areas around previously used screw holes to help the new panel lay flat.
- Magnetic tray for new screw for attaching the panel
- Scissors for cutting the foil lined bubble wrap insulation
not shown:
- roll of masking tape for sticking the insulation to the door (yes for cargo doors, wall, roof. not sure about front doors. I have sometimes, but don't anymore. Just putting the door panels in will keep your knee on the door side much warmer, even w/o insulation under there. Under no account use insulation that holds moisture)
-screwdriver for door screws.
Tap old holes flat, this lets the new panels sit flat against the door:
If the hole is too, big, you can either drill a new hole, or hook a tiny wire in there to shrink the hole, or put a piece of tape over it , and poke a hole in the tape with a pin, which also effectively shrinks the hole.
66-67 doors with pull handle:
Buses got the pull handle and the small flipper door handle in October 1965, at VIN 216 046 096.
The pull handle screws into metal 'speed clips' that slide into the door at the square holes. So for most 66s and all 67s, make sure you have those metal clips in place BEFORE you install the door panel.
They take up two of the clip holes:
Door handle with pin:
First part to attach the panel to the door is the door handle. For the handles with the pin, have a friend push the new panel against the door from inside the bus with the door closed. This method works for me. Then you can lean in the open window and install the escutcheon and handle.
The spring goes on between the door and the panel.
*Do any fixes or cleaning/lubricating of the door mechanism before installing the panel.*
insulation in side door
You can make pencil marks to mark where the holes in the bus are, then push a pin through.
After, I wiped the pencil marked off with my thumb.
use drill at pin hole. I use a 1/8" drill bit here. You can waller out the hole if the pin was not in exactly the right place, the trim washer will cover it if it is close.
The hole finder tool looks good, as well.
It does help to have a friend hold the cab door panel when you start it.
I start all screws before snugging them down.
front doors used 23 screws:
install tip pics link at the end of my ads. |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Sat Mar 22, 2014 1:50 pm Post subject: |
For the front door panels I was installing on my 1963 camper, I put a screw part way in every hole (the heads of the screws need to be all even), put a dob of that black crap that fixes holes on roofs on the head of each screw, then I lined up the panel and pushed it against the heads of the screws. After that, there were black spots on the inside of the panel, which is where I drilled the holes from the inside. This method worked really well. _________________ Don't worry; be happy. (Baba) |
cru62 Samba Member
Joined: December 31, 2002 Posts: 4121 Location: Margaritaville.....24/7
Posted: Sat Mar 22, 2014 5:50 pm Post subject: |
I have used masking tape at each hole after making sure that they are all OK to hold the screw tightly. I place the tape at a right angle to the edge of the panel and make a pencil mark parallel to the panel edge through the screw hole. Then, at a right angle to the line I draw another line in pencil from the screw hole. At 3/4" I make a hash mark. I offer up the door panel and make sure that everything is good. The first hole that I drill is always at the point on the top of the panel where it is a slight angle. Push the panel up tight against the door and mark, remove, drill and reinstall. THEN mark the remainder of the holes. Sometimes I have marked the upper, back corner to hold the door with the first hole drilled and screwed. That way the door panel won't shift.
I made the mistake of not marking the hole at the angle point of the door ONCE. I installed the screw in the two upper corner holes and when I put in the screw at the angle, you guessed it, it pulled out the two corner wedges.
As an aside, I was looking at the rear hatch on my Kombi and noticed that there are tiny pilot holes punched into the inner frame right where the screw holes for an inner trim panel would go. That way there would be a hole for the tip of the screw to go into when the panels are being installed. I noticed several on the cargo doors as well. I didn't see any on the front doors, but that would be because there were door panels installed which would necessarily use the pilot holes.
I saw a pair of NOS early doors at a show once. But they were some kind of crossover door with icepick handles and the door panel buttons, so no pilot holes.
My point is that it doesn't make sense to try and use the trim screws to start a hole as they would skitter all over the place. And predrilling would be immensely time consuming. Pilot holes just make more sense. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Clara  Samba Member
Posted: Sat Mar 22, 2014 9:26 pm Post subject: |
cru62 wrote: |
My point is that it doesn't make sense to try and use the trim screws to start a hole as they would skitter all over the place. And predrilling would be immensely time consuming. Pilot holes just make more sense. |
Cab door panels (pre mid Dec 1963) did not have standardized screw placement, and NOS doors did not have screw holes. (Dec 63 & later, with push button handle, cab doors had the holes for the clips)
Door panels from one bus won't have all the holes line up if you move them to another bus.
Cargo door panels do have standard door placement. There are holes punched in from the factory. :)
You can screw through the panel into the holes, they are the right size for the interior panel screws. Though I like to use a drill bit on the panels rather than the screws.
Rear hatch 55-63 also has standard screw placement, and factory holes.
You can transfer cargo door panels or 55-63 rear hatch panels from one bus to another and the holes will line up. |
Posted: Sun Mar 23, 2014 7:26 am Post subject: |
Great tip on installing the front door handle pin Clara. Thanks looks like you may have done this once or twice  |
rebapuck Samba Member
Joined: May 17, 2007 Posts: 1023 Location: Chapel Hill NC
Posted: Sun Mar 23, 2014 11:05 pm Post subject: |
I use the new panel to make a posterboard template. Hold the template in place and rub over a hole to locate it. Stick a screwdriver in the hole to hold it. Same in another location and it's pretty much secure. Rub and poke the other holes. Turn over to use for opposite door. KEEP the template for next time. _________________ Judy
1966 Camper "Hannah"
1967 SingleCab "Khady" |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1151 Location: Burlington, WA
Posted: Wed Mar 26, 2014 10:05 am Post subject: |
Clara wrote: |
Door panels from one bus won't have all the holes line up if you move them to another bus. ... |
It seems the front kick panels were also not standardized. Got an og set of kick panels and most of the holes were just slightly off.
And I agree with Big Bill, great tip on reinstalling the early door handle pin. That sure is a pain to do solo! _________________ -Adam
'59 Mango Bus
'69 Bug - Cobalt Blue |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71484 Location: Phoenix 602
Posted: Wed Mar 26, 2014 10:37 am Post subject: |
otis_bartleh wrote: |
Clara wrote: |
It seems the front kick panels were also not standardized. Got an og set of kick panels and most of the holes were just slightly off. |
I agree based on the few I have installed. _________________ How to Post Photos
Posted: Wed Mar 26, 2014 11:55 am Post subject: |
Another question somewhat similar to this topic. Might as well ask it here instead of starting a new thread.
Any of you guys out there have issues with your door mechanisms in your front doors rattling?
Any processes/materials that you guys use to minimize rattles? Now is the time to address it. Dont want to have to pull the panel off to fix noises. |
Posted: Wed Mar 26, 2014 2:17 pm Post subject: |
Bret Young wrote: |
I just passed through Turlock on the train a couple hours ago, funny... I rarely get door mech noises, but I'm able to just move the door handle slightly to stop it. So your noise might be from a different spot than mine... _________________ -Adam
'59 Mango Bus
Posted: Wed Mar 26, 2014 2:38 pm Post subject: |
Maybe part of my rattling noise is because the door handle isnt installed yet. I am assuming once you put that spring under the door panel and put the pin into the handle it will put some tension on the mechanism.
I have been driving my bus for a month without door panels (put the door handle on when I need to get out), but I get a decent amount of rattling around inside my door.
Anyone else noticed this? |
Clara  Samba Member
Posted: Wed Mar 26, 2014 3:03 pm Post subject: |
EverettB wrote: |
Clara wrote: |
I agree based on the few I have installed. |
I think they standardized the kick panels screw locations for the 4/64 - 67 kick panels. |
