rear shock question.
wj32796
wj32796 is offline
PostPosted: Sun Mar 23, 2014 8:45 pm    Post subject: rear shock question. Reply with quote
I have a 74 baja that im working on. I installed lift spindles and raised the rear one notch. So now I need rear shocks. I dont want to drill out another hole so that stock size shocks will work, besides they are worn out and need replaced anyway.
so what im asking is if anyone has found shocks from a particular vehicle (vehicle make and year) that has worked for thier car. I dont need anything fancy this is just a trail riding car.
VWSTORECHICK
VWSTORECHICK is offline
PostPosted: Sun Mar 23, 2014 9:08 pm    Post subject: Reply with quote
I know you said you want to do some trail riding but that can mean so many things. Woods, sand, etc.
Also are you one to go beating on it or just out to have a little fun with the car?
Give me some ideas on what your going to do with it and I can help you get some ideas on what you should do here.
If you want to call to discuss it I can also help you out.
wj32796
wj32796 is offline
PostPosted: Mon Mar 24, 2014 7:58 am    Post subject: Reply with quote
No im not going to beat on it, mainly just have fun on established forest trails occasionally some mud. Not going to go fast either. Im running the stock shocks up front and dont want to spend a bunch of money for rear ones they just need to be the right size because of the 1 notch lift in the rear.
wj32796
wj32796 is offline
PostPosted: Mon Mar 24, 2014 8:01 am    Post subject: Reply with quote
dirtkeeper
dirtkeeper is offline
PostPosted: Mon Mar 24, 2014 8:29 am    Post subject: Reply with quote
If you haven't notched the spring plate you should be able to use stock shocks. Stock size kyb gas adjust shock is a good choice.
wj32796
wj32796 is offline
PostPosted: Mon Mar 24, 2014 8:31 am    Post subject: Reply with quote
I forgot to mention but yes I did notch the spring plates. My stock rear shocks are about 1" short to the original bolt hole now.
ORANGECRUSHer
ORANGECRUSHer is offline
PostPosted: Mon Mar 24, 2014 9:38 am    Post subject: Reply with quote
It's real easy. measure from mount to mount for full droop to full extension and add 1/2" travel so the shock doesn't bottom out. Then go to a shock vendor website and try to match your measurements to one of their shocks.
Here's a link to the Rancho list that I used when I searched for my shocks. RS5000 can be had for around $50/ea. which is pretty decent.
http://www.gorancho.com/assets/catalog/2012catalog_pdf/2012-13_Rancho_shock_specifications.pdf
Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes
VWSTORECHICK
PostPosted: Mon Mar 24, 2014 7:51 pm    Post subject: Reply with quote
I would go with something like a gas shock in this application.
Stock shocks are oil. The KYB Gas-A-Just shocks work well for easier off-roading.
wj32796
wj32796 is offline
PostPosted: Mon Mar 24, 2014 8:01 pm    Post subject: Reply with quote
Ya I want a gas shock for sure just need to figure out a part number so I can order them.
VWSTORECHICK
PostPosted: Mon Mar 24, 2014 8:05 pm    Post subject: Reply with quote
What is your measurement eye to eye extended & compressed?
wj32796
wj32796 is offline
PostPosted: Mon Mar 24, 2014 8:08 pm    Post subject: Reply with quote
ill have to get it in the morning.
VWSTORECHICK
PostPosted: Mon Mar 24, 2014 8:11 pm    Post subject: Reply with quote
No problem I will keep an eye out and try to help you out.
Have a nice night!
wj32796
wj32796 is offline
PostPosted: Mon Mar 24, 2014 8:30 pm    Post subject: Reply with quote
Have a nice night!
I appreciate it! Thank you.
VWCOOL
VWCOOL is offline
PostPosted: Tue Mar 25, 2014 5:00 am    Post subject: Reply with quote
Maybe a Kombi/Type 2 shock will work...?
VWSTORECHICK
PostPosted: Tue Mar 25, 2014 5:59 am    Post subject: Reply with quote
We won't be able to help him out really until we figure out how much length he has.
T2 shocks are 22" I think there going to be to big.
dirtkeeper
PostPosted: Tue Mar 25, 2014 7:47 am    Post subject: Reply with quote
Here's a kyb size chart. http://www.kyb.com/technical/documents/ShockDimensionsSecured.pdf
wj32796
wj32796 is offline
PostPosted: Tue Mar 25, 2014 8:47 am    Post subject: Reply with quote
Ok I think im doing something wrong.
for the extended I jacked up the car until the tire was off the ground. I measured center of upper shock mount hole to center of lower shock mount hole and got 17-1\4".
For compressed I jacked up on the lower shock mount until the tire raised off the ground and I got 15" still measuring center of shock mount holes. Does that sound correct? Or is there a different way I should measure?
dirtkeeper
PostPosted: Tue Mar 25, 2014 9:33 am    Post subject: Reply with quote
You need to take the wheel off, tie a chain around the jack and the car frame (around the shock area works for me) then jack up the hub (shock bottom whatever) until the rubber stop hits its stop. that is full compression. You wont be able to measure this unless you hold the body frame down, other wise the car just keeps lifting and the suspension wont compress.
i will add i am redoing my rear suspension and i have 11.5" to 17" ( my shock bottoms have been cut and raised an inch) i didnt really look at the kybs ,after getting bilsteins in the front i appreciated how much a good shock makes a difference ( i have been happy all along with my KYBs) yad yada .. anyway the only shocks that i could find that actually would fit the travel and size were very expensive bilstein5165,s part # 25 187878
have you checked your cv's? if you notched the spring plate they may not articulate enough for the new travel. no problem..just means more upgrades$
wj32796
wj32796 is offline
PostPosted: Tue Mar 25, 2014 11:07 am    Post subject: Reply with quote
wj32796
wj32796 is offline
PostPosted: Tue Mar 25, 2014 12:09 pm    Post subject: Reply with quote
I didn't do that double post on pourposes. Not sure how that happened? Lol.
