bajafreaks Samba Member
Joined: July 17, 2007 Posts: 469 Location: gardnerville, nevada
Posted: Sat Mar 29, 2014 4:44 pm Post subject: early 2.0 rebuilt engine value ? |
I recently bought a 74 Porsche 914 that has a rebuilt 2.0 engine in it.
Case #CV044076 which states its from a 80-83 vanagon. Per the guy I bought the car from he says it was freshly rebuilt, but has a rear seal leak and the project was then put on hold so there are zero mile on the rebuild.
I want to sell the engine and get the proper one for my 914 restoration, any ideas on what this engine would be worth ? any one want to buy it ?
Thanks. |
Jeff's Old Volks Home Samba Member
Joined: December 19, 2011 Posts: 819 Location: Chester Basin, Nova Scotia
Posted: Sat Mar 29, 2014 4:51 pm Post subject: |
$12-1500? I sold a couple very low mileage 2.0's for $1500 complete with exhaust and FI.
Jeff _________________ www.jeffsoldvolkshome.com
2004 Jetta TDi Wagon
2002 Smyth Ute TDi
1990 Vanagon weekender Syncro AAZ
1987 Syncro Doka AAZ...soon to be TDI
2014 DL650ABS Xpedition
1986 Weekender Syncro (Under construction)
1987 Westfalia (Under construction)
1987 Syncro Single cab |
hdenter Samba Member
Joined: October 14, 2008 Posts: 2966 Location: San Luis Obispo, CA
Posted: Sat Mar 29, 2014 5:02 pm Post subject: |
I would not pay that kind of money for an engine that I haven't heard running. The parts for those engines are not any less expensive than the water cooled engines. Replace the seal and fire it up. Do a you tube video and show the compression. Then, get you $1200+ price. Otherwise it is just an unproven $500 core. At least in my book. Do you have documentation for the rebuild?
Hans _________________ '79 triple white convertible bug
'84 sunroof vanagon
'85 weekender |
Posted: Sat Mar 29, 2014 5:03 pm Post subject: |
'84 sunroof vanagon
'85 weekender |
the joker Samba Member
Posted: Sat Mar 29, 2014 5:19 pm Post subject: |
| Better hope it didn't come from waterboxer inc., then it worth maybe a core exchange at best. |
Posted: Sun Mar 30, 2014 10:12 am Post subject: |
| hdenter wrote: |
Hans |
I don't have any build history just a mans word.
I fired it up briefly before it was pulled from the car. I did a compression check on it and all cylinders were 150. The case has been split with new sealant showing. I'm going to pull one of the heads to get pictures of the pistons and back side of the heads. I know its a gamble for a buyer but I wont be asking full price for it either although its worth more than a core fee. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19166 Location: Retired South Florida
Posted: Sun Mar 30, 2014 10:35 am Post subject: |
A 2.0 engine from a 914 from memory does not interchange with a vanagon 2.0 directly. The exhaust ports are the wrong shape and I am pretty sure the sparkplug location in the head is slightly different on the 914 as well.
I would add that even between the 2.0 bay and the 914 they are not completely interchangeable. I could be wrong on both counts too. |
Posted: Sun Mar 30, 2014 11:20 am Post subject: |
| rsxsr wrote: |
I have the square ports on these heads and yes the plug locations are different from 2.0 Porsche heads to 2.0 bus heads. |
Smudge1 Samba Member
Joined: July 15, 2009 Posts: 51 Location: Western Alberta Canada
Posted: Sun Mar 30, 2014 1:25 pm Post subject: |
If memory serves me correct a 2.0 914 head will have 3 studs on the intake manifold.
Those are desirable heads.
If it doesn't have those heads it's not a 914 2.0.
If the heads have 2 studs it could have any combo of bore and stroke.
You don't want to run a type 4 with big bore thin wall cylinders in a bus.
It's ikely a 1.7, 1.8 or maybe a 2.0 type 4 VW engine.
Smudge |
Posted: Sun Mar 30, 2014 3:32 pm Post subject: |
| Smudge1 wrote: |
Smudge |
As I mentioned the engine case # is from a 80-83 vanagon so its definitely a vw case, it doesn't have Porsche heads on it. I'm planning to pull one of the heads to measure the cylinder diameter |
oorwullie Samba Member
Joined: May 01, 2003 Posts: 2365 Location: fribourg,switzerland
Posted: Sun Mar 30, 2014 3:36 pm Post subject: |
i wonder how many times they tried to fix that oil leak?
i once had an engine where i changed the seals a coupla times for no cure and then discovered it was actually a hairline crack in the case...............  |
Posted: Sun Mar 30, 2014 3:59 pm Post subject: |
| oorwullie wrote: |
Its my understanding that the guy installed the rebuilt engine and once he got it running discovered the leak. The sad part of the whole story is he discovered he had cancer right around this time and gave up on the project because of his health and passed away a short time later. |
Posted: Mon Mar 31, 2014 7:05 am Post subject: |
I totally misread your thread.
You now own a 914 that is powered with a Vanagon engine and you want to repower it with the original 914 2.0. And sell on the vanagon engine to recoup some money.
If you can't run the engine, upload a video to you tube, do a cylinder leak down and compression test, it is only worth core value if that. |
