Front Heater Box Rebuild -What foam to use for flapper doors
scottjk
scottjk is offline
PostPosted: Sat Apr 12, 2014 6:36 am    Post subject: Front Heater Box Rebuild -What foam to use for flapper doors Reply with quote
I took out my front heater box to replace both wiper shaft assemblies and decided to clean it up. All the foam on the flapper doors is disintegrated and I'd like to replace it.
What foam do you guys recommend? I'd hate to put something in there that reacts with heat and either smells or off gases.
I've got some closed cell foam left over that is used for under floor applications. I wonder how this would work.
Thanks
Scott
1985 Westfalia 2.5L EJ
Alaric.H
Alaric.H is offline
PostPosted: Sat Apr 12, 2014 6:51 am    Post subject: Reply with quote
http://www.amazon.com/3M-03420-Yard-Pickup-Camper/dp/B000CPZYFE
dhaavers
dhaavers is offline
PostPosted: Sat Apr 12, 2014 6:52 am    Post subject: Reply with quote
EDIT: Damn, Al beat me to it!
"The WonderVan"
scottjk
scottjk is offline
PostPosted: Sat Apr 12, 2014 7:14 am    Post subject: Foam Reply with quote
How dense is that stuff? Will it allow the flapper doors to close enough?
This stuff looks good for sealing the heater core barrier but I'm not sure it would work on sealing the 6 flapper doors.
luVWagn
luVWagn is offline
PostPosted: Sat Apr 12, 2014 10:06 am    Post subject: Re: Foam Reply with quote
Others have used it with success, there are threads on here detailing install tips (including use of a hot awl).
'91 Double Door Transporter
danfromsyr
danfromsyr is offline
PostPosted: Sat Apr 12, 2014 10:08 am    Post subject: Reply with quote
I use the 1.5in grey felt you find in the window/door weatherstripping isle of the hardware store. you'll need to cut/punch the holes for the retaining plates to snap thru.
http://www.frostking.com/wp-content/uploads/2011/12/S258-17.jpg
you can see a good write up here on Cojinchef's blog site, about mid way down.
http://chojinchef-vanagonowneragain.blogspot.com/2011_12_01_archive.html
Abscate wrote:
chimivee
chimivee is offline
PostPosted: Sat Apr 12, 2014 9:33 pm    Post subject: Reply with quote
I re-foamed the heater flaps on a prior van about 10 years ago and, at least at the time, I couldn't find any camper top foam locally that seemed like a suitable replacement, even though that's what everyone recommended. But I don't remember if I tried specifically the 3M stuff mentioned in this thread.
I ended up using pipe insulation wrap and it seemed to work well. It's thin, fairly dense closed cell foam, but very soft and squishable - kinda like memory foam the way it compresses.
-James
86 Syncro Westy, etc
View user's profile Send private message Visit poster's website AIM Address Instagram Gallery Classifieds Feedback
IdahoDoug
IdahoDoug is offline
PostPosted: Sun Apr 13, 2014 4:05 pm    Post subject: Reply with quote
I have a thread on it as well. Whatever I used is ID'd in the thread and it seemed tailor made. It was extremely soft so conformed well to the surfaces with minimal pressure but also had kind of a "memory foam" feel so when the flaps were closed it seemed to further mush and conform with any high spots not preventing full and even seal pressure. Worthy project. Quieted the van on the highway (was whistling) and the fan blew a hurricane after this job.
DougM
SyncroJack
SyncroJack is offline
PostPosted: Sun Apr 13, 2014 5:01 pm    Post subject: Reply with quote
What ever foam I used sticks in freezing weather and occasionally bends the control cables. Grrrr. I need to revisit the heater box foams.......
86 Syncro 1.8T power!, 76 Westy
