DannoT Samba Member
Joined: September 15, 2007 Posts: 249 Location: Up where the air is thin
Posted: Sat Apr 26, 2014 9:41 am Post subject: |
| Surprisingly its during forward flight when a helicopter's engine is working the least and cylinder head temperatures are the lowest, during a winter flight it can become necessary to descend into a hover in order for the ch temperatures to rise in to the green arc. most of my experience is with the HIO-360D1A Lycoming engine which is a 360 cubic inch horizontally apposed 4 cylinder engine rated at 190hp. If an air cooled 4 cylinder engine the size of a big block V8 can keep cool at altitude a smaller vw engine should be able to do the same with a custom cooling shroud and external oil filters. The Lycoming engine is used for a 1200 pound helicopter with a maximum gross weight of 1800 pounds, so a vw powered one would need to be a single seater weighing no more than 1200 pounds. |
Malokin Martin Samba Member
EverettB  Administrator
Joined: April 11, 2000 Posts: 71956 Location: Phoenix 602
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15486 Location: Casa de Oro, California
Posted: Thu Jan 16, 2025 6:55 pm Post subject: Re: Helicopter bus? |
| Is it hard to get that approved? |
Busstom Samba Member
Joined: November 23, 2014 Posts: 4590 Location: San Jose, CA
Posted: Fri Jan 17, 2025 2:17 pm Post subject: Re: Helicopter bus? |
| BarryL wrote: |
It shouldn't be hard at all, it will be registered as an "amateur-built" aircraft in the "Experimental" category, like other kit and home-builts. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom)
| cory464 wrote: |
| if you aren't perfectly centered in the hole you will have issues when you tap it. |
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2606 Location: UK (South)
Posted: Sat May 24, 2025 2:43 pm Post subject: Re: Helicopter bus? |
Pops up regularly on the Ruined VWs facebook group...
_________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
Posted: Sat May 24, 2025 9:12 pm Post subject: Re: Helicopter bus? |
Is it done? That’s rad if it is. I wouldn’t say, “ruined”. Plus it’s a fried egg so… meh?  |
Posted: Sun May 25, 2025 2:23 am Post subject: Re: Helicopter bus? |
| Malokin Martin wrote: |
| Is it done? |
Not quite. That post said he'd just pulled it outside and it barely fitted under the hangar door.
There was another update overnight showing the rotor head going on though...
This is his Facebook page...
https://www.facebook.com/groups/890839631733591/user/603486900
In a post on the Ruined VWs page, he said it's just art.
