PastDown Samba Member
Posted: Mon Jun 09, 2014 6:16 am Post subject: Splitcase Gearbox help... |
Hi,
When I purchased my BD, it came with a gearbox, the part number 113.301 101 B Does 113 mean it was a beetle gearbox?
It has the number 2A.... I can get the rest later.
As I understand that there are two gearbox types, the early vertically split case boxes used on the 'crash' and early 1200 vans to the early 50s.
There seems to be NO web-based resource for identifying stock split gearboxes. I find this hard to believe, but I can't find anything, just the beetle box lists.
Thanks for any help.
mandraks Samba Member
Joined: November 28, 2004 Posts: 7125 Location: Lawrenceville, Ga
Posted: Mon Jun 09, 2014 8:01 am Post subject: |
your post in the UK indicates a 1958 manufacture? this would make this not a barndoor bus.
http://www.ssvc.org.uk/phpbb/viewtopic.php?f=6&t=51410
Barndoor production ended in 55. you might want to repost in the regular split to 67 forum for more exposure _________________ regards
Uli
EverettB  Administrator
Joined: April 11, 2000 Posts: 72016 Location: Phoenix 602
Posted: Tue Jun 10, 2014 1:23 am Post subject: |
That's really helpful, Thank you EverettB. I wasn't aware that the 2A relates to split screen. If it was beetle does it start with A, if that's incorrect, do you know the start code for a beetle?
2A1593584 is not my serial number, I'm off around to my unit tonight, so I will get my serial code. Is there somewhere I can check online?
Thanks
Rob |
Posted: Tue Jun 10, 2014 12:49 pm Post subject: |
The number is 2A2062018, code on the top is 323977 and the nose cone number is 211.301.211.
Thanks
Rob |
Posted: Wed Jun 11, 2014 1:14 am Post subject: |
59, that's what I thought.
The number is located on the top of the gearbox.
Capriacci Samba Member
Joined: February 15, 2011 Posts: 298 Location: Brazil
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 1109 Location: Melksham, UK
Posted: Tue Sep 09, 2014 3:17 am Post subject: Non Synchro Gearboxes On Early Type 2? |
Could somebody help here please.
I've been offered 4 complete Barn door gearboxes and reduction hubs, but lacking the nose cones, where previous owners have gone the IRS route.
Did early type 2's have non synchro gearboxes, and if so, up until what gearbox/chassis number, or date please?
I could use non synchro boxes on my pre Oct 52 Beetles, and am already using the reduction hubs and drive shafts off one for my 43 Kubel.
Thanks for any help. |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2409 Location: Graz, Austria, Europe
Posted: Thu Sep 11, 2014 1:52 am Post subject: |
according to the details section on Tonnys site (barndoor.dk) they started the synchro trans in early 53 with
| Quote: |
... synchromesh transmission. At this type only the
1. gear was unsynchronised. It is how it looked from ch. number 20-047017
for reference my July53 Single cab 20-57... has a 20-476.. (synchro)transmission, so obviously the transmission numbers are off the chassis numbers ! _________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
62 Dickholmer, Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
bauhaus Samba Member
Joined: September 17, 2008 Posts: 1 Location: Wiltshire
Posted: Tue Nov 18, 2014 2:36 am Post subject: |
Hi Martin,
Did you buy the barn door gearboxes/axles? Would you like to sell one?
I'm restoring a 44 kubel and looking for a good pair of axles but I'd be interested in a complete gearbox/axle assembly if ones available.
Regards
Nev |
VWLady Crazy VW Lady
Joined: March 13, 2004 Posts: 3868 Location: Twin Cities, MN
Posted: Fri Nov 21, 2014 9:44 pm Post subject: |
I have a trasmission that was in my 57 euro deluxe with the number 2A-149400 So this appears to be from a 53?
I'd very much like to get one closer to December 1956 when my bus was made.
Anyone want to trade ?
Please PM me if you do. |
Posted: Sat Nov 22, 2014 9:59 am Post subject: |
This is what I have. I'm not sure what you mean by smooth case.
Posted: Sat Nov 22, 2014 10:17 am Post subject: |
I agree that is a '53 transmission.
I guess they used what they had on hand since the reduction boxes and nose cone are later pieces.
The earlier transmission casings have less cross-ribbing.
Here's my later NOS case:
A side by side comparison would be better but I no longer have the early '54 transmission pictured above. _________________ How to Post Photos
Posted: Sat Nov 22, 2014 10:23 am Post subject: |
| While taking pictures I found a factory rebuilt stamp and the KD 260937 so that probably explains the later nosecone and RGB. |
ulme2004 Samba Member
Joined: September 23, 2006 Posts: 5 Location: Germany
Posted: Sat Feb 13, 2016 1:56 pm Post subject: Re: Splitcase Gearbox help... |
Hallo, I need help in determination the model-year relation
of my barn find splitcase gearbox.
It seems to fit to a 58 T2 kombi
But is it an earlier gearbox? Which model year exactly?
The number is N 2A 1458901
what means N?
Regards Andreas
Posted: Fri Mar 25, 2016 3:32 am Post subject: Re: Splitcase Gearbox help... |
| nobody an idea? |
