BarryL  Samba Member
Joined: November 01, 2004 Posts: 15258 Location: Casa de Oro, California
Posted: Fri May 30, 2014 1:35 pm Post subject: |
How do you know which quadrant of the disc to hold against or do you try to keep it in total 360degree contact? |
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
Posted: Fri May 30, 2014 4:34 pm Post subject: |
I use the free editing software that came with my computer, iMovie and a small point and shoot camera with video. Keep it simple!
I am no expert at a shrinking disk. This is the blind leading the blind here. The set I got had a little one and a big one. I don't have a large side grinder yet so I have only tried the little one. The disk will kind of find the high spots as I move it around. Once I feel it I put more pressure at the top of the disk and let it warm up. It does not have to glow. Full disk contact would mean the area is flat and just bog down the motor.
Kurt _________________ "The more I get done the less it looks like I did anything"
1959 Single Cab Restoration"Funky Truck"
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight=
1965 21 Window Restoration Thread (From old photos)
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1963 Panelvan build "Tyvanosaurus Wrecks"
http://www.thesamba.com/vw/forum/viewtopic.php?p=8351639#8351639 |
casey & the cricketes Samba Member
Joined: March 15, 2012 Posts: 61 Location: in the middle of damn california
Posted: Sat May 31, 2014 6:23 am Post subject: |
i like using the large shrinking disk it works great. be careful with them big grinders, i learnt to practice the two handed method when i cut my 9" grinder on . oh and thanks for posting all the awesome videos the funky truck is awesome! _________________ anything worth doing is worth doing right |
motofly196 Samba Member
Joined: June 01, 2008 Posts: 1467 Location: Eastern WA
Posted: Sat May 31, 2014 11:04 am Post subject: |
I've got a few hinge areas to repair on my truck also. I have used nut plate sections out of donor decklids to repair that area before...and it's no stronger, plus it takes a ton of time! I am going to copy your method of using new flat stock! Excellent idea, and looks to be WAY stronger! Thanks for posting this up!!!
Scott |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7117 Location: Lawrenceville, Ga
Posted: Mon Jun 09, 2014 8:22 am Post subject: Re: I had a blast today |
I think you will be pleasantly surprised when you wash those windows  _________________ regards
Uli
kombisutra Samba Member
Joined: October 02, 2003 Posts: 4127 Location: San Anselmo, 10 miles North Of San Francisco
Posted: Tue Jun 10, 2014 8:34 pm Post subject: |
glideking wrote: |
Paid too much for this at Kelley Park but...
... portrayed though this exceptional repair, the vision of both will put you at peace when the world is falling down around you! Very, very nice! Dash porn right there! |
Posted: Fri Jun 20, 2014 10:32 pm Post subject: Sealing Wax Red L53 finding a good match |
I had read that this was going to be a challenge. Red is an extremely difficult color to get right. Our eyes are very sensitive to slight variations. Add to that the variations from the factory over the years and differing ages and oxidation. I am working with my second paint mixer. The first one did not work out. This new guy is very interested in getting it right. We spent three hours on this today. Our first attempts were all to milky then they went too much magenta. I don't want a lipstick pink single cab! It is worth getting it right as this paint is very expensive. My single cab needs at least two gallons.
The treasure chest door and gas flap are from different vehicles from swap meets. The gas flap was under three other colors and polished up ok. The area under the treasure chest lock still had the original gloss and the deepest color so we chose to match to that. We started with a Nason chip and ended way out in custom land.
The orange spot was the best match from the first guy. This is just finger painting. The bubbled area above my thumb is from the pint I will spray out this weekend. He won't give me the formula until I buy my first gallon. I will share it with you if it turns out to my liking.
Spitty1974 Samba Member
Joined: September 30, 2011 Posts: 647 Location: California
Posted: Fri Jun 20, 2014 11:32 pm Post subject: |
Hi Kurt,
Are you going to be spraying single stage pain on your truck, or is it base and clear? I want to do single stage on my bus, so curious to see if you're using single stage. I was wondering what the single stage paint is like these days with all of the regulations here in Northern California, is it all water based?
I really enjoy all of your postings. Thanks for sharing all the details and for passing on your expertise and knowledge.
Paul |
Posted: Fri Jun 20, 2014 11:52 pm Post subject: yea "single stage PAIN" |
I sprayed my Turquoise bus with base / clear many years ago. I liked it when I did it but it does have a lot of depth, like a glazed donut. Not that solid color of a vintage VW. I am going with a single stage urethane this time. We can still get urethane here in the North Bay. I want this color to be solid looking with not too much shine. It is supposed to be an economical work truck after all. Thanks for the compliments. My expertise and knowledge were gained from working on my two VW projects. Everything else is just made up!
cru62 Samba Member
Joined: December 31, 2002 Posts: 4121 Location: Margaritaville.....24/7
Posted: Sat Jun 21, 2014 9:35 am Post subject: |
Kurt-I have a chunk of roof from over the DS door that has a good swath of original SWR on the INSIDE of the roof which had been covered with the headliner board and never exposed to sunlight. I can send that to you if you want to get the best match to original paint. I tried giving them ( I have several pieces) using an ad on this site with no takers. I will be keeping one for my own use, but you, or anyone reading this thread, are welcome to a piece if needed.
I can send you a pic if you want. I just don't want to post it in the Gallery and waste space. _________________ "My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Posted: Mon Jun 30, 2014 1:40 pm Post subject: |
No slacking! I have been working hard. While waiting for the paint chip from cru62 to verify the sealing wax red color formula, I have been doing the rest of the blasting. I am now done with all the large parts blasting. I have cleaned the garage. What a mess! Any small parts blasting will be in the cabinet.
Scrapped off some layers with a razor blade. It was thick and came off in sheets.
Used a disk sander to remove most paint. Way faster than just blasting alone.
Blasted the rest off. This is a rare picture as that much bare metal is not left lying around for long.
The Mercedes is being used as a drying rack for the acid washed parts.
The gates will be disassembled and worked now that they are clean.
wcfvw69 Samba Purist
Posted: Mon Jun 30, 2014 1:49 pm Post subject: |
You're doing such a great job on this truck Kurt. I have to ask two questions-
1) Are you keeping track of the hours you have in this and if so, how many? When I did my restoration of my rusty 69 convertible, I wish I had!
2) Are you shooting for a completion date or do you have one in mind?
Bill _________________ Contact me at [email protected]
The Samba member since 2004.
Chris Paterson Samba Member
Joined: February 21, 2010 Posts: 1068 Location: Newbury Park, CA
Posted: Mon Jun 30, 2014 2:03 pm Post subject: |
glideking wrote: |
#2:
I really miss driving my truck and want to finish before I am too old. Driving this year, 2014 is my goal without taking any shortcuts.
#1:
The hours are easy to figure out. It is the same as the number of hours that most other average Americans watch T.V. Get back to work!
Kurt |
Ohhhhhh Snap! Cancel your cable and build your VWs!! Also, you'll have a little extra money every month! _________________ - Chris
58' PGSG |
Posted: Mon Jun 30, 2014 2:27 pm Post subject: |
glideking wrote: |
#2:
#1:
Kurt |
So, the average American watches I believe 4 hours of TV per day. So, your first post was 2-2013. If you worked on it each day for the avg, 365 days + roughly 4 months or an additional 120 days. 485 days X 4hrs a day = HOLY $hit or 1940 hours!
What the hell, times $80 per hour= $155,000.00  _________________ Contact me at [email protected]
Posted: Mon Jun 30, 2014 2:46 pm Post subject: |
That is not including all the hours I spent over the last 20 years keeping it running. All those upgrades, brakes,trans & boxes, steering and engine builds. All productive time well spent. I am sure I will spend more money on my truck than it will be worth on the market, not including time. Happily!
If I wanted a restored truck the most cost effective way is to buy one already done. My truck is special to me and the journey has enriched my life. VW people understand.
Kurt
I did watch some TV in there somewhere... _________________ "The more I get done the less it looks like I did anything"
Posted: Mon Jun 30, 2014 3:16 pm Post subject: |
glideking wrote: |
Kurt
I did watch some TV in there somewhere... |
It's so true, plus you think any car is going to require maintenance and money. So how much more are your really paying? Parts are cheap in relation to modern cars. _________________ - Chris
58' PGSG |
lumber-baron Samba Member
Posted: Mon Jun 30, 2014 8:41 pm Post subject: |
glideking wrote: |
#2:
#1:
Kurt |
You're putting me to shame Kurt, I have to admit I've been sneaking in a little TV. I hope you accomplish your goal of being back on the road this year, Funky is looking good! |
