Engine bolt questions for 1974 Super 1600cc
Page: Previous  1, 2
pb_foots
pb_foots is offline
PostPosted: Tue Jul 08, 2014 5:38 am    Post subject: Reply with quote
gjetson wrote:
Plumbers putty? Really? Somehow I don't think the
guys on the assembly line used plumbers putty.
Do as Cusser suggested and you will have no problems.
Now I'm curious. How did the guys on the line install this bolt? I really don't see VW designing a fastener that requires two people to assemble, doesn't make sense.
Was the engine installed in the pan before the body was dropped?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Jul 08, 2014 5:57 am    Post subject: Reply with quote
Yes
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
pb_foots
pb_foots is offline
PostPosted: Tue Jul 08, 2014 7:56 am    Post subject: Reply with quote
Well, there you go.
FWIW, I've used both tape and putty to hold the bolt in, but I prefer the putty mostly because it just falls off as the bolt is tightened and I don't have to crawl under there to peel off tape.
the key is to have clean fasteners. A couple seconds with a wire wheel on that bolt will make a huge difference.
wuwei75
wuwei75 is offline
PostPosted: Sat Jul 12, 2014 1:59 pm    Post subject: Reply with quote
hi all,
I'm very happy to say that I did NOT have to remove the engine to get the seals in. This pic shows the engine seal. The firewall seal is done also.
My method:
1. Spray channel and rubber insert with silicone spray
2. Line up the bottom edge and then use a screwdriver to get the top edge into the channel.
Also got my bolts secured and now all 4 are torqued correctly.
That's it. Took my 30 minutes total.
Thanks for all your help.
Brett
1974 Super Beetle (Jill)
1972 Fastback (Maude)
johnnypan
johnnypan is offline
PostPosted: Sat Jul 12, 2014 3:28 pm    Post subject: Reply with quote
Glenn wrote:
showoff...
Tim Donahoe
Tim Donahoe is offline
PostPosted: Sat Jul 12, 2014 3:41 pm    Post subject: Reply with quote
Can I assume that, after taking the photograph, you pushed the inner edge of the seal down (under) the edge of the engine tin?
Tim
wuwei75
wuwei75 is offline
PostPosted: Sat Jul 12, 2014 3:48 pm    Post subject: Reply with quote
Tim
hi Tim
the engine tins are not in it right now. gotta put her all back together...Smile
Brett
wuwei75
wuwei75 is offline
PostPosted: Sat Jul 12, 2014 3:49 pm    Post subject: Reply with quote
johnnypan wrote:
Glenn wrote:
showoff...
what is that and where do I get one?
Harleyelf
Harleyelf is offline
PostPosted: Sat Jul 12, 2014 4:00 pm    Post subject: Reply with quote
I use a welder's pointy vise grip on the D bolt. It will seat in the correct position once you begin to tighten the nut.
Do you have the pressed-in nut on the upper right? The bolt should not need a nut on a car as young as yours. If there isn't room under the car you might consider rolling the two left wheels up onto the curb from the edge of your driveway.
wuwei75
wuwei75 is offline
PostPosted: Sat Jul 12, 2014 4:03 pm    Post subject: Reply with quote
hi there
I got a bolt and used an extra long ratchet extension and got it on. the engine side has a built in nut. all is well now...Smile
Brett
johnnypan
PostPosted: Sat Jul 12, 2014 5:30 pm    Post subject: Reply with quote
wuwei75 wrote:
johnnypan wrote:
Glenn wrote:
showoff...
specialty tool made by Hazet for VW..
Ive got a Hazet brake spoon..it feels right, using Vw tooling for Vw repair..
wuwei75
wuwei75 is offline
PostPosted: Sat Jul 12, 2014 5:34 pm    Post subject: Reply with quote
johnnypan wrote:
wuwei75 wrote:
johnnypan wrote:
Glenn wrote:
showoff...
I bet. that is a must have. will have to locate one. thanks.
williamM
williamM is offline
PostPosted: Sat Jul 12, 2014 6:14 pm    Post subject: Reply with quote
johnnypan wrote:
Glenn wrote:
showoff...
We found more of those while doing oil/filter jobs- people would put them on and then forget them- I even bought one off Snap and soon it was missing- yup gone down the road on a clutch job.
Something bout "Yahoo job done" that makes you forget your tools.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
Gdwilson001
Gdwilson001 is offline
PostPosted: Tue Mar 30, 2021 10:37 am    Post subject: Reply with quote
Relyt wrote:
Image from Asiab3
Here you can see the "D" is supposed to wedge against a piece on the starter. If yours no longer has a place to wedge it against I would suggest replacing it with a normal head bolt and getting help tightening it down.
What I did to hold it in place is to put a piece of electrical tape around the shaft right next to the head, it's able to wedge it into the hole enough to let me start tightening it.
Reviving an old thread. I recently pulled the starter in my 64 bus. In doing so I struggled with removing the top starter bolt as my 6v starter does not have a D shaped bolt or an extension on it that would hold a D-shaped bolt in place.
See the picture. Mine is on the right side and a D-shaped set up is on the left.
My question: are these features (D-shaped bolt and ridge extension) on most 6 volt starters or just 12? I’d hate to buy a replacement only to encounter the same issue.
Cusser
Cusser is offline
PostPosted: Tue Mar 30, 2021 1:23 pm    Post subject: Reply with quote
Just get a helper to hold the bolt end securely at the starter; that's what we did in the old days.
Page: Previous  1, 2
Page 2 of 2
