Engine in pieces, not sure what I'm doing, lots of questions
Page: Previous  1, 2, 3
57BLITZ
57BLITZ is offline
PostPosted: Fri Jul 11, 2014 2:49 pm    Post subject: Reply with quote
sb001 wrote:
Mattegan, where did you read all this info? What are these documents you speak of --the Gene Berg stuff?
It's not that I'm questioning any of it- I just want to read up on the same stuff myself.
I'll tell you where you could read "all this info" . . .
Go back to the post I made on page one of this thread and click on the link I provided for you!
There is a TON of information in the Gene Berg catalog and it is information that has been available for several years before you ever even had a computer!
Mattegan, from the photos, it's hard to tell, so look at the area of the case surface around those large, center studs around the #2 main bearing . . . . It ideally should have a machined appearance like the rest of the case mating surface.
Also, you can put the case together (without any internal parts) and torque ALL the case nuts to specs . . . . that same area should fit together tight and with NO gap!
RE the 82mm crank . . . if you are like me, you will not want to pay the price of a GOOD crank. For a mild street engine, quality-reworked VW con-rods are fine for up to 78.4 cranks.
And I too have been happy with CB Performance . . . I have their heads and other parts . . . they have taken good care of me!
BTW, maybe a typo you made about the Webers . . . You looked at 40IDF or 48IDA . . . big differences between them. I will be using the 40IDF Webers on my new (90.5 x 78.4) engine. I ran 48IDA Webers on my 2180cc . . . it was a MONSTER!
Oh, and put aside about a hundred bucks for a complete balance job.
Jesucristo es mi Señor y Salvador!
OLD VW NUT
OLD VW NUT is offline
PostPosted: Fri Jul 11, 2014 7:28 pm    Post subject: Reply with quote
mattegan wrote:
Yeah, I read on the Aircooled.net article that I should never use a 'used' case for anything other than stock, but I've heard other things elsewhere. What if it's never had an align-bore?
You're reading info provided by a business. They are in business to sell parts - not info. Many of us have maxed out used cases for large motors. You just need to check - double check - then get the right machine shop to do the machining. Things need to be machined in the proper order. I've rejected cases for stock rebuilds and used old cases for performance motors - you just need to know what to look for. If you are good at building motors then go for the 2110. It doesn't go together first second or third try but its a very satisfying motor to drive. I love mine. While I could have easily built a larger motor since I've done it before I saw no reason to since I'm not racing it.
71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI
sb001
sb001 is offline
PostPosted: Fri Jul 11, 2014 11:42 pm    Post subject: Reply with quote
I DID look at the Gene Berg link you provided, which is why I was asking- cause I didn't see ANYTHING in there about how to upgrade an existing engine- just musings about how to NEVER line bore a case (always buy a new one), or how any crack in #3 cylinder was because of owner neglect (buy a new one), or rambling about how he rejected 80% or whatever of cases that came his way (buy HIS new one.) At least he praised my AS21 case as being the best ever made.
Mattegan already answered my question anyway.
I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Bosch 113905205AE autostick distributor
Volks Wagen
Volks Wagen is offline
PostPosted: Sat Jul 12, 2014 5:27 pm    Post subject: Reply with quote
Lots from GB reads like advertising.
1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile.
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Sun Jul 13, 2014 4:45 am    Post subject: Reply with quote
Those of us who remember having talked to him would differ with your opinion, he would dispense advise and make recommendations even if it meant not making a sale. So the exact opposite was true as he could have been much more successful skipping processes and selling shitty parts. This is difficult for the hobbyists and those with little or no formal mechanical/engineering training to understand. One thing is true he was all about quality saying that the parts he made had to meet or exceed stock specs but its human nature to gravitate towards that which seems cheap and easy. After having nearly forty years myself into working on these cars one thing never changes that's the attitude of some of the younger ones coming along thinking they will reinvent the wheel, that's human nature too. It's been said that experience is the best teacher and so I'll not stand in the way Very Happy good luck to you all.
Jim-
Volks Wagen
PostPosted: Sun Jul 13, 2014 10:56 am    Post subject: Reply with quote
Jim-
It's good of you to defend him Jim, but he's not coming under any attack from me. I've no personal opinion of the man as I've never met him. I should have said that "Lots from GB site reads like advertising", as that's all I can access with his name on it. I've heard of his technical papers but not found them. I'd be interested in reading those.
db69
db69 is offline
PostPosted: Wed Jul 16, 2014 10:32 pm    Post subject: Reply with quote
[quote="sb001"]
db69 wrote:
If you have not read aircooled.net's tech articles this is a good starting point. Lots of your questions are answered there or at least it gives you options to think about. Great resource that I haven't been able to find anywhere else.
This is exactly what he is saying he DOESN'T need more of. Rolling Eyes
Why is it so difficult for those of you in the know about rebuilding engines to answer his straightforward questions????? Just TELL him what he needs![
Maybe if you actually read his questions and were familiar with ACN ' tech articles you would see all of his questions were answered there by knowledgable mechanics who have been in the business for years not shade tree mechanics arguing over stock vs aftermarket vs performace etc. etc. blah blah blah. The guy asked for help ACN's site is loaded with tons of RELIABLE info. I hope this helps him and maybe you could read the tech articles yourself in case you have to fix a flat or something.
db69
db69 is offline
PostPosted: Wed Jul 16, 2014 10:58 pm    Post subject: Reply with quote
mattegan wrote:
I'm getting most of my info from the Aircooled.net articles (the one about building performance engines) and also read the part about performance in the back of the Muir guide.
GArBA, holy cow! Thanks for linking that. I would have never thought. I'll make double sure. I may just take Danwvw's advice and just go at it with a Dremel and wire brush, possibly letting a shop put it in their cleaner.
Danwvw, I didn't notice that crack except in the photo, I'll take another look.
I'll measure the journal widths tonight.
Okay, I hadn't even considered anything about the heater boxes. I guess I'll have to figure that out. I definitely want to keep heat to use the thing in the winters here. Are you saying there's some relation between the cam/rockers and the heater boxes?
What's wrong with running ratio rockers with the stock cam?
edit: Just curious, what's the market for used engine parts? I know this is going to be expensive, but is there any chance that anybody wants to buy a crank and rods and case that are still in good condition?
I see you are in GA there is a shop there called Pro Flow performance he has done case machining for me (stock case 84x94 2332) and is a knowledgable Vw mechanic, machinist and VW drag racer. I think you would benefit from giving him a call his shop is in Hiram, GA. Let him look at your case he can tell you what you can build with it and do the machine work for you they are good people. There are LOTS of opinions on the forums they are just that continue your search for facts from reliable sources and you can build a fun motor. I have been and still am in the same boat you are and have found everyone has an opinion on everything and there are 3 answers to every question. Good luck
Page 3 of 3
