zandr Samba Member
Joined: April 07, 2014 Posts: 28 Location: Berkeley, CA
Posted: Sun Aug 24, 2014 10:40 am Post subject: |
It's difficult to tell what's going on from your schematic since you're inconsistent about showing grounds and negative leads, but...
The dual relays really bother me. If you're going to use two relays, I suppose it's safer to wire the coils in series, because then you'll be protected against one possible failure mode. But it seems more likely that the high current side will fail (even partially - high contact resistance) and the other relay will end up carrying all the load. Since you'd then have a 60A relay in a circuit fused at 100A, you could have a problem.
If you're going to insist on two relays, rather than a single properly sized relay, at least fuse them independently.
If your only expectation of the solar panel is to keep the battery topped up while storing the vehicle, you might be OK. 30W isn't going to extend the run time of your system while camping at all.
I admire the ingenuity of using the solar controller's low-voltage disconnect to shed load from the house system. The inverter isn't connected that way, and might well have non-trivial current draw even when "off". Something to keep in mind. If you're going with giant relays already, I'd use one there. _________________ '87 EJ22 Full Westy "Hamish" |
RBEmerson Samba Member
Joined: November 05, 2011 Posts: 2221 Location: SE PA
Posted: Sun Aug 24, 2014 7:39 pm Post subject: |
Yes, you need all three 100A fuses. Although I'd look at the loads again; 100A seems a little high.
You need to guard your power sources with fuses, as you did.
By contrast, VW doesn't guard any of the three wires to the main battery. If the battery-starter lead wears through, bye-bye Westy. And probably ditto for the two leads to the fuse panel and aux. battery.
So, yes, ya done good to think about the fuses needed. Just tune their sizing a bit.
Something to research: if you're going to get serious about using solar modules, look into MPPT controllers (MPPT is a technology, not a brand).
[soap box mode] I am skeptical of many of the solar module projects seen here. Coming from an environment (marine cruising) where 200W modules are now pretty much the bare minimum, and 400W module sets are common, even 80W strikes me as wishful thinking.
Basic rules for any module (regardless of size): 1) keep it square to the sun as long as possible but certainly during local mid-day, 2) keep it cool, 3) keep it clean, 4) there's MPPT and there's a waste of money and effort.
The best power concentration is always when the panel is perpendicular to the sun's rays. Anything less and the same power is spread over a larger area or, inverting, less power on a fixed area. When the sun is at its highest, the light passes through less of the atmosphere than at sunrise or sunset. The shorter path through the air means less power is lost. The best period for solar power is around local noon on the summer solstice (sun is at its highest, the day is the longest), the worst is the winter solstice (lowest sun at local noon, shortest day).
The cooler a module is, the more efficient it is. Sunlight heats up panels. Cooler ambient air (or at least cooler air circulating under a module) helps. This is just one of those contradictions in life: the sunlight you want heats the module the way you don't want.
A dirty module is an inefficient module. Given even a good module is only about 18% efficient(!), dirt on the module isn't going to help raise that number. It will drop the number. A lot.
MPPT (maximum power point tracking) is an electrical slight of hand developed to force a module to operate in its electrical sweet spot. (For those who want to catch up on their sleep, Google on MPPT and how the module is tricked into working at the knee of its power curve. If that doesn't put out the lights, call an anesthesiologist.) What matters is not using an MPPT (technology) controller with modules of any real size is literally wasting power and money. An MPPT controller won't beat the laws of thermodynamics, but it'll find a lot more power in your solar module system than anything else.
Finally, if you can fold, bend, or roll up your fave module, please do so forthwith. It'll take up less space in the recycling bin where it belongs. Honest, of all the solar modules, thin-film modules are, by far, the least efficient. If you can't go for monocrystalline panels or polycrystalline panels, save your money for them and, in the mean time, work on optimizing your existing power system. Money spent on thin-film modules is money wasted. Honest. They look cool and the flexible panel seems neat but... see item 1) above. If the module isn't flat and square to the sun, you're not getting all you can from your module investment. And no thin-film module can flex and remain fully square to the sun. [/soap box mode] _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
whynotvw Samba Member
Posted: Sun Aug 24, 2014 8:31 pm Post subject: |
| RBEmerson wrote: |
[soap box mode] even 80W strikes me as wishful thinking.
[/soap box mode] |
Its not like we have a unlimited space on the roof like a regular RV or Boat. Lets be real we have small space to work with and even smaller if you carry cargo or surfboards etc.... Yea it would be nice to have 400 watts or 200 watts, but really space on the roof is very limited. By the way my 80watts work just fine with me.  |
kamzcab86 Samba Moderator
Posted: Sun Aug 24, 2014 9:05 pm Post subject: |
| RBEmerson wrote: |
| I am skeptical of many of the solar module projects seen here. Coming from an environment (marine cruising) where 200W modules are now pretty much the bare minimum, and 400W module sets are common, even 80W strikes me as wishful thinking. |
Solar requirements all depend on the individual set-ups. A bare-bones 16' pontoon boat is vastly different from a 50' yacht. Likewise, my minimal Vanagon components (LED light strips, eventual portable fridge, Dometic fridge fan, and that's it) do not require the same solar needs as John Doe's Vanagon in which he uses a fridge/freezer, stereo, TV, computer, microwave, inverter, lights, and so forth. My set-up could get by with 80W, while Mr. Doe's set-up might need 200W or more. Furthermore, there are numerous 100W set-ups, permanently mounted and portable, displayed on The Samba that are working just dandy.
So, you really need to sit down and do some math before spending money on a solar system, including any potential expansion components... IMHO. For some, 50W will be enough, for others 50W will not even come close.  _________________ 1986 Cabriolet: www.Cabby-Info.com
2016 Golf GTI S
Posted: Mon Aug 25, 2014 6:03 am Post subject: |
| whynotvw wrote: |
| RBEmerson wrote: |
[/soap box mode] |
[soapbox mode]The laws of physics can't be ignored. If the demand exceeds the power availability, an undersized module will never, ever get the job done. If the job is full charging. If the job is only to slow down the rate of discharge (sooner or later the engine has to be run), then a small panel is OK, but IMHO why bother. "Do or do not, there is no try."
The first thing that has to be done is a full assessment of the amp-hours to be consumed. That means every little LED, motor (e.g., fridge fan as well as cabin fans), laptop charging, phone charging, etc., etc. has to be accounted for. How much does each device draw and how long is it likely to be used during a 24 hour day. If the module can't supply that same amount (preferably at least a little more) as the demand, the system is undersized. There is no way around that.
The choices are then to use less power - leave the TV home, for example - or get more charging. If 100 - 150 watts does the job, fine. In my experience, even with careful use - don't leave something drawing power if it's not really in use - the overall demand is often more than expected.
And charging is less than expected. Trees cast shadows. Clouds cast shadows. Most modules stop producing if a surprisingly small area of the module is shaded (this is the result of internal wiring in the module and isn't user-adjustable). Winter camping adds its loads (shorter days, more lights) and the sun isn't delivering as much energy to the module as a summer day. In summer, the module is heated up more, dropping output. It doesn't drop precipitously, of course, but there is some loss.
It's certainly possible to tweak how the module is used. Put it on a stand and move it around to favor the best illumination, for example. But remember voltage drop on the intervening wiring. Get that wrong and the benefit from a movable panel may be eaten up by wiring losses.
It's possible to cobble something together that may or may not meet most needs, but getting it really right and up to "off the grid" standards just isn't as simple as many folks want it to be. [/soap box mode] _________________ Lord, give me coffee to change the things I can change, and wine to accept the things I can't change. |
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 10480 Location: Orbiting San Diego
Posted: Mon Aug 25, 2014 6:27 am Post subject: |
Most Westy people are using solar to supplement their needs, not to go completely off-grid for any extended period. The few people wanting to stay completely off-grid need more capacity, naturally.
But no matter how much of the Westy roof you cover with solar panels and no matter how much you fill the storage areas with heavy batteries there can still be circumstances under which you will not have enough of either. So the real issue is planning and balance. You have to balance the usefulness of having MORE of something with the downsides of carrying more of it. And then plan to live under the limitations that will always exist.
Mark |
Posted: Mon Aug 25, 2014 11:54 am Post subject: |
| RBEmerson wrote: |
| whynotvw wrote: |
| RBEmerson wrote: |
[/soap box mode] |
It's possible to cobble something together that may or may not meet most needs, but getting it really right and up to "off the grid" standards just isn't as simple as many folks want it to be. [/soap box mode] |
blah blah blah. please get to the point, i feel like i'm in some physics class
I've been using my 80 watt for 5 years and its been doing just fine. And if thats not enough I carry a honda eu1000i inverter which can top off all my batteries in couple hours with the Iota charger. For the most part my solar works just fine. |
sunkid Samba Member
Joined: March 31, 2008 Posts: 31 Location: San Diego, CA
Posted: Sat Oct 29, 2016 2:57 pm Post subject: Re: YAVAWD - Yet Another Vanagon AUX Wiring Diagram - Fuses? |
Pardon me for reviving an old thread, even if it is my own...
Finally getting to putting it all back together here and am running into many mysteries of wiring done by previous owners. I was planning to hook my AUX battery up as described here, for example, but that would only power the cigarette lighter. Interior lights and clock were off with my main battery disconnected. If I hook up the AUX directly to an interior light, I have power on fuses 1-4 regardless of which I pull out.
Looking at the big B plug that should have pins 11 and 12 connected to cigarette lighter and clock/lights respectively, it is actually missing the #12 connector.
Any help or advice on how to best figure out what is going on here would be greatly appreciated. |
