longbdr58 Samba Member
Joined: August 21, 2012 Posts: 43 Location: Inland Empire
Posted: Sun Jul 13, 2014 5:36 pm Post subject: Rebuilt engine smoking after warming up |
So I finally was able to get my rebuilt type 4 dual carb engine installed with some help from a pretty good VW guy but after the engine warms up it starts to blow out white smoke out of the exhaust. The installer stated it was the old gas I had in the tank, he added a couple of gallons of fresh gas with a little octane booster to help but it is still smoking after warming up. I called the builder and he stated since my engine had bad rings and valves before the rebuild that it is possible there is oil burning off in the exhaust pipe and muffler and that's why it starts smoking after it warms up. I really have not been able to drive it much because its still on non op but the power seems to be weak as well, the guy who helped me install it said that was from the bad gas as well. Anybody experience any of these things? I know valves need to seat also but the smoke seems to be more than just that especially as it warms up.
Thank You |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 43001 Location: at the beach in Northern Wokistan
Posted: Sun Jul 13, 2014 5:42 pm Post subject: |
that is a hard one. Lets say that the engine was tipped on its side for awhile during the time it sat, and the muffler was on it, there could be oil in the exhaust - in which it does take time to burn it off. I doubt old gas would do that unless someone added diesel to the tank. New rings and reworked heads would not pump oil like that.
Turn it off and check the dipstick level. It is possible too much oil was added.
If you want to know for sure you may need to let it cool off and look at the spark plugs to see if one or more is wet with oil. Then you can start wondering why. Do document that you spoke with the engine builder about it and they said to run it as it is and see if it burns off. |
Posted: Sun Jul 13, 2014 5:54 pm Post subject: |
I know the engine did not set on its side. I will check the oil level and pull the plugs to see if they are wet but will need to wait until morning. The van has been in my garage the whole time so I'm pretty sure diesel was not poured in the tank. The gas was about a year old though, I guess I could drain it and start with 100% fresh gas, the fuel filter is new and looks very clean.
Thank You
babysnakes Samba Member
Posted: Sun Jul 13, 2014 5:55 pm Post subject: |
| I just did a ring job on my 1600. I honed the cylinders and used new rings. I am no pro at this. The engine smoked for about 300 miles, then the rings seated and the smoke went away. I went through the recommended ring seating procedure. I am also running Brad Penn oil. Maybe my honing skill are not up to snuff and the oil may be to slippery for good ring break in. No more smoke. |
Posted: Sun Jul 13, 2014 5:59 pm Post subject: |
| Good to know, its been so long since I have a had an air cooled VW engine rebuilt I don't know what to expect |
Posted: Sun Jul 13, 2014 8:46 pm Post subject: |
How is your brake fluid level at this point? Brake fluid will cause white smoke verses the blue/white smoke of burning oil. Try removing the vacuum line for the brake booster and plugging off the nipple and see if that makes it go away.
Water will also make for white smoke, but this is usually seen during cold or very humid weather and when the engine is still cold. |
Posted: Sun Jul 13, 2014 10:30 pm Post subject: |
| I will check that out, thanks |
Potsie Samba Member
Posted: Thu Aug 07, 2014 3:15 pm Post subject: |
| So... Did you figure it out? I'm about 150 miles into a new set of pistons and cylinders (on a Beetle though). Mine is smoking while it idles, with a big puff as I take off. I'm trying to figure out if the rings need to seat or if I have other problems. Has yours stopped smoking yet? |
Posted: Thu Aug 07, 2014 3:53 pm Post subject: New Engine Smoking After Warm Up |
Well I ruled out old gas because I ran until it died, I know there was some old stuff still in there but I added 5 gallons of high octane, it seems to be running a little better. I know it's not brake fluid because the line was bone dry at both ends, I was a little low on fluid but I just went through the front brakes and did not refill. The smoke seems like it has calmed down a bit though, I cant really drive it right now because it has been on non op and I haven't been to the DMV yet. I have about one hour on the engine driving in the neighborhood and letting it idle at about 2000 rpm for about 5 to 10 minutes at a time. As soon as I get it registered I will take to the builder so he can fine tune it, I think I will readjust the valves myself before taking to him, I would hate to drive the ten miles with the valves too tight. It will be a few weeks though but I will update this forum.
Thanks, Mike |
Potsie Samba Member
Posted: Thu Aug 07, 2014 4:05 pm Post subject: |
| Thanks for the update, good luck! |
Posted: Mon Sep 01, 2014 11:57 pm Post subject: |
So last week I decided to check the valves, 1 and 2 were good, when I got to 3 and 4 I found the issues, # 4 intake adjuster had loosened up and the adjuster screw was really loose. I adjusted and closed everything back up and it seemed to have solved all the smoking and low power issues. I have not had a chance to get it over to the shop for a good tune and check up, I'm hoping there is no damage, it seems to run and sound great.
Thanks everyone, Mike |
Potsie Samba Member
Posted: Tue Sep 02, 2014 7:32 am Post subject: |
Thanks for updating. I hope that solves your problem. My smoking problem (new p/c set) has pretty much cleared up too. It now has about 400 miles, including one pretty long drive that had at least 40 minutes between 60-65mph. I have not seen any more smoke at stop lights. It smoked one time idling in the driveway, but that time it took 5-10 min before it started. _________________ Knows just enough to be dangerous. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17790 Location: San Diego, California
Posted: Tue Sep 02, 2014 7:53 am Post subject: |
Hi there,
I'm just curious how your 1976 bus passes a smog test with dual carbs? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
merlinj79 Samba Member
Posted: Tue Sep 02, 2014 8:41 am Post subject: |
| babysnakes wrote: |
Brad Penn is good stuff...maybe too good for break in. I would have used single weight dino oil for break in. I'd expect the rings rings to seat in less than 100 miles...at least enough to not smoke. _________________ Rick
"Pumpkin II"
Stock 2L FI '77 Westy
CA Smog Stuff |
Posted: Tue Sep 02, 2014 10:43 am Post subject: |
I bought a large box of FI parts that I'm going to have looked at to see what else I need to put it back. Car Craft in Riverside CA said they could put it back to FI if I ever wanted to but at what cost?
I will update if that happens.
Posted: Tue Sep 02, 2014 10:58 am Post subject: |
| longbdr58 wrote: |
As far as smog goes.......friend of friend is suppose to take care of it. I bought a large box of FI parts that I'm going to have looked at to see what else I need to put it back. Car Craft in Riverside CA said they could put it back to FI if I ever wanted to but at what cost?
I will update if that happens. |
It's expensive believe me. I have a long list of parts I had to buy. Some of the no longer available stuff can be costly. I spent over $250 just on 3 or 4 hoses. The computer was $210. I paid $145 just for a heat shield. The project took me roughly 3 months and I went from this
to this
to this
I recommend putting together a comprehensive list of stuff you'll need and start aquiring the parts early. Don't assume that these 40 year old fuel injection components will work either. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Tue Sep 02, 2014 12:26 pm Post subject: |
| Yes I figured $1000-1500. If my friend of a friend comes through on the smog I will have two years to gather parts. I was going to try and find a complete FI engine and or late bus that has everything I need and sell of the rest. Whatever I can score. |
Posted: Tue Sep 02, 2014 12:54 pm Post subject: |
Going into the project that's what I figured but I was way off. First, you need to know if it's a FED or Calif. bus. You can get that from the VIN. Have you ever smogged this bus before or is it new to you? What year is it again? Keep in mind that I'm no expert. I relied on several people to guide me. It took me hours and hours of planning and researching parts plus I had to know the right people. I bought an EGR valve for $145 but then had to spend $43 on 5 gaskets that are NLA and I was real lucky to know the right guy who I got them from. The PCV valve is NLA and one guy told me he had to pay $400 to get one from Croatia. I got lucky and a guy GAVE me one. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Tue Sep 02, 2014 12:56 pm Post subject: |
You have already said too much. If I worked for BAR and got a hold of one of your Lic. numbers or VIN's from pix. Your friend of a friend would loose his license and possibly be out of a job.
Think about it? |
Posted: Tue Sep 02, 2014 2:23 pm Post subject: |
| Yes I have owned since 93 and got it smog tested when I bought it with all the FI on it. I think around 96 I changed it to dual carbs, I only changed it because I could not find a shop that could fix the problems I was having with it. I had to get it tested a few times this way and they would just pass it, not a big deal back then. I put in non op status in 2000 and was waiting for the 30 year smog year (2006) to roll around but Arnold caved and changed the law to 76 and newer. |
