denwood Samba Member
Joined: July 29, 2012 Posts: 1047 Location: Thunder Bay, Ontario, Canada
Posted: Sat Oct 12, 2013 5:17 pm Post subject: How to bleed / test your Vanagon coolant system-$2 solution. |
Here is an overview of a very simple way to bleed air from the vanagon rad that does not require a bong, raising your van front or running the van. I still fill the system and run the van to warm it up a bit. This method also tests the entire system for leaks, and will provide a pressure test for your rad cap as well. Hope you find it useful. (this post was my first done entirely from an iphone: onboard camera for pics, Phonto app for adding text, then uploaded from the phone to Samba gallery..cool!)
Cheers, Dennis.
Edit/Note: The system pressure is rated at 15 psi; exceeding 15 psi during a pressure test should only be done if, like me, you're looking to stress the system a bit.
_________________ Cheers,
Dennis Wood
The Grape
bluebus86 Banned
Posted: Sat Oct 12, 2013 5:28 pm Post subject: |
nice idea, however I'd be more comfortable with a pressure lower than 20 psi, a pressure exceeds the pressure cap pressure and could cause a rupture on some cooling component. but then again if it survives 20 spi, the system really is up to snuff!
The pressure gage shown is not really accurate at 20 psi, since your at the bottom 1/8th of the gages range. Ideally you should be using a lower pressure gage for best accuracy, a 40 psi max gauge would be a better choice if your targeting for 20 psi.
most gages have the best accuracy at mid range.
I like the idea, but suggest a gage better suited for low pressure. very nice however. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12438 Location: Santa Cruz, CA
Posted: Sat Oct 12, 2013 5:36 pm Post subject: |
I have been doing that with my motive brake bleeder as the pressure vessel and gauge for a while now and it works nicely. 1 fitting and a length of hose that I had laying around and it was done.
Even bleeding the entire system with a new radiator becomes a simple task. I don't pressurize the system quite as high as you though.
Nice right up. |
Posted: Sat Oct 12, 2013 5:42 pm Post subject: |
20 psi is only 5 over the cap spec...so yep, if it blows up at 20, better in your garage than on the road  _________________ Cheers,
Dennis Wood
The Grape |
Posted: Sat Oct 12, 2013 7:48 pm Post subject: |
Blue, I actually set pressure using my regulator (fancy pants dual compressor system), the small one pictured is just there for illustrative purposes. I use it when painting to evaluate pressure drop on the line. _________________ Cheers,
Dennis Wood
The Grape |
noganav Samba Member
Joined: January 06, 2006 Posts: 1236 Location: San Diego CA
Posted: Sat Oct 12, 2013 8:03 pm Post subject: |
| I went even simpler. I installed a tire valve in the cap of the coolant overflow reservoir and use a bike pump with pressure indicator. Same idea, and it works great! |
jimeg Samba Member
Posted: Sat Oct 12, 2013 8:48 pm Post subject: |
And by running the van, the thermostat is open? Would this system work if the thermostat was closed? _________________ 1986 Root Beer Syncro Tin Top....so many plans.
Here: http://www.thesamba.com/vw/forum/viewtopic.php?t=578490
Posted: Sat Oct 12, 2013 9:26 pm Post subject: |
Nog, that's a good idea
Jimeg, I've always filled the system, then started the van (cap off) to allow the water pump to circulate the coolant. I've never worried about getting the engine hot, so likely the thermostat is not open. It would make sense to warm the engine given a WBX...keep in mind my setup is an i4. _________________ Cheers,
Dennis Wood
The Grape |
jimeg Samba Member
Posted: Sat Oct 12, 2013 9:28 pm Post subject: |
| denwood wrote: |
Jimeg, I've always filled the system, then started the van (cap off) to allow the water pump to circulate the coolant. I've never worried about getting the engine hot, so likely the thermostat is not open. It would make sense to warm the engine given a WBX...keep in mind my setup is an i4. |
Ok. Mine would apply to an I4 diesel, so fairly similar cooling components, yes? _________________ 1986 Root Beer Syncro Tin Top....so many plans.
Here: http://www.thesamba.com/vw/forum/viewtopic.php?t=578490 |
Posted: Sat Oct 12, 2013 9:35 pm Post subject: |
Yep, same. It's not a bad idea after your first hard drive to idle the van with hot coolant and check for air at the rad..any there will "burp" under pressure. _________________ Cheers,
Dennis Wood
The Grape |
Merian Samba Member
Posted: Thu Sep 18, 2014 6:30 pm Post subject: |
| What is a KEP bleed valve? |
Posted: Thu Sep 18, 2014 7:01 pm Post subject: |
Kennedy engineering ( http://www.kennedyenginc.com ) supplies these, or you can make your own. They make bleeding very easy . Google "radiator petcock". Instead of risking stripping the bolt threads, you just turn the handle, bleed and close. I purchased this at the same time as the adapter plate for my 50 degree i4 conversion.
I should mention that if you don't have an air compressor, just use a Schrader valve in place of the air fitting clamped to the 5/16" hose. A bike pump then is all that is needed to both pressure test and bleed. Nog evidently just installed this by drilling a hole, installed right into his expansion tank and left it there.
http://www.polyperformance.com/shop/Sway-A-Way-Shock-Schrader-Valves-p-16945.html
Dennis Wood
The Grape |
Posted: Thu Sep 18, 2014 9:55 pm Post subject: |
I drilled a hole in a spare cap for the overflow tank and installed a schrader tire valve to it. I just throw on the modified cap when I need to bleed the coolant.
In effect we're doing exactly the same thing, and mine also cost about $2  |
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1342 Location: Snoqualmie (WA)
Posted: Thu Sep 18, 2014 10:15 pm Post subject: |
i smell a business opportunity of modified tire-valve caps, sold with pressure gauge as a set, for $20 or something.
For all us mechanically declined folks  _________________ '91 Double Door Transporter |
Posted: Thu Sep 18, 2014 10:28 pm Post subject: |
You're right! I shouldn't have told and turned a quick buck. The Prospect IL business model.  |
seventyfo Samba Member
Joined: February 13, 2007 Posts: 916 Location: Ocoee FL
Posted: Thu Sep 18, 2014 10:42 pm Post subject: |
I've been bleeding with a $10 ACE 1 gallon garden sprayer minus the sprayer. Fill with coolant, attach to overflow port on the cap, open bleeder on radiator. A few pumps on the handle and it's all over in a couple minutes. Usually I use an old cap though. _________________ 85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
"I don't know you well enough to care about your comments". Watkins Cravey |
Posted: Thu Sep 18, 2014 10:45 pm Post subject: |
It works good on brakes and clutch too. _________________ 85 Vanagon GL Westy GW 2.2 (Rebuilt by YT)
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Thu Sep 18, 2014 11:09 pm Post subject: |
I have used Schrader valves on all sorts of projects over the years. I usually use the type made for tubeless tires when installing them in a plastic tank of any sort. This helps to make a better and longer lasting seal, since the threads on a standard screw in valve won't have much to bite onto:
_________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
Terry Kay Banned
Posted: Thu Sep 18, 2014 11:49 pm Post subject: |
| noganav wrote: |
I don't know where this is--can you give me a hint?  _________________ T.K. |
Posted: Fri Sep 19, 2014 6:32 am Post subject: |
Jay, that valve looks perfect for a sacrificial cap install.
It won't be the 2$ solution as a retail product . That said, a cap/valve combination used for bleeding is something vendors would likely sell. Anyone with an air compressor likely already has the bits in hand to do the air/fitting hose setup.
Using 20 psi accomplishes 3 things:
1. Tests for leaks, particularly when you have the original coolant pipe ends up from.
2. Allows you to bleed the system in one step.
3. Checks the cap as it should bleed off 5 psi or so when air supply is disconnected. _________________ Cheers,
Dennis Wood
The Grape |
