Reverse light switch
2000typer
2000typer is offline
PostPosted: Thu Sep 25, 2014 11:52 pm    Post subject: Reverse light switch Reply with quote
I have a 1966 bug but it doesn't have the original tranny(I'm not sure what year it is).
It has a plug on the nose cone to install a back up light switch. Is that all that's necessary to get reverse lights or is there something internal in the tranny that's required?
shortride
shortride is offline
PostPosted: Fri Sep 26, 2014 12:43 am    Post subject: Reply with quote
I would like to install backup lights on my '66 as well.
Pearl White 1966 Sedan
Retired US Army - 21 years 11B40, 173rd Airborne Brig. - Vietnam Combat Veteran
[email protected]
ptjjb@yahoo.com is offline
PostPosted: Fri Sep 26, 2014 12:44 am    Post subject: Reply with quote
No, just stick a switch on there. The hockey stick has a nub on it that swings over and trips that switch.
Merlin
Merlin is offline
PostPosted: Fri Sep 26, 2014 2:02 am    Post subject: Reply with quote
Good work on your pan. Keep it up. Smile
iowegian wrote:
People who are allowed to have signature lines annoy me.
61SNRF
61SNRF is offline
PostPosted: Fri Sep 26, 2014 4:48 am    Post subject: Reply with quote
A stock/original '66 trans doesn't have the threaded hole for the switch, that started in US '67 models.
If your trans is original and never updated, new replacement nose cones have the hole for a switch and are a direct bolt on...
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-113-301-205-F
-Bruce
An ounce of prevention is worth a pound of cure.
pwmcguire
pwmcguire is offline
PostPosted: Fri Sep 26, 2014 5:13 am    Post subject: Reply with quote
I just installed a rebuilt 67 tranny in my 66 with a reverse light switch and I added reverse lights. All you have to do is add a switch and wire it up
60ragtop
Bonneville Belt Bitch
60ragtop is offline
PostPosted: Fri Sep 26, 2014 5:27 am    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/album_page.php?pic_id=1104510
shortride check into this type for the speedo head or this type that hooks up under the plate to access the shift coupler
Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote:
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote:
maybe he just snapped cause his car sucked Wink
shortride
PostPosted: Fri Sep 26, 2014 5:42 am    Post subject: Reply with quote
shortride check into this type for the speedo head or this type that hooks up under the plate to access the shift coupler.
I appreciate the information.
2000typer
PostPosted: Fri Sep 26, 2014 7:18 am    Post subject: Reply with quote
Thank you very much. Back up lights will be nice.
Bruce
Bruce is offline
PostPosted: Fri Sep 26, 2014 8:46 pm    Post subject: Re: Reverse light switch Reply with quote
Make sure you use the thick aluminum sealing washer that's with the plug. If you don't use this washer the switch will be too close to the R shift rod and it will prevent you from engaging reverse.
Note: it is the Reverse shift rod that actuates the switch. Nothing to do with the hockey stick.
2000typer
PostPosted: Sat Sep 27, 2014 12:48 am    Post subject: Reply with quote
I will, thank you Bruce
kanexavier
kanexavier is offline
PostPosted: Sat Sep 12, 2015 8:32 am    Post subject: reverse light in pre-67 Reply with quote
Hello; I bought a vw dune buggy that has parts from various years and trying to track down parts. I have a swing axle with no back up switch. My question is can I install a back up switch by just changing the nose cone and wiring it up or do i have to change any internal parts in the tranny??
61SNRF
61SNRF is offline
PostPosted: Sat Sep 12, 2015 5:26 pm    Post subject: Re: reverse light in pre-67 Reply with quote
kanexavier wrote:
Hello;...My question is can I install a back up switch by just changing the nose cone and wiring it up or do i have to change any internal parts in the tranny??
That's correct, only the nose cone is different with no other internal parts to change.
It's actually the flat end of the reverse shift rail that acts on the tip of the switch, so no worries with the hockey stick either (Beetle hockey sticks are all the same from '61-'79 anyway).
Bruce also gave a good tip above, be sure to use the good thick sealing washer or it could inhibit full reverse gear engagement Wink
-Bruce
grandpa pete
grandpa pete is offline
PostPosted: Mon Sep 14, 2015 8:39 am    Post subject: Reply with quote
Don't be afraid of the wiring ;
pull 12 volts off the coil ( is only on when the key is on ) ; run through the tranny switch , to a light on the rear ;grounded...
63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Mon Sep 14, 2015 8:49 am    Post subject: Reply with quote
Add an inline fuse to the coil circuit as well.
IMO .. protect the entire circuit..
I never understood why VW never fused the IGN 15/54 "ON" voltage to the coil circuit from the Ign switch..
Lots of cooked harnesses over the years because of that penny pinch...
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
Eric&Barb
Eric&Barb is offline
PostPosted: Mon Sep 14, 2015 11:00 am    Post subject: Reply with quote
Because, not if, but when the fuse goes bad you have the VW stall out in possibly a bad place to do so.
http://www.thesamba.com/vw/forum/viewtopic.php?t=341025&highlight=reverse+switch
In Stereo, Where Available!
VOLKSWAGNUT
PostPosted: Mon Sep 14, 2015 11:22 am    Post subject: Reply with quote
Yeah.. I guess a melted harness and possible fire is a bit safer.. Rolling Eyes
Fuses open when a circuit is overloaded or shorted.. they just don't go bad..
If that bad fuse pop stall theory were true... all modern cars today are just ticking stall bombs..
aka Ken {o\!/o}
Eric&Barb
PostPosted: Mon Sep 14, 2015 11:27 am    Post subject: Reply with quote
Well have over 300,000 miles and 30 + years of driving old ACVWs and never have had a wiring problem with stock wiring. Of course keep the wiring in good shape, especially in the engine compartment where wiring gets brittle insulation. With anything (like fuel lines), preventive maintenance is a must.
61SNRF
61SNRF is offline
PostPosted: Mon Sep 14, 2015 6:24 pm    Post subject: Reply with quote
VOLKSWAGNUT wrote:
...I never understood why VW never fused the IGN 15/54 "ON" voltage to the coil circuit from the Ign switch..
One thing to think about, adding a fuse to the circuit would add 6 more man made connections to potentially break down from oxidation or looseness resulting in a Voltage drop:
1-Terminal crimp on Black wire from fuse panel +15
2-Push on terminal connection to fuse holder in
3-Fuse holder to fuse, input side
4-Fuse output side to fuse holder out
5-Push on terminal to fuse holder
6-Terminal crimp on Black wire to coil +15
Old style ceramic fuses also get hot and cold thus expand and contract, eventually breaking down and open circuiting where they are bent.
I've fixed more than one reverse lights inoperative issue by simply replacing a fatigued fuse and cleaning the holder.
A soldered in fusible link may be more reliable in the long run, say limited to about 20 Amps.
-Bruce
EVfun Premium Member
EVfun is offline
PostPosted: Mon Sep 14, 2015 7:25 pm    Post subject: Reply with quote
I fuse the ignition coil wire up front. VW fused the ignition wire before running it to the reverse light switch for cars equipped with one. I think lack of a fuse to the front parking lights under the sloped covers was an even worse idea than the ignition coil decision. I either move that to the tail light fuse and have them stay on with the headlights, or I fuse that wire.
Wildthings wrote:
