Sea Blue Bus Blues ~my 67 preservation~
Page: 1, 2, 3  Next
BusJunky
BusJunky is offline
PostPosted: Fri Sep 26, 2014 10:45 pm    Post subject: Sea Blue Bus Blues ~my 67 preservation~ Reply with quote
Hello all! Well i picked up this 1967 OG paint bus last weekend over in New York. I was pretty excited because this is my first split window project that's 100% original paint. The frame and under carriage in general is in very good shape. There's a fair amount of rust in the usual areas. Doglegs, floors, rockers etc. It's not too bad... Other then the roof. Im sure debris from a near by tree collected on it and over the years of sitting, it rusted thru. Then the water started making it's way down the roof channels, mice had nested there and those nest, water logged, essentially rusting the entire inner roof line. To make matters worse, the water made it's way thru the inner A pillars and rusted them from the inside out. From the outside the paint looks great and the windshield pillars and lower windshield look amazing. Their inner structure however, is non-existent. My goal is the preserve and keep as much of the original paint as possible. I ordered all of the lower sheet steel replacement parts from WW and i've got that under control. Im going to need some guidance with the roof lol.
All loaded up and headed back to Ohio!
At home and ready to be cleaned up! The wheels were locked up and i had to chain it to a post and drag it back of the trailer. I trashed my come-along winching it up on the trailer. Luckily the back wheels had just cleared the dove tail when it broke.
That's ugly!
All cleaned out to assess the damage.
All washed up and buffed out. Theres plenty of life left in that old paint. Popped a few dents out while I was at it.
First things first. Although I have sheet steel coming, I also ordered everything needed to replace the brakes. I have enough stuff around to rebuild the engine. Im going to make it a running/driving project before anything else. I've learned in the past that diving right into rust repair is very, very time consuming and easy to get bogged down. I think being able to cruise around will be extra motivation to see the project thru. Like a lot of other VW enthusiast, I have several projects going on at once. Most can not be driven. It's quite frustrating lol. Im looking forward to sharing my experience preserving this old bus with you!
Leroux's Autowerks “like us on fb”
https://m.facebook.com/Lerouxs-Autowerks-942149562555768/?ref=bookmarks
flemcadiddlehopper
flemcadiddlehopper is offline
PostPosted: Fri Sep 26, 2014 11:08 pm    Post subject: Reply with quote
Wow, good find and a nice project.
Make sure you go over everything before you think about driving it. You don't want to start your project by making things worse.
Also, check your birthdate of your '67 to see if you have the newest split on the Samba (other thread).
Good lick, keep us posted on your progress.
Gordo.
Everybody Dies....Some Never Live.
Retrograde Garage. Vintage Aircooled, and others.
BusJunky
BusJunky is offline
PostPosted: Fri Sep 26, 2014 11:13 pm    Post subject: Reply with quote
Gordo.
she was born on 12/19/1966 Smile
kenshapiro2002
kenshapiro2002 is offline
PostPosted: Sat Sep 27, 2014 7:16 am    Post subject: Reply with quote
Ahh....got excited when I saw the birth date, but mine was exactly three months earlier:
Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx
BusJunky
BusJunky is offline
PostPosted: Sat Sep 27, 2014 7:52 am    Post subject: Reply with quote
I seen your post on other threads. I may part with my radio for other sea blue parts. Mine was a camper conversion from England. The mcode says its a 6 pop outs bus, but it had 4 stationary windows and 2 pop outs. All of my side glass was shot out, unfortunately. My drivers door had a dent and was pulled with the screw type dent puller. Im going to need a donor door.
kenshapiro2002
PostPosted: Sat Sep 27, 2014 1:59 pm    Post subject: Reply with quote
If your radio is a working AM/FM Sapphire VI, I'd be interested in it.
BusJunky
BusJunky is offline
PostPosted: Sat Sep 27, 2014 9:14 pm    Post subject: Reply with quote
I checked it out earlier today. Its a V not VI. not sure if it's functionable either. I did find these og touch up paint bottles under the seat compartment. There was a ton of stuff rotting in there. These finds are always cool. To bad the box is trashed.
BarryL Premium Member
BarryL is offline
PostPosted: Sun Sep 28, 2014 2:52 pm    Post subject: Reply with quote
I remember buying those at VW. What VW part are they resting on?
BusJunky
BusJunky is offline
PostPosted: Sun Sep 28, 2014 7:58 pm    Post subject: Reply with quote
That's just a old card table. It kinda has that VW material appearance. I have a handful of these cans of original paint. Most of them were never opened. A friend of mine was parts manager at a VW dealership for 35 years. He's collected about a thousand cans of the stuff over the years. If i were to dig up a can of sea blue and paint my newly welded in panels, could i still claim 100% og paint Smile
BusJunky
BusJunky is offline
PostPosted: Sun Jan 04, 2015 3:07 am    Post subject: Reply with quote
Time for an update. Got my front floor in.
Then my outer cargo floor.
Picked up a donor door with 5 layers of resparys on it. Then got it stripped back to the og sea blue and got it on the bus.
BusJunky
BusJunky is offline
PostPosted: Sun Jan 04, 2015 3:09 am    Post subject: Reply with quote
I used metal from the old door to patch up a big rust hole in the outer rocker. Trying to keep as much og paint as possible.
BusJunky
BusJunky is offline
PostPosted: Sun Jan 04, 2015 3:18 am    Post subject: Reply with quote
Got the engine all tore down and rebuild it with all new bearings and seals. Keeping it stock other then the exhaust.
BusJunky
BusJunky is offline
PostPosted: Sun Jan 04, 2015 3:26 am    Post subject: Reply with quote
There was a big hole from where someone mounted a antenna on the bus at some point. So i used a VW belt buckle that i had and used it as a patch for the hole. It gives the bus some more character, goes nice with the bullet holes along the side too!
Then I slapped a couple stickers on the back as well.
After that i got all my electrical sorted out and ive been driving the bus around my shop parking lot. Its such a blast even in first gear putting around with no brakes lol.
kenshapiro2002
PostPosted: Sun Jan 04, 2015 6:25 am    Post subject: Reply with quote
Nice progress. While you were putting in that metal, I found my Sapphire VI radio, and a lot of OG aero papyrus interior panels. I'll soon be selling some aero papyrus interior panels if you want some.
BusJunky
BusJunky is offline
PostPosted: Sun Jan 04, 2015 3:22 pm    Post subject: Reply with quote
I still have alot of mine, but i was going to do new panels with black carpet. Early bay westy interior in the back. This bus was just alittle too rusty to give it the full on restore. I appriciate the offer tho. I have the chrome interior panel strips and headliner bows still. If your interested let me know.
BusJunky
BusJunky is offline
PostPosted: Sun Jan 04, 2015 3:27 pm    Post subject: Reply with quote
I rebuilt the A pillar by hand. Turned out pretty good. Trying to save as much of that og paint as i can.
kenshapiro2002
PostPosted: Sun Jan 04, 2015 3:31 pm    Post subject: Reply with quote
Crustier ones than yours have been restored. Mine's just being "conserved", which is why I've been looking for decent OG interior panels. Looking forward to watching your progress.
BusJunky
BusJunky is offline
PostPosted: Sun Jan 04, 2015 3:49 pm    Post subject: Reply with quote
Then i started in on the lower dogleg. I had to cut off and replace the front half of my roof. I used what good steel was left to build it. Still german steel.. I started by making the outer part first.
Then i built the inner frame. Leaving enough material to tie it into the og dogleg.
Then i made the first little 1/4" step in part and the lower elbow. It would be really difficult to make the elbow and the top piece all in one part.
Then i made the top plate and tied it all in. Hand made dogleg in the raw.
kenshapiro2002
PostPosted: Sun Jan 04, 2015 3:52 pm    Post subject: Reply with quote
I had to do lower doglegs too, but used nice green KF parts. I bow to your skills... nice work.
BusJunky
BusJunky is offline
PostPosted: Sun Jan 04, 2015 4:16 pm    Post subject: Reply with quote
It looks kinda crappy because i ran out of wire in the middle of the night and finished tacking it with flux core. Plus the paint. They'll look great when their all cleaned up. Thank you tho!
Page: 1, 2, 3  Next
