blackdog1999  Samba Member
Joined: October 17, 2004 Posts: 1209 Location: Rancho Cordova, CA 95670
Posted: Tue Jan 28, 2014 3:34 pm Post subject: Dormobile Roofrack Clamps |
I have been asked by several people to post pics & specs on some Dormobile front roofrack clamps so they can make them. Here they are;
_________________ Home of the one true split Bus Motorhome |
ezcamper Samba Member
Joined: January 10, 2001 Posts: 915 Location: Atlantic Beach, FL
Posted: Tue Jan 28, 2014 5:32 pm Post subject: |
I came a set of dormobile clamps that are the same on top but the bottom where the clamp attaches to the rain gutter is more triangle shaped and does not have a back to crimp onto the gutter. _________________ I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
instagram is http://instagram.com/bullidriversteelworks |
Posted: Tue Jan 28, 2014 6:16 pm Post subject: |
If there is nothing to clamp it to the back side of the gutter how does it secure? Road vibration could, theoretically, work its way loose. _________________ Home of the one true split Bus Motorhome |
fig Samba Member
Joined: August 17, 2000 Posts: 1080 Location: 26.15°S, 28.2°E
Posted: Tue Jan 28, 2014 9:12 pm Post subject: |
Thanks for that blackdog; you've saved me having to take pics as I've also had the same requests.
The clamps on my 63 Martin Walter Dormobile rack don't have the gutter clamps and I have had one vibrate loose before. Luckily I heard it fall and stopped and found it on the road. Since then I've used cable ties to secure them to the rack legs. My clamps have a hole drilled through the lower part, which is perfect for the safety ties. The part that hooks under the gutter on mine is also triangular. _________________ fig
Kaapse Kombi Kult
"Don't make a fuss, just get on the bus ..." |
Posted: Sat Oct 25, 2014 10:19 pm Post subject: |
Just made this clamp out of stainless.
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1697 Location: Nebraska
Posted: Fri Jan 29, 2021 8:46 am Post subject: Re: Dormobile Roofrack Clamps |
How much is a pair of those repro clamps? |
Posted: Fri Jan 29, 2021 1:10 pm Post subject: Re: Dormobile Roofrack Clamps |
$75 each. They are no longer stainless though. _________________ I make HWE style roof racks, Jim-Dandy racks, SO-33 metal parts, Dormobile racks, HWE style ladders, engine crank start handles, Westy rack tags, Binz tags, Sundial badges, State of California tags, steering lock electrical covers and single / double cab gate latch friction blocks.
MrBusCo Samba Member
Joined: February 13, 2007 Posts: 1576 Location: stoughton, WI
Posted: Sun May 09, 2021 9:49 pm Post subject: Re: Dormobile Roofrack Clamps |
How do you tighten these? just wondering. _________________ Josh The Bus Guy formerly known as JOGR
BlazeCutUSA.com MrBusCo.com |
peecee69 Samba Member
Joined: January 27, 2005 Posts: 1592 Location: Annapolis, MD/Bloomfield Hills, MI
Posted: Mon May 10, 2021 5:54 am Post subject: Re: Dormobile Roofrack Clamps |
MrBusCo wrote: |
How do you tighten these? just wondering. |
In this picture:
The left side hooks to the roof rack and is stationary with a threaded rod inside it. The right side hooks to the rain gutter and has female threads and a ball & socket mechanism. The right side is rotated right to tighten and left to loosen. I had one of these racks a while back and those clamps work quite well. I wish they would have a provision for a cotter pin to lock them in place, but I checked them every time I fueled up to make sure they were still tight. I think I found them slightly loose a few times. _________________ 1973 Standard Beetle - running maintenance thread - https://www.thesamba.com/vw/forum/viewtopic.php?t=675712&highlight=
1966 Doublecab - Starting resto - https://www.thesamba.com/vw/forum/viewtopic.php?t=668518&highlight= |
Posted: Mon May 10, 2021 6:58 am Post subject: Re: Dormobile Roofrack Clamps |
And you just turn it in by hand and it’s tight enough? _________________ Josh The Bus Guy formerly known as JOGR
