Any tips for getting to the #2 spark plug?
ivwshane
ivwshane is offline
PostPosted: Thu Oct 30, 2014 3:55 pm    Post subject: Any tips for getting to the #2 spark plug? Reply with quote
This is my first time changing the plugs and I thought it was going to be a piece of cake. #1 plug was changed with no problems so I moves on to the #2 plug. I can't even see it! I stuck my finger under the tin and it feels like it's located more towards to front of the bus in relation to the hole in the tin.
Even if I'm able to get a plug socket on it and remove the plug I don't know how the hell I'm going to get the new plug back in and not mess up the threads.
So any advice?
77 type iv stock fi
I tried the search but it's not working right now nor did the google search for some reason.
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
dabble
dabble is offline
PostPosted: Thu Oct 30, 2014 3:57 pm    Post subject: Reply with quote
Patience. And a spark plug socket so the plug doesn't slip out.
1973 Westy with a 78 FI 2000cc
[url=http://www.vw-mplate.com/mplate2-9157.png]Click to view image[/URL]
ivwshane
ivwshane is offline
PostPosted: Thu Oct 30, 2014 4:04 pm    Post subject: Reply with quote
So it's just a matter of sticking the socket in and hoping for the best?
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
wihr
wihr is offline
PostPosted: Thu Oct 30, 2014 4:11 pm    Post subject: Reply with quote
Try various length extension if you are using a ratchet wrench. I cannot remember whether I use the 3 inch or 6 inch. And be sure you are using a spark plug socket.
WIHR
1970 Campmobile "Van Ordinaire"
2009 Lincoln Town Car "Behemoth"
1969 Lambretta 150 DL "Nina"
1962 Matchless G 12 CS 650cc
VDubTech
VDubTech is offline
PostPosted: Thu Oct 30, 2014 4:49 pm    Post subject: Reply with quote
You have to use an extension and remember the plug is at an angle. Shine a light into the hole in the tin first so you can get an idea of its orientation. #4 will be exactly the same way.
First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote:
a measurement of your rod would be extremely useful.
notchboy wrote:
my dad wasnt a belittling cock when he tought me how to wrench on cars.
One photo = good for reference.
10 photos = douchebaggery
ivwshane
ivwshane is offline
PostPosted: Thu Oct 30, 2014 4:59 pm    Post subject: Reply with quote
I managed to get it, no skill involved, pure luck;)
Thanks guys!
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
timvw7476
timvw7476 is offline
PostPosted: Thu Oct 30, 2014 5:07 pm    Post subject: Any tips for getting to the #2 sparkplug? Reply with quote
just use a 6 inch extension, get it on the plug and remember the angle,
also I had to fish too many dropped plugs out of the tin one time too many-
I think autozone sells a magnetized 13/16" "powercraft"? socket, so no more
dropped plugs on install!
Tcash
Tcash is offline
PostPosted: Thu Oct 30, 2014 5:17 pm    Post subject: Starting spark plug with a piece of hose. Reply with quote
You can use a piece of hose that fits snugly over the porcelain part of the plug to get it started, thread it in as far as you can with the hose. Then pull the hose off and tighten it with the plug socket.
The hose will need to be a bit longer than this.
Thrasher22
Thrasher22 is offline
PostPosted: Thu Oct 30, 2014 5:23 pm    Post subject: Reply with quote
I'm glad I'm not the only one that finds this a PIA Laughing
I usually unclip the air intake to give a couple more inches wiggle room.
1975 Westfalia - http://www.thesamba.com/vw/forum/viewtopic.php?t=516701
Lil Lulu
Lil Lulu is offline
PostPosted: Thu Oct 30, 2014 5:40 pm    Post subject: Reply with quote
Mac Tools sells a terrific spark plug tool. Stiff rubber, about 6", about $12, gives you a more deft touch than a plug wrench. Finish with wrench.
I tried a hose piece but could never get it straight, the hose wants to curl. This thing is purpose-designed, so it works great for this and this only.
'65 Beetle "Lil' Lulu"- Ruby Red
1600 stock from '71 bus
'72 Deluxe - Niagara Blue w/pastelwiess Camper Special 2L dual 40 Webers 002
'74 Hightop Weekender "Dixie" 1800 34 Del singles
Joey
Joey is offline
PostPosted: Thu Oct 30, 2014 6:56 pm    Post subject: Reply with quote
I use the hose on the end of the spark plug for both removing and installing my spark plugs. I also use the hose for spark plug installation on all the cylinders. It reduces the risk of cross threading.
Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle
ivwshane
ivwshane is offline
PostPosted: Thu Oct 30, 2014 9:51 pm    Post subject: Reply with quote
Because the plug would fall off without the screw on tip, I just used blue tape around the plug and socket, enough tape to keep it in place but not enough to not allow me to remove the socket.
I used ngk BP6ET and prenco performamax wires from busdepot who seem to think these are better than bosch.
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
ivwshane
ivwshane is offline
PostPosted: Thu Oct 30, 2014 9:55 pm    Post subject: Reply with quote
These are my old plugs, how do they look?
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
airschooled
Air-Schooled
airschooled is offline
PostPosted: Thu Oct 30, 2014 10:53 pm    Post subject: Reply with quote
We'd like to see a bit more of the insulator to get a true reading. A view of the base of the threads is helpful to see too.
What kind of condition was the engine last run at right before the plugs were removed? I like to read them immediately after a highway run. Like, pull off the freeway and shut it down, cool off, and pull plugs to read. Don't reinstall into a warm head unless you like to risk stripping threads.
WTB: 215mm Type 4 flywheel. Cash in hand.
www.airschooled.com
Road trip reports and tech blog:
ivwshane
ivwshane is offline
PostPosted: Fri Oct 31, 2014 12:02 am    Post subject: Reply with quote
The bus was running great, a little on the rich side according to the failed smog test:(
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
ivwshane
ivwshane is offline
PostPosted: Fri Oct 31, 2014 12:04 am    Post subject: Reply with quote
77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab
Lil Lulu
Lil Lulu is offline
PostPosted: Fri Oct 31, 2014 8:50 am    Post subject: Reply with quote
Show more of the business end of the plug. Also, if you photograph them on a neutral background, the white reflection won't betray the true hue.
Couldn't resist writing that last part cuzza tha rhyme. Embarassed
udidwht
udidwht is offline
PostPosted: Fri Oct 31, 2014 8:52 am    Post subject: Reply with quote
Use NGK B5ES for the plugs. They are the equivalent in terms of heat range as the no longer made Bosch W8CC plugs. The NGK's are by far better than the current Bosch offerings.
1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires
