Using 73+ Disk Brakes on 68-70 Bay Window
Page: 1, 2, 3  Next
kevlarian
kevlarian is offline
PostPosted: Fri Nov 21, 2014 4:10 pm    Post subject: Using 73+ Disk Brakes on 68-70 Bay Window Reply with quote
Can I just purchase a 2 1/2" drop spindle for a 72-79 bay, and insert that spindle on my 68... then source a new/used hub/disk combo (all the parts...) and run them on my 68?
Is it possible to mate a 72+ drop spindle on my 68 without modification?
Discuss...
(I think you know where I am going with this. I want Disk Brakes AND a 2.5" drop Trying to figure out a way to do it and keep it mostly stock.)
Tcash
Tcash is offline
PostPosted: Fri Nov 21, 2014 4:16 pm    Post subject: Reply with quote
Check out this thread.
Lowering a Bay
FlatfourFrenchy
FlatfourFrenchy is offline
PostPosted: Fri Nov 21, 2014 5:13 pm    Post subject: Reply with quote
I called WagensWest for some info for myself and asked him that same question. The gentleman told me that any year ball joint spindle will fit any year ball joint bus. They have some pretty cool goodies for the front end so I figured they know.their sh!t. I will be shopping there.
1971 Tin Top Westy Campmobile 70
skills@eurocarsplus
Samba Peckerhead
PostPosted: Fri Nov 21, 2014 6:05 pm    Post subject: Reply with quote
just harvest all your bits from a 71-79 bus. they bolt right on. then you can have power disk brakes too. order your spindles as needed
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
kevlarian
PostPosted: Fri Nov 21, 2014 6:34 pm    Post subject: Reply with quote
So when you say all the bits, you are talking from the spindle out. What about the master and slave cylinders.
FlatfourFrenchy
PostPosted: Fri Nov 21, 2014 7:01 pm    Post subject: Reply with quote
And don't forget the booster.
Tcash
Tcash is offline
PostPosted: Fri Nov 21, 2014 7:28 pm    Post subject: Reply with quote
Disc Brake Conversions
cdennisg
cdennisg is offline
PostPosted: Fri Nov 21, 2014 8:38 pm    Post subject: Re: Hear me out on this... Reply with quote
Discuss...
Short answer, yes. But as you seem to have discovered, there is a little more to it. The later spindle will fit the early beam, but the 68 beam does not have the mount for the power brake booster that is used with the disc brake master cylinder. Some adaptation is in order.
FYI, use 73-later disc stuff. It is better,and more readily available.
kevlarian
PostPosted: Fri Nov 21, 2014 11:24 pm    Post subject: Reply with quote
WTB: 73-later Disk stuff;-)
Tcash
Tcash is offline
PostPosted: Sat Nov 22, 2014 7:49 am    Post subject: Reply with quote
Parting out
kevlarian
PostPosted: Sat Nov 22, 2014 10:20 pm    Post subject: Reply with quote
Alright. Follow up question. If I convert the front of my 68 to disk with the 73 or newer front end, can I just replace the outer rear drums with the 73 or newer drums tomget the same bolt pattern, or do I have to replace the entire rear drum system too...
cdennisg
cdennisg is offline
PostPosted: Sun Nov 23, 2014 10:42 am    Post subject: Reply with quote
You will need the entire rear brake setup off the later bus. Instead of just a brake drum, they use a drum/hub combo. It will bolt onto your early trailing arm (I think), but it is definitely different. Might be a few small mods needed. Hopefully someone with direct experience with that swap will chime in here if I am wrong.
If you have a Bentley manual (and you definitely should) there are exploded diagrams of each rear brake setup in there. Study them closely and you will see what you need.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Nov 23, 2014 1:12 pm    Post subject: Reply with quote
I must have missed the 68 part. it's a 1 year only bay beam, as is the bolt hole pattern.(will fit 66 and 67 split's iirc)
you will need to use your beam, just swap spindles and have a plate welded on to it for your booster
Jake Raby wrote:
Brian wrote:
cdennisg
cdennisg is offline
PostPosted: Sun Nov 23, 2014 1:35 pm    Post subject: Reply with quote
68 and 69 beam have the same bolt pattern. 70 has the late pattern with drum brakes, 71-79 have the late bolt pattern with disc brakes. You can drill two holes in the sideplates of a 71-later beam to bolt up to an early bus, or change the sideplates to an aftermarket plate that is intended for building a lowered beam.
http://www.thesamba.com/vw/classifieds/detail.php?id=1358803
Here is a good shot of the two hole patterns, and the m/c mount plate.
It is likely the best plan to get an entire front beam from a late bay, then swap the spindles to your early beam and use the late beam/master cylinder mount as a pattern to build and install your own m/c mount plate.
kevlarian
PostPosted: Sun Nov 23, 2014 3:50 pm    Post subject: Reply with quote
Sourced a complete set of front spindles, brakes, rotors, calipers, etc from a 75 bay. How difficult is it to have my rear drums re drilled for the 5x130 whole pattern as up front will be. Also. Had anyone tried to do front disk brakes without the booster. Just running them straight.
cdennisg
cdennisg is offline
PostPosted: Sun Nov 23, 2014 4:05 pm    Post subject: Reply with quote
I don't think the wide five rear drum design will allow for the small bolt pattern. the casting in the center is too large.
Not sure about non-boosted discs.
kevlarian
PostPosted: Sun Nov 23, 2014 6:45 pm    Post subject: Reply with quote
I have looked at many of the disk brake conversion kits and none of them have boost or assist, including wide 5 native conversion. I the rear os going to be a challenge. I either have to run vastly different rims front and rear or figure out the rear.
cdennisg
cdennisg is offline
PostPosted: Sun Nov 23, 2014 8:30 pm    Post subject: Reply with quote
Not sure if the size of the pistons in the calipers, and the ID of the lines have anything to do with the need for a brake booster, but this stuff was designed to work as a team. Careful swapping in replacement players. Also, don't forget the brake proportioning valve from the donor late bay.
Swapping to late bay rear brakes is a bolt-on affair, I am pretty sure.
kevlarian
PostPosted: Sun Nov 23, 2014 10:37 pm    Post subject: Reply with quote
why cant the stock brakes work well... then this wouldn't be a problem...
cdennisg
cdennisg is offline
PostPosted: Sun Nov 23, 2014 10:42 pm    Post subject: Reply with quote
The stock brakes can work quite well if properly built and maintained. The disc brake advantage has more to do with the feel of power assist, and the lack of brake fade when they heat up. Also, drums get somewhat non-functional after driving through a big puddle or a heavy rain. Discs generally don't have that problem.
Page: 1, 2, 3  Next
