Raising the fenders for on and off road use...
Metal Twister
Metal Twister is offline
PostPosted: Sun Nov 30, 2014 2:53 pm    Post subject: Raising the fenders for on and off road use... Reply with quote
Well My hope is to take possession of my Thing around the first of the year. With that said Ive been looking at what I want to achieve as soon as possible after I get it. It has already been lifted, the adjustable front beam installed as well as after market 2" longer arms on the back. While my intent is to keep this a 60 Percent on road and a 40 percent off road car there are a few things that I have seen that I really like that have not been executed as of yet.
The original fenders are gone and new plastic fenders are waiting to be installed. I saw only one pic of this blue Thing on line and I think it is the direction Id like to go with mine. My question is for those of you that have them already what would be involved with raising the fenders to a similar height as these? Mine is a 73 so the boxes are not an issue. Body trimming? Moving things around inside the body for any reason? Thanks in advance so I can be making some plans.
Change is Opportunity!
Instagram=metaltwister
Captain Spalding
Captain Spalding is offline
PostPosted: Sun Nov 30, 2014 7:21 pm    Post subject: Reply with quote
On the photo you posted it looks like body cutting front and rear, and cutting of stock fenders. It kind of looks like the fenders were tack welded to the body after paint.
GI Joe
GI Joe is offline
PostPosted: Sun Nov 30, 2014 8:31 pm    Post subject: Reply with quote
I don't see much body cuttin on the blue one... Just a little on the rear 1/4 panel....
Looks like the Thing "Baja" style front fenders, trimmed to a flat style...
Rears look like wider glass, just mounted up higher on the body...
There is a thread here "After 20yrs, a Thing".... Or something like that... He's done close to the same thing, but kept the fenders full...
Love the look, and it looks Very functional!! Cool
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
77kafer
77kafer is offline
PostPosted: Sun Nov 30, 2014 8:50 pm    Post subject: Reply with quote
[quote="GI Joe"]I don't see much body cuttin on the blue one... Just a little on the rear 1/4 panel....
quote]
Take another look at that photo, look across the hood at how high the driver side front fender is and compare it to yours or any other stock thing. The body metal below the fender has all been removed.
Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer"
GI Joe
GI Joe is offline
PostPosted: Sun Nov 30, 2014 8:53 pm    Post subject: Reply with quote
http://www.kustom1warehouse.net/Prerunner_fenders_for_VW_Volkswagen_Thing_p/thingfenders.htm
Here are the fenders.... Prerunner style.. They sit about 4" taller than stock(but mount to the stock locations...)..
It's an optical illusions guys! I stand by that the blue Thing posted above is Not cut in the front... Wink
From Shoyrrt's thread(also a SoCal guy)..
Ok, I'm guessing the fenders on the blue one are one offs... They sit even higher than the ore runner style.... But I still beleive the body is uncut... Rolling Eyes
Ahh, who knows...... Laughing
'71 Beetle RPU
www.NLEOMF.com
77kafer
77kafer is offline
PostPosted: Sun Nov 30, 2014 9:02 pm    Post subject: Reply with quote
You are right, it is an optical illusion. I didn't realize that the add on fenders jutted up.
Metal Twister
PostPosted: Sun Nov 30, 2014 9:24 pm    Post subject: Reply with quote
I Spent a few minutes tonight searching for more pics of his car and I actually found a couple. This shows the front a lot better and I see shinny bolt heads in there? Heck I can fab up some raised fenders no problem.
After getting abetter look at the back fenders Im not so sure I like them as much as I did in the desert shot...
Thanks for the pic of the yellow fender that helps me a lot! I'm thinking seriously about cutting off the front of the front fender like he did. Then build a doubler plate off the body under the fender and removing the turn indicator and installing a pair of small rectangular head lights on top of the fender where the turn indicators are now. I will use a couple of the new DOT button LED's for turn indicator and clearance lights.
These are the high low beam head lights I was thinking of using on the street. For off road I will run an assortment of LED's...
http://www.speedwaymotors.com/Rectangular-Headlights-Halogen-Bulb,35742.html
Shoyrtt
Shoyrtt is offline
PostPosted: Mon Dec 01, 2014 1:43 pm    Post subject: Reply with quote
Here is a picture of the yellow fender on the car before paint. I picked them up from Brian Coats Fabrication in Huntington Beach.
These were direct bolt on replacements for the stock fenders. I wanted to run a larger tire, but I didn't want to run a body lift or cut any of the sheetmetal. I also liked that Brian's fenders didn't have any provisions for a turn signal up top.
Metal Twister
PostPosted: Mon Dec 01, 2014 2:00 pm    Post subject: Reply with quote
A little off topic but I sure like your cage design. Did you twist it up or is that something someone is selling? I've seen a little red thing with a similar cage and really like the simple, functional, and nice lines of your cage.
Shoyrtt
Shoyrtt is offline
PostPosted: Mon Dec 01, 2014 2:33 pm    Post subject: Reply with quote
Are you talking about this car?
I had this car in mind when I had the cage fabricated. It also is a nice example of fenders both front and rear. Wink
Metal Twister
PostPosted: Mon Dec 01, 2014 3:18 pm    Post subject: Reply with quote
That's it, I didn't recognize it all blown apart like that. I'm thinking something like that would be just perfect... Then I saw yours. How is the entry head room for the back seats? Enough clearance for the head or is it a head thumper?
The pic I was looking at...
Shoyrtt
Shoyrtt is offline
PostPosted: Mon Dec 01, 2014 4:08 pm    Post subject: Reply with quote
I'm running stock rear seats and if you are over 5'9" the horizontal bar at the "C" pillar is a head thumper. You would need to move it to the rear to clear.
Metal Twister
PostPosted: Mon Dec 01, 2014 4:39 pm    Post subject: Reply with quote
Naaa, just keep the big folks out of the back of the car. As often as it will be used for full sized folks I like the looks of the cage as it is. Do like the cops when they are putting cuffed guys in the back seat, put your hands between the cage and their noggins when getting in. LOL Thanks for the input its very helpful.
Shoyrtt
Shoyrtt is offline
PostPosted: Mon Dec 01, 2014 6:19 pm    Post subject: Reply with quote
The noggin knocker is an equal opportunity employer "getting in" to the car. Like any cage you get used to where the bar is upon entry. The bar I'm talking about runs horizontal between the two "C" pillars. Back seat passengers (especially when you hit a bump) can hit their foreheads on that bar. No full sized people back there unless they wear a helmet. LOL
Metal Twister
PostPosted: Mon Dec 01, 2014 6:49 pm    Post subject: Reply with quote
Oh that bar... I have a old friend who knows that bar very well!
Ratt
Ratt is offline
PostPosted: Mon Dec 01, 2014 7:53 pm    Post subject: Reply with quote
Who's thing is this, and any more photos of the cage? I'm trying to figure out what I am doing for my suspension.
saddlesore1
saddlesore1 is offline
PostPosted: Tue Dec 02, 2014 9:28 am    Post subject: Reply with quote
Here is another shot of Brian's fenders on my car. As far as I am concerned they are the best out there.
Metal Twister
PostPosted: Tue Dec 02, 2014 10:18 am    Post subject: Reply with quote
After really studying all the fenders available, even the different fenders cut up I like the ones on your Thing the best. Very nice width and full length and look right at home on your thing. Very Nice.
mattt
mattt is offline
PostPosted: Tue Dec 02, 2014 11:04 am    Post subject: Reply with quote
As far as I know, there are 3 different raised/widened front fenders available for the Thing. The first available were from Socal Imports and are about 2.5" wider and taller than stock. I have Socal Imports front on my Thing. Then the ones from Kustom 1 were made available as 'glass knock-offs of the first all steel set of widened/raised fenders that were hand made by Brent?, the builder of "Leopard Thing." In the last few years, saddlesore has been selling the fenders from Brian? I don't know their width/height.
As far as rears, for higher fenders there aren't many options. The Kustom 1 fenders bolt with well nuts to the outside of the body. Again....made by the builder of "Leopard Thing." The only other rears that were taller were made in Mexico back in the day, and I have a set on my Thing. They bolt in the stock rr fender mounting holes but wrap outside the fender opening so they are wider and taller than stock. I haven't seen another set like the rears I have in the US. The only others I saw were on a Thing that lives/lived in Mexico and I saw it in San Diego one time. I had to have a set and took a few trips south to get them. You can see pics of the fenders and Thing in my gallery pics, complete car is back on page 3. Soon after someone stopped by my place to buy some Thing parts, and checking out my 181, the other rears that are made by Brian? & mount in the stock fender mount holes, and wrap up higher and wider appeared for sale. Coincidence.....
saddlesore1
PostPosted: Tue Dec 02, 2014 11:19 am    Post subject: Reply with quote
As far as rears, for higher fenders there aren't many options. The Kustom 1 fenders bolt with well nuts to the outside of the body. Again....made by the builder of "Leopard Thing." The only other rears that were taller were made in Mexico back in the day, and I have a set on my Thing. I haven't seen another set like the rears I have in the US. The only others I saw were on a Thing that lives/lived in Mexico and I saw it in San Diego one time. I had to have a set and took a few trips south to get them. You can see pics of the fenders and Thing in my gallery pics. Soon after someone stopped by my place to buy some Thing parts, and checking out my 181, the other rears that are made by Brian? & mount in the stock fender mount holes, and wrap up higher and wider appeared for sale. Coincidence.....
Not sure what you are inferring Matt.
I have Brian Coats' and yes I advertise for him because I said I would. I get nothing by the way. I promote his because like I said in the past I believe they are the best.
They are similar to all the other "raised and wider" except for the fact that the ugly turn signals have been removed. They are also slightly thicker and are preprimed out of the mold. if you scratch your paint while driving it hard you do not see raw fiberglass. You see the original color that was shipped to you.
As for the rears they are completely different than any others available. They bolt in the stock location so guys like me do not have to drill holes in the side of the body to get the look they want and have them raised 2" and wider to match the front. They look like they belong together.
for these reasons they are "in my opinion" THE BEST AVAILABLE.
Oh did I mention he should have the mold done for the 74's with earmuffs.
