gabchbum Samba Member
Joined: November 05, 2013 Posts: 16 Location: Savannah
Posted: Sun Dec 07, 2014 5:55 pm Post subject: no fire to coil |
| we just replaced the 1600cc type 2 engine in the 1971 bus. the starter turns fine,but the engine wont fire. i have fire to the coil,but none from the coil. i replaced the coil and still got no fire.... i believe the electronic ignition leads could have been swapped on the coil(black on positive and red on negative). i just dont see why it would still turn over if i fried the electronic ignition. im looking for any help or suggestions |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Sun Dec 07, 2014 6:35 pm Post subject: Electronic Module Testing |
Stupid question. Did you put the rotor back in?
If you hooked it up backward. It may have fried the Module.
Posted: Sun Dec 07, 2014 6:43 pm Post subject: |
| everything is in place as it should be and the distributor wires are on tight. if the electronic ignition is fried,would it block or suppress power from the coil? |
Tcash Samba Member
Posted: Sun Dec 07, 2014 6:46 pm Post subject: |
Yes it would. Run the test in the picture, to test the module.
Good Luck |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24504 Location: NYC/Upstate/ROW
Posted: Sun Dec 07, 2014 6:49 pm Post subject: |
Frying the electronic ignition module won't have any effect on the starting system which cranks the engine. These are independent systems. _________________ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ πΊπΈ π π π |
Tcash Samba Member
Posted: Sun Dec 07, 2014 7:24 pm Post subject: |
| Quote: |
| the starter turns fine |
dugfresh Samba Member
Joined: November 04, 2012 Posts: 651 Location: Seattle
Posted: Sun Dec 07, 2014 7:44 pm Post subject: |
| Tcash wrote: |
| Quote: |
Don't you mean "The Starter System"? _________________ 78 Riviera
http://flic.kr/s/aHsjDRJPa1 |
Tcash Samba Member
Posted: Sun Dec 07, 2014 7:48 pm Post subject: Re: no fire to coil |
| gabchbum wrote: |
Posted: Sun Dec 07, 2014 8:11 pm Post subject: |
| 12.3 volts when i go across the ignition with a volt meter |
Posted: Sun Dec 07, 2014 8:27 pm Post subject: |
| Abscate wrote: |
| Frying the electronic ignition module won't have any effect on the starting system which cranks the engine. These are independent systems. |
Addresses question...
| Quote: |
Tcash Samba Member
Posted: Sun Dec 07, 2014 8:56 pm Post subject: |
| gabchbum wrote: |
You have 12.3 volts where?
#15 positive side of the coil?
Do you have a set of points and condenser that you can install? |
