Henrik_K Samba Member
Joined: November 17, 2013 Posts: 181 Location: Denmark
Posted: Thu Dec 25, 2014 12:11 pm Post subject: Where did this spacer come from? |
Turned my Type4 - 1800 - shortblock around in the enginestand today.
This little bugger fell out. It's kind of shivered - with an odd pattern on it. It definitely doesn't looks like a regular spacer...
Can anyone identify where this might come from?
Thanks
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23567 Location: Oklahoma City
Posted: Thu Dec 25, 2014 12:24 pm Post subject: |
Cant tell from the photo. What are the specs/size? ID, OD, thickness?
Ray |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Thu Dec 25, 2014 3:01 pm Post subject: |
Thanks to jerseylooker
Did you take #8 the Distributor drive out?
[url]
Good luck
Tcash
[/url] |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42988 Location: at the beach in Northern Wokistan
Posted: Thu Dec 25, 2014 3:05 pm Post subject: |
yes - that is the shim under the distributor drive gear. It will have 3 worn/shiny high spots on each side. Don't lose it. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"
1971 deluxe (sold)
1977 deluxe |
Posted: Thu Dec 25, 2014 5:04 pm Post subject: |
| SGKent wrote: |
| yes - that is the shim under the distributor drive gear. It will have 3 worn/shiny high spots on each side. Don't lose it. |
thats what I get for looking at this on my phone. As good as my 5s screen is.....I could not see the three telltale nubs of the distributor drive shim. My eyes may also be getting old....just the eyes.
Ray |
Posted: Fri Dec 26, 2014 1:08 am Post subject: |
Yes, I did take the distributor drive gear out, cause I thought it pointed in the wrong direction when #1 was at TDC.
How do I get back in? a little grease on the end of drive gear?
Should it be flipped in a specific way?
Thanks a lot.... |
williamM Samba Member
Joined: August 07, 2008 Posts: 4343 Location: southwest Arizona
Posted: Fri Dec 26, 2014 1:32 am Post subject: |
Best way to return it is to spear it with long skinny screwdriver and slide it down the hole, grease will help hold it in place ti the drive comes back on top. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5175 Location: California's Hot and Smoggy Central Valley
Posted: Fri Dec 26, 2014 3:43 am Post subject: |
Are these readily available?
Is this the part number> 021105235 ?? |
Tcash Samba Member
Posted: Fri Dec 26, 2014 4:05 am Post subject: |
| Henrik_K wrote: |
A screwdriver is best. Less chance of dropping the washer.
No, either way will work.
Thanks a lot.... |
Indexing Distributor Drive Pinion |
Posted: Fri Dec 26, 2014 5:15 am Post subject: |
| Thanks Guys.... |
SGKent  Samba Member
Posted: Fri Dec 26, 2014 8:20 am Post subject: |
as stated, grease on it and a long skinny rod ir screwdriver. Put the it on the screwdriver and make sure you have it. Put the screwdriver all the way down in the bearing race before you let the washer slide down. Use a dowel or snap ring pliers to grasp the gear as you put it in. Do not remove the gear again because if that washer had fallen into the engine you would be disassembling it now to get it out. If you have to turn the gear, only pull it out enough where the teeth disengage - leave the tail in the bearing race. You were really lucky this time. Don't forget the spring when you put the distributor back in. _________________
George Carlin:
1971 deluxe (sold)
1977 deluxe |
Posted: Fri Dec 26, 2014 9:58 am Post subject: |
Thanks again....
I have the engine in the engine stand. I could rotate the engine upside-down and that way insert the piniongear with the shims on?
I wasn't aware that the shims could slide into the engine like that.
Lucky that it came out and that I actually noticed this.
Otherwise I might just have overseen it on the floor...
Thanks again for all your repsonse. Appreciate it.
Merry X-mas and all... |
Tcash Samba Member
Posted: Fri Dec 26, 2014 10:07 am Post subject: Tom Wilson |
Might I suggest you purchase this book.
How to Rebuild Your Volkswagen air-Cooled Engine - Tom Wilson
Publisher Penguin, 1987. ISBN 0895862255, 9780895862259
It describes in great detail all the steps of rebuilding a air cooled VW engine. Read and understand it completely. Don't be afraid to ask questions.
Good Luck
Tcash
Posted: Sat Dec 27, 2014 1:42 am Post subject: |
Just in case the T-1 engine new guys are listening- you can not put your bigger stack of washers on your drive and put them in - your thrust washers must be in the case first - then the drive installed as the washers will gouge the brass crank gear and NOT allow the drive to engage the crank gear.  _________________ some days I get up and just sit and think. Some days I just sit.
Posted: Sat Dec 27, 2014 2:05 pm Post subject: |
I actually have this book and others. But as English is not my first language - it can difficult the read and understand tech stuff.
I also have the BugMe videos... |
Tcash Samba Member
Posted: Fri Mar 20, 2015 8:43 am Post subject: Re: Tom Wilson How to Rebuild Your Volkswagen air-Cooled Eng |
| Tcash wrote: |
Might I suggest you purchase this book. It describes in great detail all the steps of rebuilding a air cooled VW engine. Read and understand it completely. Don't be afraid to ask questions.
Good Luck
Tcash |
ROCKOROD71 Samba Member
Joined: January 18, 2012 Posts: 2770 Location: Boston, MA
Posted: Fri Mar 20, 2015 9:16 am Post subject: |
| Wasted youth wrote: |
http://www.busdepot.com/021105235
Whether or not they have it in stock is another story... _________________ 1971 STD BEETLE- DD-1st car, 1st love. keepin' it stock! 1600DP, Solex 34-3 Mexi Bosch SVDA Dist NOW w/POINTS
1977 WESTY "KrustyKamper" 2L FI
| 79SuperVert wrote: |
30 years from now, the next guy may not want your girlfriend, but he may want your classic car, depending on how nice you were to it. |
| asiab3 wrote: |
Careful guys, a petulant child can grow up to be president these days. |
**winter drivers: no survivors!**rust warrior**#keepbodyshopsbusy** |
photoboy52 Samba Member
Joined: September 24, 2010 Posts: 15 Location: SoEast Texas on the Gulf
Posted: Fri Mar 20, 2015 9:25 am Post subject: Re: Tom Wilson How to Rebuild Your Volkswagen air-Cooled Eng |
| Tcash wrote: |
| Tcash wrote: |
Good Luck
Tcash |
This book is so great, worth its weight by far, I purchased an extra at a thrift store the other day, can leave this one in the bus, it was a steal for $2!  _________________ Current
1972 Sierra Yellow Campmobile
1.7L (rebuilding)
'97 Geo Metro 3 door 1L
Tin can on a skate
(Did engine rebuild my self)
Past
1961 Bug Sedan
Thrown Rod (Recently found it still at home now need to get from Nor Cali to SE TX!!) |
Tcash Samba Member
Posted: Wed Mar 23, 2016 6:56 pm Post subject: Tom Wilson |
Good Luck
Tcash |
