Fredrok Samba Member
Joined: July 06, 2014 Posts: 227 Location: Under the evergreens. CO
Posted: Wed Jan 07, 2015 5:23 pm Post subject: Heat exchanger to heater box? tube? |
I'm unable to find any parts reference at all in the Bentley after the heat exchangers. I'm also unable to find any parts reference for a tube that would run between the exchanger and the heat box(?) I have some cheesy tubes on there now around 5" long that don't fit the ends properly. The exchanger is 60mm and the box downstream in the picture is 64mm.
Seems all that is offered in the parts world is the longer plastic flex tubes as in the picture. I could get 2 of those to elimnate the "boxes" altogether with ends that fit properly (60mm-50mm-body tube size) but is that the method most are going with? Seems if I could get the proper flex tube, I'd just stay with the original boxes but I haven't found an appropriate flex tube yet.
Anyone have ideas they care to share? Do you have a solution for the 5"ish 60mm to 64mm flex tube I seek or just pick up a couple of the newer flex tubes in the appropriate size and be done with the boxes?
Thanks for your input.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25868 Location: Olympia Wash Rinse & Repeat
Posted: Wed Jan 07, 2015 6:28 pm Post subject: |
Check out the "Type 2 Parts Reference Manuals" here:
http://oacdp.org/
Loads of exploded diagrams and descriptions. Have used the info there for part numbers for use in internet searches to locate and buy parts.
Full index is easier to use than the quick index.
Heater tubes came in only 60 and 50 mm sizes. _________________ In Stereo, Where Available! |
Posted: Wed Jan 07, 2015 6:56 pm Post subject: |
I can't believe I spaced and forgot about using the OACDP resource. Thanks so much for directing me there.
So, the "box" is actually a heater muffler and you're correct, 50mm or 60mm only. Makes sense since early exchangers were 50 and late 60. If both ends are the same diameter (and I don't know), then I wonder how they fit over the 64mm muffler ends. It's a 211255715B which is no longer available so it seems folks are going with flex exhaust pipe, etc. which still leaves one with a mismatched end issue.
Maybe most are replacing the muffler altogether with the insulated, longer plastic tubes and calling it a day? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 52686 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Wed Jan 07, 2015 8:20 pm Post subject: |
If you get the flexible pipe that's smooth (no octagonal crimps) it can be unwound/wound to larger or smaller diameters by twisting it.
_________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Jan 07, 2015 8:35 pm Post subject: |
Thanks BD. Yea, after some research it looks like that's my only option if I keep the mufflers. Replacing them with the plastic tubes frees up some space in that area and eliminates 2 connections. I think I'd go that route if I could locate a pair of NOS German 60mm/50mm tubes as the aftermarket ones look like shit on the inside. Just some fiberglass insulation thrown in and "held" in by a wire someone yanked out of a radiator flex hose while reducing the ID cross section by 50%. |
Clara  Samba Member
Posted: Thu Jan 08, 2015 8:52 am Post subject: |
The VW solution for mismatched heater boxes and VW is an adaptor which converts the 50mm to 60mm.
Here it is with late heater boxes in a 63 SC:
For the quick and cheap fix, I have put the end of a paper hose inside the large tube, and duct taped it in place. |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Thu Jan 08, 2015 10:36 am Post subject: |
Needed heat in a hurry and had a muffler shop make some adapters and used the paper hose. In 17 years of secondary use I have had to replace the tube 2 times. Don't mind the leaky boot, that has been repaired.
EverettB  Administrator
Joined: April 11, 2000 Posts: 71455 Location: Phoenix 602
Posted: Thu Jan 08, 2015 10:44 am Post subject: |
ToolBox wrote: |
This works too.
Suggestion: Add an insulating wrap around that to minimize heat loss. _________________ How to Post Photos
Krustybus Samba Member
Joined: February 16, 2004 Posts: 442 Location: SE Michigan
Posted: Thu Jan 08, 2015 12:25 pm Post subject: |
Awesome, thank you all. This is exactly the kind of feedback I was looking for. I have a JOGR heater wrap kit that I'm finally getting around to installing and realized last night that it includes the pieces to wrap the short flex hoses between mufflers and boxes. I guess I'll reuse the flex pieces that I already have, hose clamp on the box side where they're slightly loose and wrap them to keep the stock setup and look.
Realistically, that will probably be the end of that but I'm going to keep my eye out for some NOS German hoses either 60-60 or 50-50 at a good buy and get adapters that Clara or Krusty pointed out.
I also got a PM that Skinner may have some good quality repop hoses and may check that lead as well.
Thanks all. |
Posted: Thu Jan 08, 2015 4:33 pm Post subject: |
Fredrok wrote: |
Realistically, that will probably be the end of that but I'm going to keep my eye out for some NOS German hoses either 60-60 or 50-50 at a good buy and get adapters that Clara or Krusty pointed out. |
Why get both?  _________________ In Stereo, Where Available! |
Posted: Thu Jan 08, 2015 6:57 pm Post subject: |
Eric&Barb wrote: |
Fredrok wrote: |
Why get both?  |
Meaning I may like to go with the cleaner install if I happen across the right parts at the right price someday but once I put it together the way it is now (with mufflers), I'll probably (realistically) be too lazy to bother changing it anyway. |
