BurghBug Samba Member
Joined: January 12, 2015 Posts: 3 Location: Pittsburgh, PA
Posted: Sat Jan 17, 2015 7:15 pm Post subject: Innovative VW 4x4 Bug build, without syncro parts! |
This site has some details about a 4x4 Bug that some guys in Brazil built:
http://www.4x4brasil.com.br/forum/gaiola-baja-e-buggy/77703-fusca-4x4.html
The google translator for Portuguese is very weak, so much of what I 'know' is a guess based on sketchy translation and looking at the pictures. Are there any theSamba members from Brazil or that speak Portuguese? If so, please help!
That said, near as I can tell, they built the power take off by adapting a regular 2wd type 2 transmission, making an extended pinion shaft that ran out of a new hole in the nose of the transmission(!) Now, before you think I'm smoking something funny, please check page 10, where they discuss reinforcing and sealing the nose of the case, and extending the pinion shaft.
If that really is the approach they took, and the engineering behind this is solid, this opens a whole world of 4x4 builds that no longer need to rely on Syncro transmissions!
For a front diff, they custom built a case for a regular rear diff, flipping it so it would spin the correct way.
The front suspension and drivetrain seems to have also come from a Bus, with a fabricated subframe to hold the tops of the struts.
And for at least a while they used a home built decoupler.
So there you have it.. how to make a 4x4 bug without using Syncro parts!
Of course they didn't stop there.. they use the bus motor and some rear suspension components, reinforced the pan, added vacuum boosted disk brakes all around, added a cage, and a bunch of other touches. Looks like it turned out to be a heck of a car. The only thing missing is lockers
Enjoy! |
Brian Samba Moderator
petrol punk Samba Member
Joined: August 21, 2007 Posts: 1053 Location: Las Vegas, NV
Posted: Sun Jan 18, 2015 12:49 am Post subject: |
Seems like they just figured a way to get power off the pinion shaft and out the nosecone. I think I'd rather just buy a Samurai if I wanted a 4x4. _________________ 36hp '56 European DeLuxe oval
'70 bug 1835cc |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 3695 Location: West Coast (Michigan's)
Posted: Sun Jan 18, 2015 7:12 am Post subject: |
what a waste of time, and a super to boot! _________________ Brian H.
OrangeCrushERBerrien Warrior-2.4L Quad4-2x3 arms-1.5Fox coilovers-094-930CVs
LAZY MARY1970 Baja 2110cc-82mm CB forged crank-AA pistons/cylinders-Grant rings-1.1 vw rockers-CB serpkit-CB chromoly PRs-CB maxiflow filter pump-wix51515 filter-Dual 44IDF-cut/turned front beam-AEM wideband-Auber CHT-Donaldson Dual PowerCore filters-custom AL air boxes |
Joined: June 02, 2011 Posts: 1593 Location: Louisville, ky
Posted: Sun Jan 18, 2015 7:23 am Post subject: |
| The 2 wheel drive transmission was designed to do exactly what they did. Officers cars in WWII were 4 wheel drive. While some hackage did occur in making this they are only following the original design. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 4006 Location: SANDY VALLEY, NEVADA
Posted: Sun Jan 18, 2015 1:03 pm Post subject: |
Why do some people just have to bash other peoples cars because they don't like it, your opinion pretty much only matters to you.
I think its a pretty cool car and they did a nice job on it, as for being a Super that saves a lot of problems like being able to use struts from a front drive car to make powering the front wheels easier. Using a cut up trans to get the center section and have VW drive flanges is a nice piece of backyard engineering.
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Sun Jan 18, 2015 2:03 pm Post subject: |
Seriously. I would love to drive a 4x4 bug like that. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
hotrodsurplus Samba Member
Posted: Tue Jan 20, 2015 9:27 am Post subject: |
So what makes you experts think that's a Super?
And since when is it a bad idea for backyard engineers to express a whole lot of ingenuity on such a common car? Before you answer that, remember what forum you're on. Seriously, the second most abundant thing in Brazil beyond big round asses are VW Beetles.
Look at that front gear carrier. I've never seen anyone here even ATTEMPT that. And they have few tools. For those of you clowning this thing, show some respect. It's impressive on several levels. |
Posted: Tue Jan 20, 2015 10:49 am Post subject: |
"For those of you clowning this thing, show some respect. It's impressive on several levels."
Yeah, you need to take it down a notch. It's not the poster's rig and the pictures are five years old. I'm hardly attacking anyone.
Don't get your panties in a bunch, I'm no stranger to doing things just 'cause you can. I'm just not impressed like you are so sue me. _________________ Brian H.
Posted: Tue Jan 20, 2015 11:50 am Post subject: |
| hotrodsurplus wrote: |
I don't think the front gear carrier is the impressive part of this build. that's a pretty easy part to make yourself if you have machine tools at your hand. I'm more impressed by how they managed to get power off the pinion shaft and out the nose cone. _________________ 36hp '56 European DeLuxe oval
'70 bug 1835cc |
Posted: Tue Jan 20, 2015 11:59 am Post subject: |
| ORANGECRUSHer wrote: |
Don't get your panties in a bunch, I'm no stranger to doing things just 'cause you can. I'm just not impressed like you are so sue me. |
...says the guy who called this a Super.
I guess I found your button.
In my few years I've found that the ones who actually do rather than spectate have very little negative to say about other peoples' work. Respect for others' work comes from personal experience.
Panties. How cute.
Last edited by hotrodsurplus on Tue Jan 20, 2015 12:15 pm; edited 1 time in total |
Posted: Tue Jan 20, 2015 12:13 pm Post subject: |
Struts = super afaic
I'm done here. _________________ Brian H.
71StandardReduction Samba Member
Joined: December 04, 2012 Posts: 791 Location: Louisiana
Posted: Tue Jan 20, 2015 7:25 pm Post subject: |
Well, looks like I was a little wrong about there being no Syncro parts in the build. That rather distinctive looking front strut seems to have come from a Quantum Syncro.
http://www.google.com/imgres?imgurl=http://www.jim...GvIIDI0eBM
The little bit of the front subframe visible in the picture looks a lot like the one they used as well. So, there is a little Syncro in there after all. I still think this is a very creative build!
Also worth mentioning, the biggest problem with the build according to the article was getting the front suspension set up correctly. They even said the front diff carrier was 'easy', given access to the right tools. |
javabug Samba Member
Joined: March 14, 2003 Posts: 254 Location: Hershey, PA
Posted: Wed Jan 21, 2015 8:42 am Post subject: |
| Quote: |
| Well, looks like I was a little wrong about there being no Syncro parts in the build. That rather distinctive looking front strut seems to have come from a Quantum Syncro. |
Look at it this way: a Quantum would have that same front suspension, Syncro or not. I'd be surprised if Quantum Syncros made it down to Brazil, given the climate (I'm saying this without any research, so take it with a grain of salt).
So, you could assume it's from a regular FWD Quantum, and stick to your original statement. _________________ Mike |
chubby53 Samba Member
Joined: February 17, 2005 Posts: 2106 Location: Eugene, Oregon
Posted: Thu Jan 22, 2015 1:39 pm Post subject: |
I have to say this thing is pretty cool. Tons of respect here. I think it would be the bomb to have a Baja that the front wheels worked too. I can't even count of how many times I would of loved to have some action on the front end to get me out of a situation. I would suggest some kind of locker on the drive shaft so you are not alway in 4wd. Very cool though. _________________ My build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385100 |
jps1145 Samba Member
Joined: March 16, 2005 Posts: 654 Location: Tehachapi, CA
Posted: Thu Jan 22, 2015 2:00 pm Post subject: |
I'm kinda curious to know what supports the rear of the car now. He cut the torsion splines completely out of the rear housing. _________________ Tehachapi, CA
'69 Baja
Vintage Funco single seater
My Baja |
Posted: Thu Jan 22, 2015 3:56 pm Post subject: |
Post 55 has a picture that shows a separate spring and shock setup.
The text with it says something about rear of van suspension, but it doesn't look like a VW bus rear suspension to me. Maybe someone with more bus knowledge will chime in..
But wait, here's a side picture of a T25 rear suspension. Picture a disk instead of drum brake, and I think it is right after all.
DAV!D Samba Member
Joined: September 10, 2013 Posts: 980 Location: EL CAMINO
Posted: Thu Jan 22, 2015 5:39 pm Post subject: |
I'm not sure why the hate, but I think it's a pretty cleaver build. I also got a pretty good kick out of the first video where he pulled a stuck jeep out of the mud with the 4x4 bug..
I will say the steering set up looks sketchy as hell but I guess do what yea gotta do to make it go..  _________________ 86 Syncro Build - Ecotec Motor Swap - Pop Top Conversion - Camper Build & Syncro Conversion |
