Porsche 915 in a VW Bay Van
dpetteng
dpetteng is offline
PostPosted: Sat Mar 14, 2015 7:13 am    Post subject: Porsche 915 in a VW Bay Van Reply with quote
so, my 1971 bay project is starting. I have a 915 and a 1987 3.2 Porsche engine.
Most of the fabrication looks relatively straight forward except the shift rod.
The VW transmission has the hockey stick at the top of the transmission and the 915 has it at the bottom so the two will not line up.
I have seen a lot of bent shift rods etc to make it work but wondering if we could make it more elegant by fabricating a Porsche shift rod with two "kinks" in in which would be steering couplings so they could move through an arc if that makes sense.
Has anyone seen this done properly? I will need to use a 911 shifter as the VW one is only 4 speed.
Any ideas appreciated.
levi20AE
levi20AE is offline
PostPosted: Sat Mar 14, 2015 7:30 am    Post subject: Reply with quote
I have no data on modifying the existing shift rod but have you thought about adapting cable shift setup? I swapped a 20 year younger trans into my mk1 and the more modern cable shift setups are so much smoother and more accommodating to flexing of mounts and such when you have a lot more power to put down.
1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
20th AE VW GTI - 369hp 340tq @ 26 PSI
1982 Rabbit Pickup - German AAZ 1.9TD - daily with lots of MPGs
View user's profile Send private message Instagram Classifieds Feedback
dpetteng
dpetteng is offline
PostPosted: Sat Mar 14, 2015 8:43 am    Post subject: Reply with quote
I have been thinking about cable shift, the problem I have seen so far is simply room for mounting these in a VW Bay window
raygreenwood
raygreenwood is offline
PostPosted: Sat Mar 14, 2015 8:49 am    Post subject: Reply with quote
VW did something similar on thr VW 411 and 412 with the 004 four speed trans. The tail cone and hockey stick are on the 004 is also on the bottom and is below the normal plane of the shift rod. I wont get into the reasons why they did it here.
Blunty its a crappy design.
It uses a ball stud of specific length attached to the hockey stick standing up vertically. The rear end of the shift rod has a tubular cup or socket that fits over the ball stud.
The problems this causes are numerous.
1. As you move the shifter from the 1/2 quadrant to the 3/4 quadrant or vice versa.....the vertical ball stud swings left or right in an arc. The height of the ball stud must be exact.....and by the same token the cup attached to the foward shift rod must also be in an exact position.....or else it changes the amount of rotation in the arc of the ball stud and causes shifting issues.
2. Because of the above need.....the forward shift rod attached to the shifter on the forward end and the socket on the ball stud of the hockey stick in the rear....must be rigidly supporte d somewhere along its length aft of the shifter......by something that is simultaneously a wear proof bearing or bushing for smooth movement.....that has some adjustability to be able to make sure the socket at the ball stud can be height adjusted.
3. This means that to keep this flexible floating ball joint linkage accurate.....the transmission must be rigidly mounted. If soft or floating trans mounts are used it will change the position of the ball stud relative to the shift rod cup causing problems.
So...if you are going to do this using ball and socket joints.....make sure the ball is pinned into the socket or snaps in. Not floating. Also a double joint will be very hard to adjust and keep adjusted.
I would suggest actually a full custom shift rod that is curved.....or a custom adapter for the shifter that drops the whole assembky down to give you a straight shot at the trans tail cone. Ray
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Sat Mar 14, 2015 8:50 am    Post subject: Reply with quote
You should be able to do something like this pretty easily
dpetteng
dpetteng is offline
PostPosted: Sat Mar 14, 2015 8:57 am    Post subject: Reply with quote
That's exactly what I was thinking of. Do you have more pics? Why is the transmission raised? is it to drop the van on the floor?
raygreenwood
PostPosted: Sat Mar 14, 2015 9:11 am    Post subject: Reply with quote
Yes....thats the way to go! Ray
VWsArent4Hippies
PostPosted: Sat Mar 14, 2015 9:16 am    Post subject: Reply with quote
Yea, trans raise to get the bus super low. Summit has a ton of u-joint options for whatever you'll end up needing
dpetteng
dpetteng is offline
PostPosted: Sat Mar 14, 2015 9:20 am    Post subject: Reply with quote
awesome, my other problem is converting the 911 shifter to be much longer for the bus, any ideas there? The problem will be with an extended standard shifter, the throw will be very big
1967250s
1967250s is offline
PostPosted: Sat Mar 14, 2015 12:32 pm    Post subject: Reply with quote
Two things I can think of are: 1. Make a raised shifter plate or box with another universal joint to get aligned with the rod. 2. Cut off the ball on the bottom of the shifter and put a small extension. Thing with this is to figure out the right spacing. Maybe use a threaded rod with lock nuts.
'72 Elm Green Deluxe
sodbuster
sodbuster is offline
PostPosted: Sat Mar 14, 2015 12:37 pm    Post subject: Reply with quote
Porsche is well served in the aftermarket. short throw kits for the shifter should be available I would think. It's all got to be fabed up custom anyway
dpetteng
dpetteng is offline
PostPosted: Sat Mar 14, 2015 1:03 pm    Post subject: Reply with quote
makes sense, thanks
notchboy
notchboy is offline
PostPosted: Sat Mar 14, 2015 1:36 pm    Post subject: Reply with quote
Why limit yourself with a VW trans if you put in a Porsche Motor? Why not fit a Porsche 5 speed?
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
dpetteng
dpetteng is offline
PostPosted: Sat Mar 14, 2015 4:00 pm    Post subject: Reply with quote
I am putting a Porsche transmission in. Using a 1977 915, hence the need to have a different shift rod.
SGKent Premium Member
SGKent is offline
PostPosted: Sat Mar 14, 2015 5:23 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=375224&highlight=915+trans
sodbuster
PostPosted: Sat Mar 14, 2015 5:29 pm    Post subject: Reply with quote
That is the part I did not know. I know you said the engine was out of an 87 911 and you had a 915 gearbox. But you didnt mention the year of the gearbox. (87 911 did not use the 915 gearbox.) So look for a shifter out of a car that did use the 915 if you still go the "short throw" Porsche shifter route.
dpetteng
dpetteng is offline
PostPosted: Sun Mar 15, 2015 4:10 am    Post subject: Reply with quote
Got it, thanks. The engine was in a car with a G50 but that transmission is harder to fit into a van, hence I went for the 915.
Still worried about the throw of the shifter even with a short shift kit as the shifter handle will need to be twice as long as a standard 911 shifter to work in a van.
Will keep thinking
SJSnakeman
SJSnakeman is offline
PostPosted: Sat Apr 04, 2015 8:59 am    Post subject: Need thoughts on installing a 911 motor and 915 trans in bus Reply with quote
I have a 62 bus and have been toying with the idea of installing a 911 motor and 915 trans. I've never done this kind of job so would appreciate any help offered. Including someone that may be able to do it for me if I go ahead with the project.
thanks ahead of time
Sorry, I was reading the messages above about the 915 install and didn't notice this is the Bay Window blog. I still hope someone can help.
thanks
