puremanb Samba Member
Posted: Sat Mar 28, 2015 11:42 am Post subject: Fused number 1 main bearing, causes? |
Did a search and couldn't find a lot of info.
New 1915cc engine, break in went perfectly, a few minutes into the first test drive the bearing fused and stopped the car dead in it's tracks. All clearances were in spec, spun freely at all points in the build, oil pressure was good.
Case was line bored .5mm.
All the bearing wear is concentric around the dowel pin side.
Is it possible that the line bore reduced the dowel pin clearance just enough to cause a small raised point on the bearing?
Should I file off a bit of the dowel for the next rebuild? |
jason Samba Member
Posted: Sat Mar 28, 2015 11:51 am Post subject: |
Yes. They must be measured. It probably pushed the bearing over reducing the clearance to zero. Enough to turn freely, without space for oil it fused. |
Posted: Sat Mar 28, 2015 12:08 pm Post subject: |
jason wrote: |
Do dowel pins have any specs? The pins are the only thing I didn't think to measure. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3295 Location: SOUTH DAKOTA
Posted: Sat Mar 28, 2015 12:33 pm Post subject: |
You can measure the depth of the hole in the bearing and measure how far the pin sticks out of the block. Probably good to have a little clearance there.  _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Bajaman65 Samba Member
Joined: January 16, 2007 Posts: 469 Location: Borrego Springs
Posted: Sat Mar 28, 2015 12:41 pm Post subject: |
It's easy to check the pin, just measure how high it is and compare it to how deep the hole in the bearing is. There are usually a few things that cause a bearing to freeze onto the crank, No Oil, not enough Oil, End Play to tight or the wrong size bearing. If it turns freely as assembly then you probably do not have a pin problem, but Never Rule It Out! Sorry that happened to your new engine. I am sure you will figure it out and let us know.  |
modok Samba Member
Joined: October 30, 2009 Posts: 27662 Location: Colorado Springs
Posted: Sat Mar 28, 2015 10:50 pm Post subject: |
if the clearance was in spec........ then what was it? |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1338 Location: miami florida
Posted: Sun Mar 29, 2015 7:56 am Post subject: |
modok wrote: |
That's what im thinking ?? OP first post says everything was in spec so ?? _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
modok Samba Member
Posted: Sun Mar 29, 2015 8:59 pm Post subject: |
It's usually caused by being too tight.
As the case heats up torque on the main bolts goes UP, and it clamps the crank.
Was it just too tight or oval or a high spot?? could be lots of things |
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23950 Location: SHALIMAR ,FLORIDA
Posted: Sun Mar 29, 2015 9:14 pm Post subject: |
I would guess wishful endplay.as in less than .003 in reality but pushed hard enough or deflection showing more than .003" add some heat and grab!! or something went through the oil gally&restricted the oil to that main. or some other stupid mistake/over sight.like hmm I dont recall but isant that rear bearing fed through the gally that almost gets pluged off when the rear main gally is taped&pluged......toofar inward.... a restriction there will show good oil pressure but the flow is reduced.even sealer can block it enough. if you have it all appart you can look at everything and find exzactly what did it.thats if you have the ability to do so. |
