HELP brand new engine doesn't crank once installed!
Combinations
Combinations is offline
PostPosted: Wed May 13, 2015 6:19 pm    Post subject: HELP brand new engine doesn't crank once installed! Reply with quote
Guys I just put back my new engine ( refurbished that was tested on a bench ) in my 1976 bay.
It seems the engine is stuck. The starter works great, very powerful, battery is fully charged, I hear the starter trying to move the motor but it won't budge.
I pulled the starter again tonight to turn the engine by the flywheel and it wouldn't move, I also tried turning the crank bolt with no success.
Should I try to push it down the driveway and pop it into first hoping that it will turn?
Do you think something could have been stuck inside?
Is there something that I could have missed once I put the engine back in the bay?
If you have some advice, let me know.
THanks
Aurel
aeromech
aeromech is offline
PostPosted: Wed May 13, 2015 6:30 pm    Post subject: Reply with quote
loosen the engine mount bolts and start backing the engine out of the transmission. As you do this keep trying to rotate the crank with a wrench. At some point it should start turning.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Combinations
PostPosted: Wed May 13, 2015 6:33 pm    Post subject: Reply with quote
Good idea, but how will it make it turn once I tighten back the engine bolts?
It was turning freely before being installed.
aeromech
aeromech is offline
PostPosted: Wed May 13, 2015 6:39 pm    Post subject: Reply with quote
Something is jammed. Just try what I told you and see what happens
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Combinations
PostPosted: Wed May 13, 2015 6:43 pm    Post subject: Reply with quote
Ok will try that, Hope I won't discover a forgotten wrench inside!
Anyone had the same thing happening?
aeromech
aeromech is offline
PostPosted: Wed May 13, 2015 6:44 pm    Post subject: Reply with quote
yep
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Tcash
Tcash is offline
PostPosted: Wed May 13, 2015 7:29 pm    Post subject: Re: HELP brand new engine doesn't crank once instaled! Reply with quote
Type 1 or 4 engine?
Transaxle 002 or 091?
Did you buy a new starter?
X2 on backing off the mounting bolts.
Good Luck
Tcash
Combinations
PostPosted: Wed May 13, 2015 7:32 pm    Post subject: Reply with quote
Type 4 engine
Brand new starter
Transaxle, I don't know The engine was the original one refurbished.
Tcash
Tcash is offline
PostPosted: Wed May 13, 2015 8:24 pm    Post subject: Reply with quote
Make sure you have the right starter.
http://www.thesamba.com/vw/forum/viewtopic.php?t=601250&highlight=starter
Pull the plugs so you are not fighting the compression.
Good Luck
Tcash
Combinations
PostPosted: Wed May 13, 2015 8:38 pm    Post subject: Reply with quote
i will remove all spark plugs, I wonder if it could come from the a too thick clutch disk?
swavananda
swavananda is offline
PostPosted: Wed May 13, 2015 9:14 pm    Post subject: Reply with quote
Your old fly wheel or refurbished one ?
This happened to me long time ago so i am a little fuzzy on details.......swapping engines on a late bay and it would stick when tightened, lots of head scratching and cursing....... turns out the bus had the transaxle swapped out some time in the past with a 75 ish -215mm ? so the swapped engine with the 228 flywheel dug in. something easy to check and eliminate
Combinations
PostPosted: Wed May 13, 2015 9:29 pm    Post subject: Reply with quote
I don't know if the flywheel is original or not. Could the flywheel touch the bell housing on the teethe side or could it be to thick in length?
How do I know which flywheel goes with which transmission?
Tcash
Tcash is offline
PostPosted: Wed May 13, 2015 9:41 pm    Post subject: Reply with quote
Trans in neutral would not matter.
Tcash
Wildthings
Wildthings is offline
PostPosted: Thu May 14, 2015 3:18 am    Post subject: Reply with quote
I would suspect that this might be the problem. The 228mm clutch will not fit inside the early bellhousing unless some clearancing has been done to the bellhousing. A picture of the starter drive on his old starter would help determine which bellhousing he has.
Combinations
PostPosted: Thu May 14, 2015 5:56 am    Post subject: Reply with quote
A lot of interesting info here thanks guys.
So if I understand it could be one of these element right:
1) The flywheel is too thick and touches the back of the bell housing
2) The flywheel's diameter is to big and touches the inner sides of the bell housing
( but it seems that the starters fits perfectly)
3) The clutch is to thick and make the pressure plate touches somewhere
How come that I can tighten the engine to the bell housing and that it fits perfectly, Are we talking about a few milimeters difference that make the flywheel touch?
In this case can swap the flywheel for a model that would fit the bell housing?
Tcash
Tcash is offline
PostPosted: Thu May 14, 2015 7:59 am    Post subject: Reply with quote
The flywheels are the same. The clutch pressure plate and disc are what is bigger.
The clutch not too thick. The pressure plate is too big around.
It will bolt up. Time to loosen the engine mounting bolts as suggested.
Again not the flywheel.
Loosen the mounting bolts and turn the engine. It may just be in bind.
Good luck
Tcash
deronmoped
deronmoped is offline
PostPosted: Thu May 14, 2015 8:39 am    Post subject: Reply with quote
Take a breaker bar to the crankshaft pully bolt and give it wrench. See how much effort is needed to turn the engine.
Hydraulic lock, something binding in the engine or clutch or alternator/fan.
tristessa
tristessa is offline
PostPosted: Thu May 14, 2015 8:42 am    Post subject: Reply with quote
You're assuming that it isn't in gear.
Not that I've ever made such a rookie mistake, oh no... Embarassed
Wildthings
PostPosted: Thu May 14, 2015 9:44 am    Post subject: Reply with quote
Assuming its an interference issue, the problem isn't going to be the flywheel or the thickness of the clutch disc. The problem is the shape of the larger 228mm clutch cover. VW redesigned the bellhousing when they went to the large clutch to prevent interference so if you have an earlier bellhousing, the clutch cover and bellhousing will bind against each other.
You can either replace the flywheel and the entire clutch assembly or replace the bellhousing. As I mentioned above post a picture of the drive on your original starter. It is also possible to clearance the earlier bellhousing and get the setup to work.
SGKent Premium Member
SGKent is offline
PostPosted: Thu May 14, 2015 12:00 pm    Post subject: Reply with quote
I agree here that there is a high probabiltiy that the flywheel is hitting the trans. I would pull the engine back out before trying further to turn it before you break something. When things bind because of a misfit, applying force is always a bad idea.
You should see teeth marks on the inside of the bell housing if the issue is that. Check the end play on the engine again while it is out to be sure the binding hasn't damaged the thrust area.
Also - 228 mm bus flywheels are cast - they can break with excessive force.
George Carlin:
Skills@EuroCarsPlus:
1971 deluxe (sold)
1977 deluxe
