RevMaster 049 Heads
Page: Previous  1, 2, 3
mark tucker
mark tucker is offline
PostPosted: Wed Nov 20, 2013 3:02 pm    Post subject: Reply with quote
how do you see them as the same castings?& I wonder just how much revmasters did as far as "developement",
Junkyardjockey
Junkyardjockey is offline
PostPosted: Mon May 25, 2015 12:01 pm    Post subject: Reply with quote
How would these RM 049 non-ported heads work with a stock 1600DP, flat top pistons, 34pict3 carb & stock heater boxes?? I'm about ready to make the drop on these heads; but I hear there may be issues with using stock heater boxes with larger than stock exh. valves; what's behind that theory?? Should I swap out the hi-rev springs that are in these with stock springs with my stock cam? Thanks!
Ken
Romans 10:9
MURZI
MURZI is offline
PostPosted: Mon May 25, 2015 12:03 pm    Post subject: Reply with quote
I'd keep stock valve size on a 1600(even with a larger cam) Larger valves make the bottom end soggy. Been there done that.
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
Junkyardjockey
PostPosted: Mon May 25, 2015 12:09 pm    Post subject: Reply with quote
Mmmmm thanks for the tip Murzi! I def. want 3/4" reach plugs in my new heads; I was considering ACN's L3 heads, but John says the combustion chambers (59cc) are too large in his opinion for a bone stock 1600DP; he suggested having his heads machined to 51cc, what do you think about that? Is there a new head out there now with 3/4" reach plug, small comb. chamber & stock valve size? And thanks again!
Ken
Romans 10:9
MURZI
MURZI is offline
PostPosted: Mon May 25, 2015 12:14 pm    Post subject: Reply with quote
I agree. Most smaller builds I use 47-49cc flycut heads to bump compression. Depends on the cam. With a stock cam 51cc would be about right assuming a stock .055 deck.
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
[email protected]
john@aircooled.net is offline
PostPosted: Mon May 25, 2015 12:39 pm    Post subject: Reply with quote
Flycutting the L3 heads are fine.
Or get
http://vwparts.aircooled.net/OEM-VW-35-x-32mm-Dual-Port-Cylinder-Head-EACH-p/oem-cylinder-head.htm
It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net
Brian_e Premium Member
Brian_e is offline
PostPosted: Mon May 25, 2015 12:41 pm    Post subject: Reply with quote
I would get these and have them flycut to get your compression right with a .050" deck height. Really good heads for the money. Have them cut for 90.5 when ordering and then run AA thick wall 88mm's that will slip into the stock case.
http://www.aapistons.com/collections/stock-perform...ad-35-5x32
Junkyardjockey
PostPosted: Mon May 25, 2015 1:10 pm    Post subject: Reply with quote
Or get
hello again John! I have almost made up my mind to get your heads; about the only really good heads out there with 3/4" reach plug holes & stock valve sizes. Since I won't be able to measure the deck height just yet , I am trying to get as close to stock specs as possible; maybe bump up the CR a little bit & still keep the stock cam, I don't think I need or want more than 8:1 CR. Question for you John: what kind of time frame we looking at here if I order your L3's & have the chambers cut to a particular cc? I would get those heads in that link above if the plugs were 3/4" reach! Thanks again!
Ken
Romans 10:9
[email protected]
PostPosted: Mon May 25, 2015 2:50 pm    Post subject: Reply with quote
Head CCing takes 2-3 days.
Do your math with a DH of ~.055". If you are +-.010" it's not a big deal, and won't change the CR enough to be significant. The OE heads are not 3/4" reach plugs, the other ones are though.
Junkyardjockey
PostPosted: Tue May 26, 2015 8:00 am    Post subject: Reply with quote
Thanks John for your help! One other concern I have: your heads have single hi-rev springs; are those going to affect the stock cam, lifters, pushrods & rockers in a negative way? Thanks!
Ken
Romans 10:9
BajaDirtMx
BajaDirtMx is offline
PostPosted: Tue Aug 14, 2018 3:49 pm    Post subject: Re: RevMaster 049 Heads Reply with quote
Hi Guys!
Any update on this topic?? I´m planning to buy this heads-
http://www.revmasterautomotive.com/product-page/049-echamber-44x37-5-94mm-bore-each
Regards,
<G.A.
67rustavenger
67rustavenger is offline
PostPosted: Tue Aug 14, 2018 5:03 pm    Post subject: Re: RevMaster 049 Heads Reply with quote
BajaDirtMx wrote:
Hi Guys!
Regards,
<G.A.
Why are you ignoring the advice of the pro engine builders from your "cam advice" thread?
You had sound advice from at least three of the people I listen to.
I have no idea about rev-master 049 heads.
But I do know that Tim's head work comes well recommended. They start with an AA 043 blank head and complete the package with their own parts.
https://www.performanceworkshop.net/cylinder-heads
Take a look and then decide.
Good Luck.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Page 3 of 3
