Stumped by a smokey wire
Pacmanfever
Pacmanfever is offline
PostPosted: Thu Jun 11, 2015 1:31 pm    Post subject: Stumped by a smokey wire Reply with quote
My son's 67 always starts right up and has been extremely reliable, a couple weeks ago I started it to warm it up, it ran about a minute and died, which it has never done before. It would crank over fine, but not restart so we went for the basics- spark, fuel, etc. Not getting a spark, we replaced the points and condenser, and coil for good measure.
It started right up! But after running for a couple of minutes we began to see smoke coming from near the steering column. We shut it down and disconnected the battery cable. The smokey offending heavy wire appears to be coming from the ignition switch area and it's getting overheated, but no fuses have blown.
Any ideas as to why this wire would start overheating suddenly? Resistance in the ignition switch maybe? Stuck relay? Aliens? I don't see any smoking gun like a chaffed or burnt wire grounding out so far.
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Thu Jun 11, 2015 1:49 pm    Post subject: Reply with quote
ignition wire grounded in the engine compartment
1958 custom camper
http://www.thesamba.com/vw/forum/viewtopic.php?t=483656
1957 oval
http://www.thesamba.com/vw/forum/viewtopic.php?t=426468&postdays=0&postorder=asc&start=0
1957 dd kombi
http://www.thesamba.com/vw/forum/viewtopic.php?t=186478&highlight=
xcoldgrimjimx
xcoldgrimjimx is offline
PostPosted: Thu Jun 11, 2015 3:00 pm    Post subject: Reply with quote
Hello dude or dudette it sounds like the ignition is sticking in the (fire up) position. When you go to start it the spring back is not working properly in a sense STAYING HOT so try dissembling the ignition.. or a simple way is to keep ALL POWER OF YOUR BUS! BATTERY DISCONNECTED ! and simply turn the key. If it just doesn't feel right ( springing back like it should normally) on its own. Than you have your problem. It doesn't hurt to trace this from the start and go back (can't go Wong that way Wink ) let us know Very Happy
ya it's rusty...but it's MINE!!!!!
telford dorr
telford dorr is offline
PostPosted: Thu Jun 11, 2015 3:53 pm    Post subject: Reply with quote
Note that power flows from the ignition switch (D) via the black wire to the top of the 7th fuse, then continues to the engine coil. After that, it goes to the choke heater and the idle solenoid on the carb.
ALL of these wires (for some inane reason only VW knows) are UNFUSED.
Thus, if there's a short anywhere in this circuit, you'll get smoke.
Check all black wire connections and devices for shorts or other issues.
I built and use this as a big test light:
Disconnect the battery '+' terminal, and connect the big test lamp between the battery '+' post and the disconnected wire. If there's a short in the ignition circuit, with the key on the lamp will light. To find the short, wiggle / disconnect wires until the lamp dims or goes out.
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
Pacmanfever
PostPosted: Thu Jun 11, 2015 6:53 pm    Post subject: Reply with quote
You guys are amazing, thanks for all the detailed info. I'll tackle this issue in the morning, we've got thunderstorms rolling in right now.
I'll be sure to post a follow up.
Ran When Parked
Ran When Parked is offline
PostPosted: Thu Jun 11, 2015 7:38 pm    Post subject: Reply with quote
Pacmanfever wrote:
You guys are amazing, ...
So true.
jason
jason is offline
PostPosted: Thu Jun 11, 2015 9:57 pm    Post subject: Reply with quote
I say resistance. I'm always tracing wires at work that are melted because of a loose wire nut. If it was stuck on you'd hear the starter. Unless he means slightly open and there is a bunch of resistance in the ignition. Just measure across the terminals with an ohmmeter.
Pacmanfever
PostPosted: Fri Jun 12, 2015 9:07 am    Post subject: Reply with quote
Here's a quick update: I checked the ignition switch and it springs back properly from the start position to the run position. It does feel a little loose between the off and run positions, but I don't have anything to compare it to.
So I moved the speedometer out of the way to get a good look at the wiring that was overheating, and discovered one terminal of the ignition switch is blackened, which I'm going to guess is the source of our car-be-que.
The tape was left on there as an identifier when I removed the speedometer to freshen it up, it's not serving duty as in insulator.
So now the question is it internal resistance in the ignition switch? Loose terminal rivet? Or overloading on that line that's causing failure at the point of greatest resistance?
Here is the backside of the switch and the offending terminal:
slow36hp
scott wimberley
slow36hp is offline
PostPosted: Fri Jun 12, 2015 9:38 am    Post subject: Reply with quote
looks like the ignition wire is cooked look in your engine bay at the wiring going to and coming from the + side of the coil
1958 custom camper
1957 oval
1957 dd kombi
