IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10357 Location: N. Idaho
Posted: Fri Jun 12, 2015 9:29 pm Post subject: Where is the cool diagram someone made for the WBX engine? |
Someone made a cool diagram of the WBX, showing the firing order, engine rotation, timing info and a couple other things useful on the side of the road. Anyone have a link to it? If I recall correctly, it showed a line drawing view of the engine from above, identifying cylinder #1, etc.
I wanted to print and laminate a copy and attach it to the top of the engine cover in a clear slip cover. Under the stress of a roadside breakdown, that info can be important. I was going to add routine engine info like NAPA part numbers for belts, oil filter, spark plugs, fuel filter, air filter and a bunch of other stuff for a quick reference guide.
Thanks! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
msewalson Samba Member
Joined: September 14, 2009 Posts: 544 Location: Grand Junction, Colorado
Posted: Fri Jun 12, 2015 9:37 pm Post subject: |
MODERATOR NOTE: The images below showing the Distributor rotation as counter clockwise is WRONG!!!!!
When the engine runs, the Distributor rotates Clockwise!
1432
Is this it? I think I pulled it off of Ben's site.
Matt _________________ 87 Syncro w/EJ22 |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12378 Location: Santa Cruz, CA
Posted: Fri Jun 12, 2015 10:09 pm Post subject: |
Timwhy's
Pete000's
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6933 Location: Fort Lauderdale, Fl.
Posted: Sat Jun 13, 2015 4:27 am Post subject: |
That can't be right...who's got an engine that clean and shiney?😆
note that it is an air cooled, I forget if the notches on pulley are the same. |
Posted: Sat Jun 13, 2015 8:31 am Post subject: |
True! The block looks gold anodized!!
Those are good ones. Seems like there was another with some other useful WBX trivia on it..? _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
riceye Samba Member
Joined: March 09, 2006 Posts: 1712 Location: Caledonia, WI
Posted: Sat Jun 13, 2015 9:04 am Post subject: |
Ben has lots of great pics and drawings on his awesome website.
www.benplace.com/vw2.htm _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
kamzcab86 Samba Moderator
Posted: Sat Jun 13, 2015 10:07 am Post subject: |
_________________ ~Kamz
2016 Golf GTI S
delta9007 Samba Member
Joined: March 17, 2008 Posts: 106 Location: Arcata,CA
Posted: Sat Jun 13, 2015 11:13 am Post subject: |
I'm confused. MS shows an aircooled with the distributor turning anti-clockwise and Kamz shows it going clockwise. _________________ '89 2wd, 4spd, 2.1 Westfalia. |
Posted: Sat Jun 13, 2015 11:44 am Post subject: |
Aircooled cars have the same firing order. That aircooled picture shows the crankshaft being turned backwards for some reason. The only time that makes sense to do is when you are adjusting the valves and you don't want to go from side to side but if you start on the 4/3 side rather than starting at the top of the firing order it isn't a issue.
Merian Samba Member
Posted: Sat Jun 13, 2015 12:01 pm Post subject: |
dwell, not dwel |
Posted: Sat Jun 13, 2015 12:10 pm Post subject: |
Merian wrote: |
dwell, not dwel |
Yeah, he fixed it. I just posted the wrong image
buspor63 Samba Member
Joined: February 17, 2005 Posts: 1179 Location: Knoxville,TN Where America stops for gas
Posted: Sat Jun 13, 2015 8:46 pm Post subject: |
Any number of those would make great T shirt art hint hint _________________ Imagine that, theres not an "h" in either Westfalia or Syncro? |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8476 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Thu Jun 25, 2015 11:52 am Post subject: |
buspor63 wrote: |
Any number of those would make great T shirt art hint hint |
x2
I'll take a timwhy on black in L...???
 _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
atomatom Samba Member
Joined: May 15, 2012 Posts: 1911 Location: in an 84 Westy or Bowen Island, BC
Posted: Thu Jun 25, 2015 4:11 pm Post subject: |
yeah, but you have to print it upside down, so you can look down at it. _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
Posted: Thu Jun 25, 2015 4:13 pm Post subject: |
"The WonderVan"
