Fred Mintert Samba Member
Posted: Thu Jul 02, 2015 4:05 pm Post subject: turn signal problems |
I have a 78 bus and I am having some problems identifying why my turn signals wont work.
I have tried several things the Bentley suggested and have no idea why. Here is what happens: When I hit the right signal, the dash light comes on but no flashers. When I hit the left turn, nothing happens.
I have tried a new flasher relay, no results.
I have inspected all the bulbs, they are all good.
I have checked the fuse, it is intact. I wiggled it around too, and no change.
I have pulled the steering wheel and visually inspected the turn signal mechanism and see no problems.
I pulled the plug and tested the connections with scrap wire and got the same results as the current function, (right turn makes dash light, no signal, left nothing) which leads me t believe the mechanism is okay.
I put the meter on the fuse heads and didn't get any perceivable change.
Thoughts? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53265 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jul 02, 2015 4:08 pm Post subject: |
Reach up under the dash and snap the hazard switch back together (plastic part with wires into metal case), then put a zip tie around it so it doesn't come apart again. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jul 02, 2015 4:20 pm Post subject: |
| used a mirror to check all the connections (6 ) on hazard switch. all are connected. I forgot to mention in the initial post that the hazard was not working either. |
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Thu Jul 02, 2015 4:36 pm Post subject: |
it's basic, but make sure you have the right bulbs in the right places. A one-way contact bulb in a two-way contact slot (or vice versa) has given my bus some strangeness in the past (like the e-brake light shutting off when the e-brake is pulled and turning on when it's released) _________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com |
Posted: Thu Jul 02, 2015 4:49 pm Post subject: |
| Fred Mintert wrote: |
Don't look for wires coming off, look for the switch itself separating.
| Fairview wrote: |
So when I looked up under the dash at the backside of the hazard switch, I could see that it was coming apart. I took it completely out, cleaned up all the contacts with electrical cleaner, reassembled and squeezed the case as it should have been. (If you are faced with this, be sure not to lose the ball bearing, which I think is the detent for the switch.) Now I have all my lights going!
Here's a couple photos to show how it looks when it comes apart. Look carefully at the one of the case, you'll see the little ball bearing near the Phillips screwdriver. You'll need to keep track of that and reinstall.
Jeff
Слава Україні! |
Fairview Samba Member
Joined: August 17, 2010 Posts: 147 Location: Waynesboro, Virginia
Posted: Thu Jul 02, 2015 5:19 pm Post subject: |
| Busdaddy's advise on this got me to investigate the hazard switch. Otherwise I would not have noticed that the hazard switch was coming apart. Take a good look at yours as it most likely is the culprit. |
Posted: Thu Jul 02, 2015 6:05 pm Post subject: |
| upon closer inspection, I have already zip tied the hazard switch a couple year back and it is tight. |
Posted: Thu Jul 02, 2015 6:58 pm Post subject: |
OK then, make sure 15 (aka+) on the hazard switch has power when the key is on and 49a on the signal switch has power from the relay, next start probing the individual wires at the fixtures, could be a whole bunch of bad grounds. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Jul 03, 2015 12:36 pm Post subject: |
| Great news! It was the flasher relay. I had replaced it with one from autozone, but it must also have been the faulty. I went to a friends house and he pulled a relay out of a 73 and it worked! Problem solved.... thanks bus daddy and everyone! |
EasyRiderVW Samba Member
Joined: July 01, 2015 Posts: 21 Location: Slatington, Pa 18080
Posted: Sun Mar 06, 2016 10:11 am Post subject: Re: turn signal problems |
Fred does the flasher relay that works have 3 prongs or 2?
I have no hazard flash on the rear lights. |
