Shocks?...
ClipperBuggy
ClipperBuggy is offline
PostPosted: Tue Jul 21, 2015 4:42 pm    Post subject: Shocks?... Reply with quote
Looking to replace the shocks on my "let's call it a 1964 Beetle Buggy"
the front end is king&link pin. so for all intensive purposes, it's a '64 I'm working with for this task.
The front passenger side bobs up and down at relatively low speeds. there is significant rust on the front shocks. so to try and fix the bob & sway while driving. I'm thinking replacing the shocks in at least the front, is the next attempt to fix this.
currently my ride height is stock.
Previously I had to do significant adjustment to my steering box to get the play out.
I want to know what is a good, not most expensive, but best bang for the buck shock I can pick up?
I would like to keep it around or under $60 per shock.
I have read through many forum posts and haven't found an answer to my question.
I believe I'm going to stick with gas shocks as it seems there isn't much advantage to switching to coil over, air, or oil that I have found...
Basic run down:
-Stock ride height
-Front end is super light! gas tank is in the rear (another issue to tackle later)
-exclusively pretty much street driving. So looking for something with a little more of a softer ride I'm thinking.
I appreciate you taking the time to read my post.
Share more: https://www.facebook.com/CaliforniaClipperDuneBuggy
didget69
didget69 is offline
PostPosted: Tue Jul 21, 2015 4:49 pm    Post subject: Reply with quote
Stock oil filled shocks for KP frontend. No coilovers. No gas filled shocks. Lower your front tire pressures.
bnc
I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door.
Dale M.
Dale M. is offline
PostPosted: Tue Jul 21, 2015 5:56 pm    Post subject: Reply with quote
bnc
Ditto.....
Dale
impaleale
impaleale is offline
PostPosted: Tue Jul 21, 2015 6:58 pm    Post subject: Reply with quote
I run gas shocks up front. They are pretty soft, It's the same a firebird had I think. You can use gas shocks but your front beam has to of had a few leafs taken out. It's a fair chunk of work but awesome in the long run. I have 30psi in my tires and a very light gas shock and my buggy handles great.
jspbtown
jspbtown is offline
PostPosted: Tue Jul 21, 2015 7:03 pm    Post subject: Reply with quote
Last time I bought them I think NAPA had some nice cheap oil filled shocks.
For your application its the way to go. With the air pressure reduction as mentioned.
didget69
didget69 is offline
PostPosted: Wed Jul 22, 2015 9:18 am    Post subject: Reply with quote
Key Point:
What is deemed as being a 'comfortable ride' & 'it handles great' to one person is not the same perspective as it is to another person.
Basic Point: No gas-filled shocks in front & no coilovers or fake coilover shocks on the front suspension. Ever. It stiffens the front suspension.
If you're going to remove leaves, do it 'properly', and not half-assed. There are a few variations on the theme.
bnc
LeeVW
LeeVW is offline
PostPosted: Wed Jul 22, 2015 9:30 am    Post subject: Reply with quote
I would like to cast another vote for cheap oil (non gas charged) shocks.
Lee
ClipperBuggy
PostPosted: Wed Jul 22, 2015 10:09 am    Post subject: Reply with quote
Found these, but can't tell if they are oil or not.
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=RR_94095_0484291759
I contacted NAPA but they didn't seem to know either.
jspbtown
jspbtown is offline
PostPosted: Wed Jul 22, 2015 10:47 am    Post subject: Reply with quote
The MSD they attached to the product suggests that they are.
You can always take a look at them. I am relatively confident (someone please correct me if I am wrong) that gas "charged" shocks come with them banded in a compressed mode and when released they expand. Oil shocks do not expand.
didget69
didget69 is offline
PostPosted: Wed Jul 22, 2015 6:13 pm    Post subject: Reply with quote
Some suppliers carry COFAP OE replacement shocks... typically used on Brazilian market, & maybe on Mexican made Beetles. German OE shock absorbers would have usually been Boge brand.
http://www.busdepot.com/113413031bbr
bnc
ClipperBuggy
PostPosted: Fri Jul 24, 2015 5:42 am    Post subject: Reply with quote
Thinking of going with
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111413031G
in the front
and in the rear:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111513031G
Thinking these must be oil filled?
ClipperBuggy
PostPosted: Fri Jul 24, 2015 5:46 am    Post subject: Reply with quote
bnc
Those are Oil Filled you think?
didget69
didget69 is offline
PostPosted: Fri Jul 24, 2015 5:53 am    Post subject: Reply with quote
in the front
and in the rear:
Most likely oil filled. I'd Contact WW and ask.
bnc
ClipperBuggy
PostPosted: Sun Aug 02, 2015 2:35 pm    Post subject: Reply with quote
Went with Wolfsberg West shocks front and rear.
Fronts fit perfect. installed no problem.
Rear's (The red ones) do not seem to let the top bolt fit through it.
The bottom stationary mount point fits, but the bolt on the top (that fits the frame correctly, does not fit through the top shock mount hole.
This is the one I'm having trouble with: http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=111513031G
Thoughts anyone?
didget69
didget69 is offline
PostPosted: Sun Aug 02, 2015 2:40 pm    Post subject: Reply with quote
Thoughts anyone?
Measure the OD of bolt & ID of upper shock mount sleeve. Contact WW. Have WW verify which shock absorber P/N you need based on upper/lower bolt OD.
bnc
Dr OnHolliday
Dr OnHolliday is offline
PostPosted: Sun Aug 02, 2015 9:00 pm    Post subject: Reply with quote
Stock. AutoZone. $20 each.
1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust
