Estacaco Samba Member
Joined: October 16, 2014 Posts: 105 Location: Dryden, Ontario Canada
Posted: Thu Jul 23, 2015 9:07 pm Post subject: Early Bay Ignition Re-key |
Is there any info out there about re-keying an ignition for an early bay? Found info on re-keying a late bay ignition but they are too different beasts.
Thanks! |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12846 Location: San Jose, California, USA
borninabus  Samba R&D Dept.
Joined: May 18, 2006 Posts: 4723 Location: Arizona Highways
Posted: Thu Jul 23, 2015 9:59 pm Post subject: |
it would be easier, IMO to work the other direction.
rekey the doors to match the ignition. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Tcash Samba Member
Posted: Thu Jul 23, 2015 10:05 pm Post subject: |
I've looked through that thread. lists said link to late bay ignition and covers all sorts of doors and hatches but not early bay ignition. |
Posted: Thu Jul 23, 2015 10:18 pm Post subject: Rekeying ignition lock |
Here's how it's done.
File down the two bronze pins. they've been mushroomed to keep the ignition/cylinder together. May also need to pry a bit with a screwdriver.
Removed.
Remove these shims. They keep the wafers from popping out. It's also been peened in. I filled the inner edges of the groove then tapped the under side of each wafer with a small flat head and hammer. Then pushed them backwards with the same flat head.
Once the shims have been removed you can change the wafers.
Reinstall reverse of diss-assembly. Pound the end back on put a dab of JB weld over each bronze pin.
Now my MK2 Golf and T2 Bus share the same key. |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 13478 Location: West Coast, USA
Posted: Thu Jul 23, 2015 11:47 pm Post subject: |
Estacaco, what year is your bus? I don't remember an early (68-70) L-code ignition tumbler working like that. Did you change key profiles? I'm really confused how you got that done in an hour, because now isn't your whole bus multiple keys anyway? _________________ One-on-one tech help for your vintage Volkswagen:
www.airschooled.com
https://www.patreon.com/airschooled |
Posted: Fri Jul 24, 2015 12:03 am Post subject: |
My bus is a 69. I lost the key, I will be rekeying the other locks to match. I did not change key profiles. It appears that they used the same key wafers in 85-92 golf's and jetta's.
asiab3 wrote: |
I'm really confused how you got that done in an hour |
I'll take that as a compliment!
Brian Samba Moderator
Posted: Fri Jul 24, 2015 12:20 am Post subject: |
Robbie, if you want to see it for yourself then do mine  _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Tcash Samba Member
Posted: Fri Jul 24, 2015 11:24 am Post subject: |
Estacaco wrote: |
Well I'm amazed.
It is in there now.
Thank you
Tcash |
Posted: Fri Jul 24, 2015 2:17 pm Post subject: |
Haha thanks. I aspire to be as useful was you Tcash! |
