jz56oval Samba Member
Joined: September 03, 2007 Posts: 379 Location: bay area
Posted: Thu Jul 30, 2015 3:33 pm Post subject: 36 hp rebuild info |
Hi
Does anyone have a thread/ post that goes through each step to tear down a 36 hp? Anything that has pictures and detailed steps? Im thinking it isn't exactly lke a 1600 tear down and rebuild.
Thanks |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
my59 Samba Member
Joined: August 13, 2003 Posts: 4018 Location: connecting the dots
Posted: Thu Jul 30, 2015 3:44 pm Post subject: |
You would have to search for the thread if it exists.
I used the Wilson book on rebuilding VW engines and cross referenced it with the VW shop manual when I did my type 4 engine along with serious study here on threads dealing with specific parts of the build.
I would do the same on a 36 hp, and the advantage I have on it is owning an original shop manual although I hear the Bentley reprint is good too. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget. |
Gwdghiaguy Samba Member
Joined: December 06, 2013 Posts: 340 Location: Greenwood, SC
Posted: Thu Jul 30, 2015 4:26 pm Post subject: |
The 36hp rebuild articles from VW Trends are very good; I just completed mine using this and it was very helpful. The only thing is in section 4 step 15 where he says to leave the thermostat bolt loose and worry about tightening it later, I couldn't get to the bolt later with my heater boxes installed; had to reach in with needle nose pliers and I don't think I got it as tight as I'd like. I think next engine I will raise the tstat bracket as far as it goes and tighten it down, then after I install the air control ring, adjust the ring to it's 20mm spacing and I'm done. I searched for air control ring adjustment and found that procedure somewhere. Good luck with your rebuild. byron _________________ 1957 Oval Window
1963 Alabama Camper Bus
1971 Ghia
1971 Baywindow Bus
Posted: Thu Jul 30, 2015 5:49 pm Post subject: |
| Thanks to all you for the info and help. I'll start reading up on it. |
Snort Samba Member
Joined: April 02, 2005 Posts: 1977 Location: Seattle, WA
Posted: Fri Jul 31, 2015 6:44 am Post subject: |
| That procedure on the thermostat bracket is misleading and the bracket the article shows is wrong. There is no adjustment on the correct 36hp bracket, it all happens at the control ring. |
Posted: Fri Jul 31, 2015 7:25 am Post subject: |
| Snort wrote: |
Mine only moved quarter inch or so; I figured that was what he was talking about. I noticed my bracket wasn't exactly like the one in the article. Is it because he was working on a 54 engine? Thanks for the info. Byron _________________ 1957 Oval Window
1971 Ghia
1971 Baywindow Bus
Last Triumph Samba Member
Joined: October 10, 2006 Posts: 915 Location: Wirral, United Kingdom
