lojoma Samba Member
Posted: Fri Aug 14, 2015 3:43 am Post subject: What year is my car? |
I just bought at '63 Deluxe Beetle. According to the VIN number, it was made in August of 1962.
So do I really have a 1962 or a 1963?
For example, 1963 cars see to have heater outlets under the rear seat, but 1962 models do not. But I am figuring when it was sold, it was rolled out for the 1963 sales year so it's called a '63.
Just want to make sure that I know what I have when ordering parts, etc. I know many parts span lots of years but there are many, of course, that don't.
Thanks.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11486 Location: Oregon
Posted: Fri Aug 14, 2015 5:00 am Post subject: |
1963 Following year production began in August of the privious year.
Welcome aboard. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4658 Location: Whittier 90602
Posted: Fri Aug 14, 2015 5:03 am Post subject: |
According to one book I have, '63 production ran from Aug 1 '62 to Jul 31 '63.
Does it have it's original engine? On Dec 15 '62 they upgraded the heating system with heat exchangers.
Does it have a coat of arms (Wolfsburg crest) on the hood? They dropped that on Oct 1 '62.
In either case they made minor running changes all during the year, so for most chassis parts like cables etc you're going to have to order by the chassis number anyway, so makes little difference what year you're going to call it. _________________ -Bruce
An ounce of prevention is worth a pound of cure. |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13957 Location: White Mountains Arizona
Posted: Fri Aug 14, 2015 6:42 am Post subject: |
If it was on the parts shelf when it came down the line that is what was installed on the car.
Add some photos in your gallery, its always a big help.
You are on the best VW site period. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
lojoma Samba Member
Posted: Fri Aug 14, 2015 8:39 am Post subject: |
It does have the crest on the hood. It does not have heat outlet under rear seat. The heat does work.
The engine is a '74 engine. (AH code).
I posted photos to my gallery for you to see. The car was restored about 15 years ago. Paint is good but not great, but the pans are in amazingly good shape and I can't find rust anywhere on this car. A few bolts here and there have light surface rust. Previous owner took very good care of it.
The photos have an aftermarket steering wheel, but he put the original back on when I bought it. |
stale air Samba Member
Joined: August 23, 2007 Posts: 5723 Location: Senoia Ga, formerly NorCal
Posted: Fri Aug 14, 2015 9:20 am Post subject: |
| lojoma wrote: |
No rear heater outlets what so ever?
It should have either these, through early 63...
Or these, mid 63- _________________ WANTED: Henry Veale Santa Rosa plate frames
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11205 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Fri Aug 14, 2015 9:21 am Post subject: |
Its a stale air early 1963.. which in reality.. is just a carry over 1962...
http://www.vw-resource.com/years.html
The 62-64 (Sedan) ID highlight reel..
| glutamodo wrote: |
| The last hood that had the Crest was at VIN / Chassis Number 5010447 |
| VOLKSWAGNUT wrote: |
3 bolts per hinge started during the 1962 model year.
| glutamodo wrote: |
Here' a few detail photos for 62-64 era ID:
Right side heater duct under back seat:
Hinge bolts:
Steering Box adjustment access plate:
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
lojoma Samba Member
Posted: Fri Aug 14, 2015 1:58 pm Post subject: |
Well...my heat ducts appear to have been removed some time ago!
The change to the '74 engine added fresh air heat. I guess they decided to push all the heat to the front for some reason.
I thought earlier ones didn't have outlets in the back because the '62 manual I looked at didn't mention adjustable flaps on those outlets like the '63 manual does, and I didn't see any on mine! Interesting. |
Posted: Fri Aug 14, 2015 3:23 pm Post subject: |
More information regarding Vw's first and poor attempt at rear floor heat..
http://www.thesamba.com/vw/forum/viewtopic.php?t=445797.
Change to fresh air rear tubes... and enjoy the roast... and ankle burners..
. _________________ aka Ken {o\!/o}
lojoma Samba Member
Posted: Fri Aug 14, 2015 5:15 pm Post subject: |
| Thanks for the info...very educational! As I mentioned, with the change to a newer engine it was upgraded to fresh air, so I think the heat will work well enough in the winter as is. Just surprised to find this interesting quirk of what I now know I have...a '62! |
Posted: Fri Aug 14, 2015 6:54 pm Post subject: |
| lojoma wrote: |
Your VIN # dictates the month and model year.. You claim Aug 1962... so wrong...its not a 1962....
If the VIN is after 4854999 and before 4932386 its August 1962....
August 1962 is a 1963 model year.
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6041 Location: Brooklyn
Posted: Fri Aug 14, 2015 7:15 pm Post subject: |
| lojoma wrote: |
No, you have a '63. However it's a very early '63 so you may find some of the stuff on your car is like '63 models and some is like '62 models. You will have to pay special attention to the parts book when ordering to make sure you get the right parts for your chassis number. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
h~moto Samba Member
Joined: November 19, 2008 Posts: 331 Location: Northern Virginia
Posted: Fri Aug 14, 2015 7:36 pm Post subject: |
If the VIN is from 4 846 836 to 5 677 118 then it would be a 1963.
If the VIN is from 4 846 836 to 4 854 999 it would be a `63 that was actually built in late July 1962. |
lojoma Samba Member
Posted: Fri Aug 14, 2015 8:18 pm Post subject: |
Thanks for the clarifications. I wasn't meaning that quite so literally...a "bridging" model with some parts 62 and some 63 is what I was trying to say.
The VIN is a 489* |
lojoma Samba Member
Posted: Sun Feb 12, 2017 6:20 pm Post subject: Re: What year is my car? |
Well, some disappointing news. My Bug's body doesn't match with chassis.
When I bought the car, my father did the transaction out of state so I wasn't there to confirm the numbers matched. The PO stated they matched. I would swear that I checked them when I got the car, but looking at them today, I see they don't actually match. Ugh. I think I must have seen the number on the chassis matched the number on the title and didn't look further. The chassis number matches the paperwork I have that goes back to when car was sold to second owner in '64.
The chassis number shows manufacture of late '62 and the body number shows as late '63. But the hood has the crest, which I think someone here said stopped after Oct 62 if I remember right. So I'm guessing the body had damage and they found a replacement but kept the old hood for the emblem (or somehow installed it).
Still love my Bug, but hate that it's not a matcher. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Sun Feb 12, 2017 6:56 pm Post subject: Re: What year is my car? |
Look for other clues as to what could have been done. My 64 doesn't have matching numbers, but the body has lots of original Java green as well as places that aren't typically gotten in a respray. Rear fenders have java green under the undercoating as well as behind the tar boards in the engine etc. My guess is the front section was replaced with that from a 63 and they just left the original body vin on it. I still need to drill out the body vin to see what color paint it behind it, but its way down my list of importance. Maybe something like this happened with yours as well? _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Posted: Sun Feb 12, 2017 7:13 pm Post subject: Re: What year is my car? |
While numbers matching is important from a legality standpoint.. it in no way should effect you enjoying it.
Importantly, If the papers match the pan (chassis) IMO knock the body tag off.. stick it in your tool box ..or.. and enjoy your car.. The chassis is the legal binding number..
Lucky for you.. the two components (body/chassis) are within close proximity of time.. so that makes it easy for parts ..well.....at least once you learn the few nuances.
hitest Samba Member
Joined: September 30, 2008 Posts: 10327 Location: Prime Meridian, ID
Posted: Sun Feb 12, 2017 11:16 pm Post subject: Re: What year is my car? |
I'm not ready to call this one done- and unmatched.
You own the car- and you possess the car. Post the actual numbers you have- and "X" off the last 2. There's no chance anybody here can impede your ownership of this car when there is exactly a 99:1 shot they guess the last two digits correctly. Give us a list of the following:
Titled VIN (from the paper- and the oldest dates)
Chassis number from under the rear seat (look to make sure the tar board has not been altered)
Body number from the stamping on the front apron- not from any separate tag (which by the way, none of my early cars have- they are all stampings)
Engine number from below the generator stand (so we can rule out a DMV clerical error)
We do not have enough of your information to conclude its a body swap. People added Wolfsburg badges all the time (I've done it), so you can't go by that. Folks typo'd VINs all day long. States used engine numbers as VINs for years. If that car has papers dating to 1964 there is no reason we can't determine its real heritage.
The reason I'm so determined is I am a passionate owner of these cars. I'm on my 4th '63 and have two '62s- rounding out all 3 deluxe models sold in the US within that year-span. _________________
| EverettB wrote: |
FU#5 |
Posted: Mon Feb 13, 2017 6:55 am Post subject: Re: What year is my car? |
| hitest wrote: |
| Body number from the stamping on the front apron- not from any separate tag (which by the way, none of my early cars have- they are all stampings). |
Where is this apron stamping number not on a body tag.. ??? _________________ aka Ken {o\!/o}
hitest Samba Member
Posted: Mon Feb 13, 2017 8:53 am Post subject: Re: What year is my car? |
| hitest wrote: |
Where is this apron stamping number not on a body tag.. ??? |
I just verified my two original cars- and neither have it like my '60 convertible (right below the Germany plate). Sorry for my confusion. I sure do not know why I had such a vivid memory of that VIN stamping. I also can't fathom why VW stopped doing it! _________________
| EverettB wrote: |
FU#5 |
