Type 4 Oil Breather Pressure Regulating Valve 022 115 303 A
Page: Previous  1, 2, 3, 4, 5, 6, 7, 8
oscarsnapkin
oscarsnapkin is offline
PostPosted: Tue Aug 18, 2015 3:47 am    Post subject: Reply with quote
SGKent wrote:
We'd need about 300 - 500 orders for the whole unit to make it really financially feasible.
300-500 doesn't really seem like that many considering the number of Buses out there. Is the problem getting that many people to commit? Wouldn't a place like Bus Depot buy a large portion of them? Count me in if you ever get it going.
- 1977 CEI Sunroof Bus 2.0L F.I. Hydraulic Lifters
- 1973 Thing
"It’s so easy to laugh, it’s so easy to hate, it takes strength to be gentle and kind."
curtis4085
curtis4085 is offline
PostPosted: Tue Aug 18, 2015 3:57 am    Post subject: Reply with quote
If we had some real numbers to kick around a group buy at cost I would throw my hat in for 10-50 units depending on price.
Steve have you tried contacting the owner of the house of Ghia about reproducing these? I cannot remember his name but he does a lot of reproduction parts for the buses.
Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com
Busstom
Busstom is offline
PostPosted: Tue Aug 18, 2015 7:15 am    Post subject: Reply with quote
How many Bays are out there...thousands?
I think this discussion ended in 2012 before I resurrected it...I can't believe someplace like Wolfsburg West hasn't worked on repopping these, or anybody for that matter.
That's why I keep questioning the criticality of (or lack of) this part, smog checks notwithstanding.
Thanks for chiming in guys (and/or gals).
SGKent Premium Member
SGKent is offline
PostPosted: Tue Aug 18, 2015 7:37 am    Post subject: Reply with quote
Usually what happens is someone wants it bad enough and they repop it. Then they sell them. Example is the set of EGR gaskets I used to sell. With postage etc it cost me about what I sell it for. The price is competitive. Yet some people will brag about coating an old piece of cardboard with RTV. That is what you are up against.
Hoody
Hoody is offline
PostPosted: Tue Aug 18, 2015 9:25 am    Post subject: Reply with quote
I sent Ray Greenwood a couple of pcv diaphragms to have molds made. Eventually I got them back. He told me that he made the molds and was going to take a shot at injecting them with silicone. But that was a loooong time ago and I am still waiting for him to return Steve's egr diaphragm which I also sent to him to have reproduced. Someone else on here made a mold and successfully reproduced a pcv diaphragm but I think he used red rtv which I am guessing failed during testing since there has not been any follow up.
raygreenwood
raygreenwood is offline
PostPosted: Tue Aug 18, 2015 12:02 pm    Post subject: Reply with quote
I still have not tried the PCV valve mold.
Simply put.....when working on these two parts....I was being a bit too much of a perfectionist. The RTVs I was using while they would be ideal for pressure molded parts like this (performance wise).....were far too aggressive to get out of the mold intact.
More avgressive mold materials are what damaged the original EGR valve part that you sent me. I still have a molded part in the last mold i made (metal cast mold)that has not been demolded.....for like 6 months. At first I was too afraid to demold it because it usually destroys the part. I startedctraveling and its still in my shop
At this point I will dissolve the mold around the part and send it back so others can take a shot at it. It really needs to be injection molded with Viton resin in a temporary (short run mold).
Its also possible......that if it can be modeled in inventor or solidworks (or they maycbe able to scan it).....one or more companies I know can CNC mill the EGR valve part from 70-80 duro epdm or viton (I dont know if that will be too hard or not).
I do have a mold of the PCV diaphram. In the past 6 months....working on other projects......I have found some new RTVs......thatcmay actually work well....especially since the PCV diaphram does not see the heat that tbe EGR valve will.
If the PCV diaphragm can operate with about 275F constant and peaks of 325F.....I have a pourable (huge difference from what I had been trying to use for the EGR part).....it can be made pretty easily....or at least use conventional molds.
I am also playing with some 750F flowable RTV on another application.....that has promise.
High performance silicone would be ideal for this part .....temp and chemical resistance. The issues are that those that have fuel vapor resistance are a b*tch to mold.....super high viscosity (defeats many mold relases)....or in a lot of cases .....really aggressive mold releases that may work can contaminate the curing process....and the RTV never cures.
Im really paranoid about making engine gaskets like this for other people. I want them to work either perfectly....or far better than the original because I am worried that a really premature material failure may destroy someone's engine.
Next week I can see how the pourable RTV works just to pressure pour a gasket in a poly mold....then dip in fuel and oil and throw it in the oven. Ray
Busstom
Busstom is offline
PostPosted: Tue Aug 18, 2015 3:16 pm    Post subject: Reply with quote
Wow, this sounds interesting, I’d like to see this thing get going.
I think I’d also want a simple canister and an adapting method as well, as a total replacement. In a perfect world, it would have two halves, so that they’re cleanable and rebuildable (picture a vacuum advance canister with flanged halves, rather than crimped).
Obviously I’m not a stitch counter, but rather, a pragmatist. I think gluing these broken-apart housings is kludgy…but that’s just me.
raygreenwood
PostPosted: Tue Aug 18, 2015 4:35 pm    Post subject: Reply with quote
Maybe just a cool clamp or a bale that holds the existing one togther nicely.
Normally I would be the first to agree that somethjng like you suggested....a new design of enclosure....would be cool.
However.....as I have been learning and noting....the PCV system of L-jet....is fairly delicately balanced. Just enough vacuum bleed to work as PCV....but not enough to affect the working of the system.
Its pretty well designed. I dont know if I would screw with that without a ton of testing.
I do know that the existing diaphrams worked well....and their only fault is that they are pushing 40 years old.
If you just had a big bag of the original diaphrams you would be happy anyway...right?
The problem with these diaphrams is what they are exposed to, bow flexible they need to be and how exact in hardness and flexibility they need to be to not.....un-calibrate..... the system. They dont just need to generally work....they need to work correctly.
I mold dozens of parts per year (meaning, different designs)......but these two parts kicked my ass because of the material characteristics they needed to have.....(while using an affordable non-injection mold method of casting or pressure, casting).......which greatly limits or forces your hand to RTVs/resins that actually dont lend themselves well to a "molding" process.
I mean...damn....I have access to viton resins.....but the type of molds, heat and pressure required for most.....is beyond what I can do in my home shop.....and not in line enough with the factories I go into.....for me to slip something into the mix.
I do have a 4oz bottle of something interesting sitting on my desk. It may be ideal for something like this. Its a carbon filled, high temp, low heat curable, pourable elastomer resin designed for head gasket elastomer use.....however.....its the proprietary property of one of my customers.
If it works.....it would be scary to ask for more (multi billion, dollar company). I need to test it soon so it may be worth trying it on the PCV diaphram. Ray
Hoody
Hoody is offline
PostPosted: Tue Aug 18, 2015 10:01 pm    Post subject: Reply with quote
Good luck Ray....I hope you can pull it off. Taking apart the original pcv valves is not difficult. It took me only one try to do it correctly. It just takes some time and a gentle touch. If the diaphragms can successfully be reproduced there will be hundreds of people that will benefit from this.The EGR valve is a bit more extensive due to the shape and size of the diaphragm. Without the diaphragm the EGR is dead in the water. I am fairly certain I have figured out how to deal with the pitting and corrosion that occurs in the body of the EGR valve. But without a working diaphragm for it....it's irrelevant. Good luck....hopefully when you have time we will hear what you have discovered.
Squeeze Cheese
Squeeze Cheese is offline
PostPosted: Mon Aug 19, 2019 11:14 am    Post subject: Re: Type 4 Oil Breather Pressure Regulating Valve 022 115 303 A Reply with quote
Just dropping my name in the hat of this old thread so I will get an email if someone ever comes up with a solution. I can't believe WW or Bus Depot never pulled the trigger on it.
Count me in as a contributor if funding is needed to repop these oil breather valve diaphragms.
63' Ragtop Beetle
78' Dakota Beige Westy. “Skills” EJ25 engine conversion w/ zero mile factory short block, Delta 1000 cams, heater core and modified Gilmore AC. Matt Steedle 091 transaxle upgrade w/ 4.14 ring and pinion, Folts aluminum gear carrier. General Grabber AT2s on stock wheels. Solar powered aux battery w/ inverter.
smitty1976bus
smitty1976bus is offline
PostPosted: Mon Aug 19, 2019 11:29 am    Post subject: Re: Type 4 Oil Breather Pressure Regulating Valve 022 115 303 A Reply with quote
Seconded! Just discovered mine is toast (or has been as long as I've had it) and just read through all these threads regarding these breathers (well, most of it, a lot went over my head Anxious ) . This thread and:
https://www.thesamba.com/vw/forum/viewtopic.php?t=665820&start=40
Both have been dormant for a long time until yesterday and today. SGKent mentions:
SGKent wrote:
I just stumbled across this on Amazon. Knowing manufacturers, this might fit if anyone wants to compare it to the stock diaphragm.
https://www.amazon.com/Ensun-Diaphragm-Repair-Memb...T92M12H36R
also https://www.amazon.com/Diaphragm-Repair-Membrane-R...amp;sr=8-4
IF YOU HAVE A CAR on file with Amazon it won't let you see it so clear your browser cache and try again.
I'm just too nervous to break mine open....
Watching these 2 threads closely Popcorn .
airkooledchris
airkooledchris is offline
PostPosted: Mon Aug 19, 2019 12:00 pm    Post subject: Re: Type 4 Oil Breather Pressure Regulating Valve 022 115 303 A Reply with quote
Just buy them whenever you can, hoping for a good one (or two) to hang onto. Then you can tear open the bad ones all you want if you want to experiment.
When I realized mine went bad, I bought 10 off of someone here on thesamba. 5 of them were good, so I sold a few and kept the rest for hoarding. I think im down to a single spare now though, so don't bother asking. Wink
think about all of the parts guys here that work primarily in parting out busses, because they might have piles of them sitting around. Chris down in Oakland CA in the classifieds parts a lot of busses, id try him or some of the more well know used parts guys. (ken, Chris/BustedBus,etc)
metahacker
metahacker is offline
PostPosted: Wed Dec 15, 2021 10:00 pm    Post subject: Re: Type 4 Oil Breather Pressure Regulating Valve 022 115 303 A Reply with quote
I made a thread posting 2 variations of a modern VAG PRV "easy install" ...
https://www.thesamba.com/vw/forum/viewtopic.php?t=762858
Page 8 of 8
