LivinInnaVWBus Samba Member
Posted: Sun Oct 18, 2015 9:05 am Post subject: 4th Case to Tranny Bolt Threaded Insert Replacement |
Does anyone know where to find this part?
Thanks! |
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Sun Oct 18, 2015 9:15 am Post subject: |
I'd contact Roy at mofoco and see what he an do for you. |
raul arrese Samba Member
Joined: July 23, 2006 Posts: 1330 Location: miami florida
Posted: Sun Oct 18, 2015 9:35 am Post subject: |
Awesome, thank you! I searched but apparently was using the incorrect terms.
Anyone know the hole size to drill for a press fit? |
Posted: Sun Oct 18, 2015 9:37 am Post subject: |
I don't know first hand cause I just measure the nut and go from there , I would wait till you have it in your hand and measure. _________________ " Hot vw feature , may 2014 issue "
" 2013 Bug Jam class winner "
" Bug Jam best motor and best paint "
" 2013 Lakeland Classic Best of Show "
" 2014 Show and Shine , First in class "
Like my facebook https://www.facebook.com/pages/Raul-Arrese-custom-fabrication-and-performance/1832968110262608 |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sun Oct 18, 2015 2:20 pm Post subject: |
From memory (and it was a while ago, 15yrs) it will press fit into the standard factory hole, no drilling necessary _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
R Birks Samba Member
Joined: September 19, 2005 Posts: 6 Location: Salem, Utah.
Posted: Wed Apr 10, 2024 6:40 pm Post subject: Re: 4th Case to Tranny Bolt Threaded Insert Replacement |
The factory sized hole is not even close to the size it needs to be to install this captive nut. Im trying to find the right drill size too. I've been told it should possibly be 9/16 but I'd prefer someones real knowledge from experience before I screw up my case. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 77091 Location: Sneaking up behind you
Posted: Wed Apr 10, 2024 6:45 pm Post subject: Re: 4th Case to Tranny Bolt Threaded Insert Replacement |
I've always just pressed them in.
use a bolt and larger washer on the back and tighten it to pull it in. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Fri Apr 12, 2024 8:01 am Post subject: Re: 4th Case to Tranny Bolt Threaded Insert Replacement |
They press in just fine if one was in the hole prior. But my situation is that there has never been a blind nut in the case so the hole is way to small to press the blind nut insert into the case. I need to drill the hole out to allow the blind nut to press into it. Im going with a 9/16 drill bit as thats as close as I can get to what I appear to need and no one has any advice or suggestions as to anything different. Wish me luck. |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4345 Location: Los Angeles, CA 90016
Posted: Sat Apr 13, 2024 4:02 pm Post subject: Re: 4th Case to Tranny Bolt Threaded Insert Replacement |
Earlier cases didn’t have this feature. Your hole must be around 10.3mm right now. Wait until it arrives, measure, and aim for .005” smaller. Step up to it, starting at .010” smaller first. Measure and decide if it needs more. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
RWK Samba Member
Posted: Sat Apr 13, 2024 4:38 pm Post subject: Re: 4th Case to Tranny Bolt Threaded Insert Replacement |
X2 _________________ 73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530 |
RWK Samba Member
Posted: Sat Apr 13, 2024 4:41 pm Post subject: Re: 4th Case to Tranny Bolt Threaded Insert Replacement |
Ream hole if possible, drilling tends to grab and oversize previous holes. _________________ 73 Type 181
63 Type 113
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21588 Location: Oklahoma City
Posted: Sat Apr 13, 2024 5:47 pm Post subject: Re: 4th Case to Tranny Bolt Threaded Insert Replacement |
You can buy these at McMaster Carr. They list drill bit sizes in the specs. Ray |
Glenn Mr. 010
Posted: Sat Apr 13, 2024 5:51 pm Post subject: Re: 4th Case to Tranny Bolt Threaded Insert Replacement |
If this task is that difficult to do, then maybe you should find a good mechanic. _________________ Glenn
Member #1009
#BlueSquare
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20411 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Apr 13, 2024 6:25 pm Post subject: Re: 4th Case to Tranny Bolt Threaded Insert Replacement |
And to complicate things even more, there is the lip on trans case the was supposed to lock the nut from turning (when using bolt & nut) ..... It's a problem when using a insert because as you tighten bolt the "lip" pushes the socket off bolt head.... You either should grind back lip or use allen head cap screw....
_________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
