loose power, occasional backfire
danaspider
danaspider is offline
PostPosted: Wed Apr 09, 2014 3:00 pm    Post subject: loose power, occasional backfire Reply with quote
2 litre FI engine in 78 Bus. Has been running well, in fact we just drove it across the northern USA. Now, it starts easily, and seems to be running fine. After sometime, 5 to 10 minutes of driving, it will suddenly loose power. But not stall, continues to idle. In a few moments it will start pulling again.
Occasionally there is a back fire when power is lost. Even when has no pulling power it idles fine.
Ideas?
Dana
Paul Hoegemeyer
Paul Hoegemeyer is offline
PostPosted: Thu Apr 10, 2014 8:19 am    Post subject: Reply with quote
Had a similar problem with my 78 and it ended up being a plug wire going bad
1978 passenger bus FI. camper special engine
1986 Brazilian DC
1979 Westy waiting on a TDI
1970 beetle
TomWesty
TomWesty is offline
PostPosted: Thu Apr 10, 2014 6:31 pm    Post subject: Reply with quote
Also, replace fuel filter.
chicagovw
chicagovw is offline
PostPosted: Thu Apr 10, 2014 6:36 pm    Post subject: Reply with quote
A few weeks ago this happened to my 78 FI. Someone here recommended that it might be a bad condenser-and that is what it turned out to be.
danaspider
PostPosted: Wed Jun 11, 2014 5:39 pm    Post subject: Reply with quote
2L 78 Bus, with FI. Was an intermittent issue of loosing power, but would still idle. Now has progressed to being there most of the time. I have changed plugs, wires, s tube intake, new fuel filter. Was better it seemed for a few days now worse than ever.
I have checked the fuel pressure and it is steady, did a compression check and find that #1 cylinder is 0. No funny noises.
I have not pulled the valve covers yet, but was wondering if this could be caused by a bad hydraulic lifter.
Any ideas? next step is to pull valve covers and look at springs and such.
Need guidance from the experts!!!
danaspider
PostPosted: Wed Jun 11, 2014 5:47 pm    Post subject: Reply with quote
Thanks for the feedback. I will do the check tomorrow and post the results.
It is interesting that it has been intermittent. That is why I was leaning toward a leaking hydraulic lifter.
Again, thanks
busdaddy
busdaddy is offline
PostPosted: Wed Jun 11, 2014 6:03 pm    Post subject: Reply with quote
Could be a number of things, the #1 cause is a loose valve seat followed by a burnt valve or damaged rings, it's not often a lifter hangs open constantly so chances of that are very remote but lifters sometimes wear off on the cam end or the lobe goes flat.
Bad news regardless of the cause, start by pulling off the valve cover and if nothing looks obvious remove the rocker assemblies and see if all 4 valve ends are level with each other (careful putting them back on, 9'lbs torque on the nuts max.).
Слава Україні!
jdedini
jdedini is offline
PostPosted: Wed Jun 11, 2014 6:28 pm    Post subject: Reply with quote
After you get your valves sorted out, check your temperature sensor 2, distributor and coil while you are at it. All three have given me similar headaches.
Justin
79' CA FI Tin Top Camper
geopanoramic
geopanoramic is offline
PostPosted: Thu Jun 12, 2014 6:42 am    Post subject: Reply with quote
Some great advise. Finding zero in a cylinder is always a bit worrying. Dying coil can also a very frustrating experience and lesson in electrics serving the motor. Multiple things at the same time are a hoot.Good Luck!
danaspider
PostPosted: Thu Nov 05, 2015 6:52 am    Post subject: Re: loose power, occasional backfire Reply with quote
Ideas?
Dana
turned out to be a ba hydrolic lifter
