Crappy kit or doing something wrong.
teched
teched is offline
PostPosted: Sat Nov 14, 2015 9:50 am    Post subject: Crappy kit or doing something wrong. Reply with quote
Got my 1300 almost all back together and ready slip back into the car. I have got all the tins back on, but the Intake gaskets are not fitting right. At least that what I think these gaskets are. Maybe these gaskets are for the exhuast. They look like two flange shaped peices of aluminum with some gasket material sandwiched in between. There are a bunch of them in the kit. I think I might be using the wrong gasket but nothing else in the kit looks like it would work.
cletus_zuber
cletus_zuber is offline
PostPosted: Sat Nov 14, 2015 10:16 am    Post subject: Re: Crappy kit or doing something wrong. Reply with quote
Yeah, those sound like exhaust gaskets. 1300? Single port?
Those take the silver ring gaskets in the kit I think.
Don't take my word for it, other, more knowledgeable folks will chime in.
HPMX 40's & 019
VERTED71
VERTED71 is offline
PostPosted: Sat Nov 14, 2015 10:17 am    Post subject: Re: Crappy kit or doing something wrong. Reply with quote
sounds like exhaust gaskets. Don't remember seeing metal intake gaskets before. The intake should be made out of paper or like a cork type material.
Aloha'z and have a great day!
71 Super Beetle Vert
15x4.5 Front
15x6.5 Rear
155/60R15 74T tires FRONT
205/65/15 tires REAR
1600 Dual Port
Progessive Carb
Electronic Ignition
Tri Mil "hotdog" exhaust
Alpha_Maverick
Alpha_Maverick is offline
PostPosted: Sat Nov 14, 2015 11:41 am    Post subject: Re: Crappy kit or doing something wrong. Reply with quote
Like Cletus said, the intake "gasket" for a single port is actually a metal donut that fits into the head, and gets squished as the intake is torqued down.
Alstrup wrote:
hmm well, wiggly Laughing I like 5,5inchers in the rear at least.
HRVW
HRVW is offline
PostPosted: Sat Nov 14, 2015 12:00 pm    Post subject: Re: Crappy kit or doing something wrong. Reply with quote
Smile Intake man gskt on a SP is a round copper looking larger then a nickel and smaller the a quarter, The sharp edge should go DOWNwards into the head.
Gskt kits have gone a bit universal to cover the 1200,1300,1500 and 1600 engines. Extra stuff just needs to be put aside for a whatever rainy day.
When building engines accumulated a lot of stuff from those kits.
teched
teched is offline
PostPosted: Sat Nov 14, 2015 12:25 pm    Post subject: Re: Crappy kit or doing something wrong. Reply with quote
Thanks, I thought something looked funny. I will check through the kit and find something "Donut Like" Will a Crispy Cream work in a pinch???? Very Happy
Rome
Rome is offline
Look here for a photo of all contents of a good gasket kit- http://www.thesamba.com/vw/forum/viewtopic.php?t=527020
The ones you need for your 1300 intake are #13.
mark tucker
mark tucker is offline
PostPosted: Sat Nov 14, 2015 12:51 pm    Post subject: Re: Crappy kit or doing something wrong. Reply with quote
larger than nickel and smaller than quarter??? wow I would have to fix that to atleast a 50 cent size. Wink or 2 quarters Shocked
teched
teched is offline
PostPosted: Sat Nov 14, 2015 1:29 pm    Post subject: Re: Crappy kit or doing something wrong. Reply with quote
Found them in another box. Not sure how they got there...f'n gnomes, LOL Laughing
ashman40
ashman40 is offline
PostPosted: Sun Nov 15, 2015 11:35 am    Post subject: Re: Crappy kit or doing something wrong. Reply with quote
You must be thinking of some other car, or a performance engine. Stock aircooled VW intake gaskets are metal to transfer heat to the intake manifolds. Even the DP gaskets (#15 in the pic) are metal.
Paper or other insulating material (like cork) are okay for dual-carb setups where the length of the intakes are both short and they are directly above the heads. Paper and cork probably seal better than metal, but don't use them for stock center mounted intakes.
AshMan40
iowegian Premium Member
Samba Curmudgeon
iowegian is offline
PostPosted: Sun Nov 15, 2015 12:17 pm    Post subject: Re: Crappy kit or doing something wrong. Reply with quote
Dunkin' Donuts are preferred---------------although if you are planning on driving the car in Canada you should use Tim Hortons.
HRVW
HRVW is offline
PostPosted: Sun Nov 15, 2015 12:26 pm    Post subject: Re: Crappy kit or doing something wrong. Reply with quote
Smile Dang....need to have my eyes checked and NEW glasses.
That would explain why I keep finding the Wrong hole (whoops, wrong thread)
