Vintage LEDS
Cptn. Calzone
Cptn. Calzone is offline
PostPosted: Sat Nov 21, 2015 5:59 am    Post subject: Vintage LEDS Reply with quote
Hello everyone has anyone used this product as of yet>Promise of bright light clairty and less drag on electrical system They look nice but and if they deliver what is claimed seem to be a good safety upgrade.
71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse
swelchy
swelchy is offline
PostPosted: Sat Nov 21, 2015 6:33 am    Post subject: Re: Vintage LEDS Reply with quote
been looking at these too.. Waiting to see some results from others
1969 Westy 1915cc 044 heads 94 bore 69 stroke scatCWcrank scat lifters C25 cam straight cam gears 1:25 ratio rockers CB weber idf 40's vintage speed sport exhaust.
raygreenwood
raygreenwood is offline
PostPosted: Sat Nov 21, 2015 7:17 am    Post subject: Re: Vintage LEDS Reply with quote
So....are you going to post a link to this company? Search for vintage LED gjves dozens of companies. One in Australia whose name is Vintageled.com.....and makes primarily residential lamps.
Ray
Kirk
Kirk is offline
PostPosted: Sat Nov 21, 2015 8:28 am    Post subject: Re: Vintage LEDS Reply with quote
Indeed. I've been looking at various LED upgrades, but why is it "vintage"? My gauge cluster bulbs are just wedge type. I was just planning to buy some LEDs and swap.
MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super
Brian
Brian is offline
PostPosted: Sat Nov 21, 2015 9:40 am    Post subject: Re: Vintage LEDS Reply with quote
Link?
Do not use LEDs for your idiot lights
I did LED tail lights and I love them. You know when you sit behind a new car and think to yourself "holy shit those are bright"? That's how bright mine, almost, are.
You have to break off the little tabs
Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter
raygreenwood
PostPosted: Sat Nov 21, 2015 9:53 am    Post subject: Re: Vintage LEDS Reply with quote
You can buy LED's with virtually any wattage dim to bright...and you can buy dimmable LED's. Should be no issue with using them for any idiit light except the alternator/generator light which requires the voltage drop across the filament to work with the alternator. Ray
Wildthings
Wildthings is offline
PostPosted: Sat Nov 21, 2015 10:16 am    Post subject: Re: Vintage LEDS Reply with quote
I don't think you can directly use LED's for your turn signal bulbs unless there truly is a "vintage" LED replacement that has a shunt added to keep the wattage in the original range so that the flasher will work. Could probably figure out how to use a heavy duty flasher if such is not available. There was a thread a year or so ago talking about how to use LEDs for the turn signals, didn't follow it but it would likely be worth a search.
You could definitely up the light output of the other bulbs in the tail light units when using LEDs as the LEDs aren't going to put out anywhere near the heat as as do incandescent bulbs, so melting or otherwise degrading the housing and lens would not be an issue.
Wildthings
PostPosted: Sat Nov 21, 2015 10:20 am    Post subject: Re: Vintage LEDS Reply with quote
I have bought a lot of bulbs for around the house from these people. Know that they have automotive bulbs but don't know how much of a selection.
https://www.1000bulbs.com
swelchy
swelchy is offline
PostPosted: Sat Nov 21, 2015 11:29 am    Post subject: Re: Vintage LEDS Reply with quote
This is what he is referring too specifically... http://www.vintagecarleds.com/
notchboy
notchboy is offline
PostPosted: Sat Nov 21, 2015 11:57 am    Post subject: Re: Vintage LEDS Reply with quote
Thats it? Just headlights?
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
raygreenwood
PostPosted: Sat Nov 21, 2015 3:27 pm    Post subject: Re: Vintage LEDS Reply with quote
And...I would choose carefully. Although LED beadlights are already a production reality.....the spectrum, reflector design and type are critical quality components. Dont confuse bright.....lumens.....with the sbility to broadcast a beam properly over distance. There is some junk out there. Ray
Wildthings
PostPosted: Sat Nov 21, 2015 5:15 pm    Post subject: Re: Vintage LEDS Reply with quote
For a 1971 Transporter
https://www.1000bulbs.com/part_finder?filter[make]...year]=1971
kreemoweet
kreemoweet is online now
PostPosted: Sat Nov 21, 2015 5:46 pm    Post subject: Re: Vintage LEDS Reply with quote
Wow! 1156 bulb replacements for only $34.00 each! And with a sooper 90-day warranty! Bet they'll sell like hotcakes!
'67 bug: seized by the authorities
Cptn. Calzone
PostPosted: Sat Nov 21, 2015 9:06 pm    Post subject: Re: Vintage LEDS Reply with quote
and your point kreemo is.....?
71 westfalia
Dana Champion
Dana Champion is offline
PostPosted: Sat Nov 21, 2015 11:22 pm    Post subject: Light housing reflective material Reply with quote
I have looked at the GoWesty LED kits, for my Vanagon Westfalia. It comes with a flasher relay for compatibility.
....Something I've done to brighten up my existing early bay tail light fixtures is putting metal flue tape inside the housing where the old reflectors are worn. It amps up the light output.
Running lights
works pretty well
Toss LED'S in there and look out Exclamation
Very Happy
Last edited by Dana Champion on Sun Nov 22, 2015 10:13 am; edited 2 times in total
Kaput
Kaput is offline
PostPosted: Sat Nov 21, 2015 11:42 pm    Post subject: Re: Vintage LEDS Reply with quote
?ucking ripoff maybe?
heres one slightly more reasonable...https://www.superbrightleds.com/moreinfo/tail-brak...-car/1326/
Cptn. Calzone
PostPosted: Mon Nov 23, 2015 7:36 pm    Post subject: Re: Vintage LEDS Reply with quote
So I take it no one on this thread has used this product nor can endorse it
71 westfalia
Dana Champion
PostPosted: Mon Nov 23, 2015 8:10 pm    Post subject: Re: Vintage LEDS Reply with quote
There is another post on this subject. The headlights are for sale in the classifieds. I would imagine someone is running these. The vendor should shed some light Laughing
Headlights look cool, kinda like my Hella H4's on my '70.
Samba vendor
http://www.thesamba.com/vw/classifieds/detail.php?id=1801829
Very Happy
Tcash
Tcash is offline
PostPosted: Mon Nov 23, 2015 8:40 pm    Post subject: Re: Vintage LEDS Reply with quote
22 matches
http://www.thesamba.com/vw/forum/search.php?search_id=753010168&start=0
Zylinderkopf
Zylinderkopf is offline
PostPosted: Tue Nov 24, 2015 12:46 am    Post subject: Re: Vintage LEDS Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=638779&highlight=led
Good product. I have these on my Thing and am very pleased.here is a link to a discussion we had in the Thing forum.
1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to."
