hitest Samba Member
Joined: September 30, 2008 Posts: 10301 Location: Prime Meridian, ID
Posted: Mon Jul 14, 2014 10:36 pm Post subject: |
fred69vert wrote: |
Just a note.....if your get these casters, put Slime in the tires. If you don't they WILL leak down (mine did) and you can't roll the dolly with flat tires. |
...and, when they lose air- be very cautious of debeading when spinning around. We had this happen with a bus set on four HF pneumatic casters. We had to replace them with 6" diam. solid castors- should have done it all along. They still roll off road. _________________
EverettB wrote: |
FU#5 |
Starkey58 Samba Member
Joined: November 16, 2014 Posts: 1 Location: Brisbane
Posted: Sat Mar 07, 2015 5:12 am Post subject: |
Hi all does anyone have plans on the larger design? Or could let me know sizes |
toms64 Samba Member
Joined: August 26, 2014 Posts: 11 Location: central pa
Posted: Sat Mar 07, 2015 5:56 am Post subject: |
Hi Starkey58, I see the link to the large one on page one is no longer usefull but you can try using the term "body dollies" in the search forum that should get you a lot of hits. Im planning to build one eventually probably the large one......good luck!! |
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Sun Mar 08, 2015 1:58 pm Post subject: |
My dolly
I was worried I wouldn't have enough height for the shell to go over the chassis, as my garage isn't super high. Probably would have been fine.
As far as plans, I copied what people here had done before and just made it to fit my car. My 2cents, if you need to replace the channels, build a rotisserie. I need to replace/fix the rear body mounts and clean up the front mounts first, this is what I used the dolly for.
No way I was going to be lying on my back drilling out 300 spot welds!
makes a hard job much easier.
_________________ If you can't join them, beat them! |
fla2smoker Samba Member
Joined: December 31, 2011 Posts: 574 Location: Parrish, Florida
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3376 Location: Dirty Jersey
Posted: Fri Nov 20, 2015 11:27 am Post subject: |
66vwkaferresto wrote: |
I opted for the longer version so that I would have access to my heater channels... I think either will serve your purpose.
Do you have the dimensions or lengths on the pieces here? I'd like to make one just like it, Thanks _________________ 1963 Ragtop Bug |
Posted: Wed Nov 25, 2015 12:51 pm Post subject: |
Thanks bud _________________ 1963 Ragtop Bug |
ping349n Samba Member
Posted: Tue Dec 01, 2015 8:05 pm Post subject: Re: Which body dolly is best? (pics) |
I just noticed that the first one in this post is mine! It's the dolly I built for the 66 I built. I still have that dolly (in pieces) but don't need it anymore now that I have a bus to build. _________________ 1969 Deluxe "Grizwald"
http://www.thesamba.com/vw/forum/viewtopic.php?t=633280 |
Customalways Samba Member
Joined: October 19, 2013 Posts: 67 Location: Baltimore, MD
Posted: Fri Dec 04, 2015 3:44 pm Post subject: Re: Which body dolly is best? (pics) |
Just built a dolly today using 4"x4"lumber and also used partial board to make the corner braces (the metal ones shown in the picture on this thread are available at home depot but they are about $2 each and you would need 16 of them so the partial board is MUCH cheaper and I think you get more support. Plus you need more than the corner supports so you would be looking at about $40-$45 in the strong tie metal pieces at home depot
I bought the 10" casters from Harbor Freight and like them a lot.
- Five of the 8' 4x4 $ $7.50 each = round up to $40
- 4 casters at $15 each = $60 (you could go much smaller if you are on concrete and in a garage and save about $35 but i needed large wheels)
- 1 sheet of 1/2" partial board @ $10
- 1 box of 3" (or 2.5") coarse thread drywall screws @ $ 7
- 16 5/16" x 1.5" lags @ .50 each = $7
- Total cost @ $160
- Super Super durable and if needed you can always recycle the 4x4 somehow in the yard
Horizontal 4x4 I cut to 66"
Vertical upright I cut to 2'
Lateral (front to back) I left at 8'
cut sixteen 45° braces out of particle board and measured them @ 12"
** I think the working height is perfect since I have channels, Firewall, and cross members to do but vertical uprights could be shortened down to 16" or 12" for someone who wants less height.
I will post pictures tomorrow when it is light out again. |
Posted: Mon Dec 07, 2015 1:31 pm Post subject: Re: Which body dolly is best? (pics) |
Pictures of recently built dolly
Posted: Mon Jan 04, 2016 3:37 pm Post subject: Re: Which body dolly is best? (pics) |
added a bit of an upgrade to my dolly incase anyone reviews this in the future. It is on my build thread (56 Oval First Time for Everything) |
13mmSpanner Samba Member
Joined: July 22, 2019 Posts: 15 Location: Sydney, Australia
Posted: Fri Aug 02, 2019 5:55 am Post subject: Re: Which body dolly is best? (pics) |
These all look great but how did you get the body off and onto them in the first place? Is the body light enough for a few blokes to lift it off the chassis and drop it onto the dolly? |
Dibaltic Samba Member
Joined: May 06, 2007 Posts: 564 Location: Chambersburg, Pennsylvania
Posted: Fri Aug 02, 2019 8:59 am Post subject: Re: Which body dolly is best? (pics) |
13mmSpanner wrote: |
Yes, you can remove fenders, decklid, and hood to lighten the body up some too. If you're heater channels seem to be rusty brace the body before removing from the chassis. |
Posted: Sat Aug 03, 2019 2:30 am Post subject: Re: Which body dolly is best? (pics) |
Once all the doors and fenders, deck lid and bonnet are off, how heavy is the bare chassis? Can 2 people lift it? |
Bama Dave Samba Member
Posted: Sat Aug 03, 2019 3:23 am Post subject: Re: Which body dolly is best? (pics) |
Still not super light, but Yes....two reasonably strong people can move the bare BODY around. Not with chassis still attached... _________________ David Richerson
1970 Beetle
1971 Super
1972 Baja
hellthorne wrote: |
First off, I know i made stupid decisions that led to my predicament, so while you are welcome to tell me that I am an idiot for doing the things I did, please know that I am already aware of this. |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1049 Location: Jacksonville, FL
Posted: Sat Aug 03, 2019 9:19 am Post subject: Re: Which body dolly is best? (pics) |
I am 5' 7" tall and of average strength (probabably on the low side of average.) I have a Ghia convertible mounted on an under-mount rotisserie. I can grab the front or rear bumper mounts, lift the car using mostly my calves, and move it side to side in the garage. Four men of average strength can easily lift the stripped body of any type I by the wheel openings or the bumper mounts.
If you are looking for a one man solution you can use an engine hoist, build a wooded gantry lift, or use eye bolst through 4x4 lumber secured between joists in the shop/garage.
This is the gantry I built to lift the body of my Ghia by myself. I also installed eye bolts in the garace ceiling when I mounted the body to the rotisserie.
...and a measured drawing if needed (2x6 Lumber)
Emil _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
Posted: Fri Aug 09, 2019 11:57 pm Post subject: Re: Which body dolly is best? (pics) |
Thanks, useful stuff |
jellydog Samba Member
Joined: September 02, 2019 Posts: 3 Location: illinois
Posted: Mon Sep 02, 2019 5:43 pm Post subject: Re: Which body dolly is best? (pics) |
Yes, you can remove fenders, decklid, and hood to lighten the body up some too. If you're heater channels seem to be rusty brace the body before removing from the chassis.[/quote]
This is my first entry so I hope I don't screw it up. I'm getting ready to remove the body on my 62 sedan. The heater channel on the drivers side is pretty well roached and I've been thinking about whether I should fashion some kind of supports. I like the idea of a brace. What about welding in a brace between the two door posts? Any other suggestions appreciated. |
