vwuguy  Samba Member
Joined: November 01, 2005 Posts: 1070 Location: southwestern ontario, on and netherlands and bc
Posted: Mon Dec 07, 2015 8:37 am Post subject: How to replace a cv boot on a 1968,1969-1979 vw bus |
Here is how to replace the cv boot on your bus watch and learn
video by erb smith copyright 2015
In order to get the clip off the end of the axle i use 2 screwdrivers one with a fine tio and one with an extra wide tip.
The wide one i push the clip out with while the fine one i used to hold the clip in place and out. you'll see when you try it..
Do you have any suggestions how to do this better or faster
thanks erb _________________
please check my youtube and click like and subscribe here trying to get to 1000 subscribers
i challenge you to invite a few friends to subscribe and help a vw uguy out
https://www.youtube.com/@Vwuguy |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8586 Location: All Across The Country
consvws  Samba Member
Joined: April 07, 2009 Posts: 1015 Location: Roseburg, OR
Posted: Mon Dec 07, 2015 9:57 am Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus |
| vwuguy wrote: |
| Here is how I replace the cv boot on my bus |
fixed it  |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Mon Dec 07, 2015 10:07 am Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus |
Background music is to high. I can't hear you.
Keep it up
Tcash
| Tcash wrote: |
Click on links.
How to Remove Stripped CV Bolt Head
CV Joints: Re-pack or Replace?
CV Joint Service (Lobro)
PSA - Nord-Lock your drive shaft (CV) bolts
1970 VW Type2 CV Joint Play
https://www.youtube.com/watch?v=mgwmuZuJ02I
Vanagon CV bolt torque specification 33 ft lbs
CV Joints 101
CV Joint Maintenance
Prt#113 501 229 A and 211 501 229, CV bolt, Socket Head, M8-1.25 x 47, 12.9 hardness, to 70.
Prt# 893 407 237, CV bolt, 12 point polygon head, M8-1.25 x 48, 12.9 hardness, to 71-79. Will work on 68-91 Buses.
| Karl wrote: |
YES!
Manual and auto trans axles are 3 different lengths.
...and are NOT interchangable.
Half shaft lengths
manual 476mm (18 3/4in)
auto left 457mm (18 in)
auto right 505mm (19 7/8 in) |
Good Luck
Tcash |
Hansolo99 Samba Member
Joined: December 04, 2010 Posts: 524 Location: So Cal
Posted: Mon Dec 07, 2015 11:46 am Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus |
I really enjoy your videos, but PLEASE get rid of that dumb music. If I want to hear music I will go on Pandora. I can't hear a damn thing. Sorry!
Also get better lights and edit it. I have learned quite a lot, but have to keep watching over and over and rewind then forward the video.
Other then that thanks for taking your time to help us that are still learning!!!
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2800 Location: Ocean Beach - San Diego
Posted: Mon Dec 07, 2015 12:46 pm Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus |
I'd probably learn a lot but please TURN THE DAMN MUSIC DOWN!
Suggestion - watch your videos (or better yet have someone else watch your videos) prior to posting them. Issues like "the music is so loud no one can hear your narrative" should be easy to identify and address.
Thanks for your efforts. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53241 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Mon Dec 07, 2015 1:28 pm Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus |
| Amskeptic wrote: |
| vwuguy wrote: |
Use proper expanding circlip pliers. |
Yes please, they'll also prove extremely useful when you make the engine rebuild video and want to get the gear off the crank
http://www.princessauto.com/en/detail/14-in-snap-ring-lock-ring-pliers/A-p8006659e _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4852 Location: Kaneohe
mpls_ham Samba Member
Joined: November 21, 2013 Posts: 78 Location: Northern Black Hills
Posted: Mon Dec 07, 2015 5:38 pm Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus |
Thanks for that Erb! I commend you for keeping your cool with the new boot install on the shaft. I might have been inclined to sling a couple of profanities in that segment  _________________ 1970 Westfalia - Evangeline
1973 Beetle Convertable |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4785 Location: Arizona Highways
Posted: Mon Dec 07, 2015 5:59 pm Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus |
the 12pts are 8mm  _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Mon Dec 07, 2015 10:15 pm Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus |
| borninabus wrote: |
the 12pts are 8mm  |
I could be wrong about the size. I changed my post so it refers to sets rather than individual sockets. The sets have both 6mm and 8mm. You can't go wrong.
Aloha
tp
Tcash Samba Member
Posted: Mon Dec 07, 2015 10:21 pm Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus |
| Tcash wrote: |
Hi All
First determine if you have the right tool.
8mm Triple Square
6mm Allen
One of the following you have in your tool box?
Locking Pliers
410 NUTBUSTER® PLIER
PIPE WRENCH
12MM X 12POINT SOCKET HAMMERED OVER BOLT HEAD
BOLT EXTRACTOR
LAST RESORT
| ftp2leta wrote: |
Cut any stubborn 6mm axle bolt head, on trany side it's easy, a grinder and cutting wheel will do the job, on the wheel side use a high speed air tool with a small cutting wheel.
Remove drive shaft. Ok, to remove the remaining drive axle bolt i mig weld a 13mm nut.
The replacement of drive axle bolt should be part of normal maintenance. It is crucial to deeply clean the bolt head before attempting to remove those, a partially inserted 6mm Allen socket will never be enough.
The TORKS 12 point bolt are way better than the ALLEN one.
They are a pain anyway |
If you do not have a welder you can, put double nuts on the bolt. Tighten them against each other. Put a wrench on the inboard nut and unscrew it.
If is broke off flush with the flange. You can try a left hand drill with a reversing drill motor. Good luck these bolts are hard.
Still no go. Weld a nut from the inside circumference to the broken piece and use a wrench to extract it.
Good Luck
Tcash |
Manfred58sc Samba Member
Posted: Tue Dec 08, 2015 9:22 am Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus |
I am the anti-Stipe! Die monster,die. Good instructional video however, thanks for sharing _________________ Fat chick owner/operator |
Posted: Tue Dec 08, 2015 10:32 am Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus |
Duckbill snap ring pliers
I have not watched the video, but if you didn't mention it you should talk about whether to keep the bevelled washer if it is still there or not. Maybe show a copy of the VW service bulletin about discarding the washer. |
14Eyes Samba Member
Joined: April 15, 2022 Posts: 72 Location: North of Raleigh, NC
Posted: Fri Jun 21, 2024 11:00 am Post subject: Re: How to replace a cv boot on a 1968,1969-1979 vw bus |
It's worth noting that the video is no longer available _________________ The Story of my 72 |
