vwuguy  Samba Member
Joined: November 01, 2005 Posts: 1070 Location: southwestern ontario, on and netherlands and bc
Posted: Fri Dec 11, 2015 11:29 am Post subject: How to remove a stuck stud how to change your tire on a 1969 |
In this video Erb shows you how to remove a stuck front rim from the drum, He also shows you how to change to your Original spare tire
please check my youtube and click like and subscribe here trying to get to 1000 subscribers
i challenge you to invite a few friends to subscribe and help a vw uguy out
https://www.youtube.com/@Vwuguy |
Malokin Martin Samba Member
Posted: Fri Dec 11, 2015 12:17 pm Post subject: Re: How to remove a stuck stud how to change your tire on a |
edited
Last edited by Malokin Martin on Fri Dec 11, 2015 2:17 pm; edited 1 time in total |
jtauxe  Samba Member
Joined: September 30, 2004 Posts: 5980 Location: Los Alamos, New Mexico, USA
Posted: Fri Dec 11, 2015 12:25 pm Post subject: Re: How to remove a stuck stud how to change your tire on a |
Wow. Where to start with the things he has done wrong?
- Used a ratchet instead of a breaker bar. The cheater pipe was good, though.
- Got is math all bolluxed up on the torque calculation demonstration.
- Jacked it up with a block putting pressure on the outside of the jack point, risking crushing the jack point.
- Spray painted after a little wire brushing -- no rust treatment, bad spraying technique, and no drying time.
Also, those "stuck" studs came out easy! I've had some on way worse than that, and this technique wouldn't have budged those. Advanced techniques: penetrating oil soak, application of heat, hammering while under torque load, and when all else fails, cutting the damned things off and using a new stud (on the later buses, at least). _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4784 Location: Arizona Highways
Posted: Fri Dec 11, 2015 12:45 pm Post subject: Re: How to remove a stuck stud how to change your tire on a |
i really hope that nobody is actually following any of these "instructional" videos made by mr. 'vwuguy'.
they are full of poor techniques, questionable practices and just plain backyard hackery.
they should be removed from thesamba as they are detrimental to the community as a whole.
on the other hand....
it's people like this--and people who take advise from people like this--that keep my belly full.
so keep it up, vwuguy.
it's slow season at the shop  _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4852 Location: Kaneohe
Posted: Fri Dec 11, 2015 1:34 pm Post subject: Re: How to remove a stuck stud how to change your tire on a |
| jtauxe wrote: |
| Wow. Where to start with the things he has done wrong? ... |
| borninabus wrote: |
they should be removed from thesamba as they are detrimental to the community as a whole. ... |
vwguy has good intentions, but some of his recommendations and procedures are poor and possibly damaging and/or dangerous. If his videos could be edited by a more knowledgable and experienced person they would be a contribution to TheSamba. As the videos are now they could lead a newbie into trouble. I agree that they should be removed, but thanks for the effort.
"The road to Hell is paved with good intentions."
Aloha
tp |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9156 Location: Syracuse, NY
Posted: Fri Dec 11, 2015 1:39 pm Post subject: Re: How to remove a stuck stud how to change your tire on a |
Always, always, always keep the tip of the spray nozzle as close to your work as humanly possible. Outstanding. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
| borninabus wrote: |
| a measurement of your rod would be extremely useful. |
| notchboy wrote: |
| my dad wasnt a belittling cock when he tought me how to wrench on cars. |
| EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Tcash Samba Member
Joined: July 20, 2011 Posts: 12843 Location: San Jose, California, USA
Posted: Fri Dec 11, 2015 2:06 pm Post subject: Re: How to remove a stuck stud how to change your tire on a |
Please refer to the instructions in your owners manual.
1969 (August 1968) Bus Owner's Manual
Tcash |
vwuguy  Samba Member
Posted: Fri Dec 11, 2015 2:28 pm Post subject: Re: How to remove a stuck stud how to change your tire on a |
actually those bolts were stuck on there I could not get them off with the air gun for life of it . used several different torque guns and tried to get those off with no luck.. this was the only way to get them off and that was the first time I took them off.
to quote
- Spray painted after a little wire brushing -- no rust treatment, bad spraying technique, and no drying time. -it was antirust paint and any paint is better than no paint.. it did dry once the wheel was on..it was 1/4 steel on painted on not really requiring paint or so I was told..
-I could not find the breaker bar or I would have used it.. If you willing to get me a breaker bar that be appreciated.
to quote
"i really hope that nobody is actually following any of these "instructional" videos made by mr. 'vwuguy'.
they should be removed from thesamba as they are detrimental to the community as a whole. "
I really disagree I have taken on the task of showing how to fix stuff on your hobby car what a task.. . Fixing cars like this is a dying art If you think that there are better ways of doing things instead of complaining please tell me how with the tools I have and the next to nothing budget i have ....thanks erb
if you want to help edit the videos than heh that's cool help me out.
did you get the joke at the end when I showed my 50 year old spare and the bias ply tire just fell apart when I put it on.. haha _________________
consvws  Samba Member
Joined: April 07, 2009 Posts: 1015 Location: Roseburg, OR
Posted: Fri Dec 11, 2015 3:51 pm Post subject: Re: How to remove a stuck stud how to change your tire on a |
| borninabus wrote: |
| they should be removed from thesamba as they are detrimental to the community as a whole. |
or at very least put them all in one hackfest thread instead of posting new threads for every video |
jtauxe  Samba Member
Posted: Fri Dec 11, 2015 3:56 pm Post subject: Re: How to remove a stuck stud how to change your tire on a |
| vwuguy wrote: |
if you want to help edit the videos than heh that's cool help me out. |
I'm sorry. People (including me) are being pretty hard on you. I know your heart's in the right place, and I commend the effort it takes to get stuff up there.
Don't let us get to you. Keep on bussin'! _________________ John
http://vw.tauxe.net
Posted: Fri Dec 11, 2015 7:17 pm Post subject: Re: How to remove a stuck stud how to change your tire on a |
I think you are going to be embarrassed when in five years you look at these videos you are making. Lots of bad technique and a whole lot of filler that should have been edit out before you ever posted them even on a draft basis.
I have owned a cheapy 3/4" drve socket set for close to thirty five years at this point which works great for braking loose stubborn wheel lugs. This set has saved me a countless amount of effort, cursing, and bloody knuckles over the years. It and a three to three and a half foot long piece of 1" Sch-40 steel pipe will get most any part of one of these rigs loose with minimal chance that anyone if going to get hurt.
Check out this video, Ben is removing a head for a WBXer engine, something that sometimes takes people hours to do. The video shows the whole process from beginning to end and is only 2 minutes and 44 seconds long.
I can't say anything wrong about anything he shows in the video at all, what it shows is that he is a pro that has figured out how to make hard jobs easy. He is not using special tools, taking risks, or destroying expensive parts and pretty much anyone who watches is going to learn something of value. |
