Missing O-Ring on Idle Adjustment Screw Fuel Injection
johnsilverlakes
johnsilverlakes is offline
PostPosted: Sat Dec 12, 2015 4:58 pm    Post subject: Missing O-Ring on Idle Adjustment Screw Fuel Injection Reply with quote
Anyone know the size/dimensions of the o-ring for the idle adjustment used on fuel injected 76 Bus? Mine is missing completely. I've got an assortment, but not sure how it was intended to seal. Looks like the throttle body is completely threaded. So, I was thinking that if it was supposed to fit inside the threaded area it would be smooth near the top...I'm trying to get the idle to lower. I checked for air leakage elsewhere and this seems to be the logical place to fix...
Thanks!
John
1976 Westfalia
Manual Transmission
Federal Emissions
SlowLane
SlowLane is offline
PostPosted: Sat Dec 12, 2015 6:48 pm    Post subject: Re: Missing O-Ring on Idle Adjustment Screw Fuel Injection Reply with quote
Just measured one: 15 mm OD, 10.5 mm ID, 2.25 mm thickness.
Present:
'81 Westfalia: 2L, manual. Originally Canadian, now Californiated
Back in the day:
'72 Super Beetle
'69 Camper Van - Corvair powered
'71 Window Van - Transferred Corvair from '69
"With sufficient thrust, pigs fly just fine." - Internet RFC 1925
"They say a little knowledge is a dangerous thing, but it is not one half so bad as a lot of ignorance." - Sir Terry Pratchett
johnsilverlakes
PostPosted: Sat Dec 12, 2015 7:43 pm    Post subject: Re: Missing O-Ring on Idle Adjustment Screw Fuel Injection Reply with quote
Thanks for the info. SlowLane! That helps determine how it should fit...
1976 Westfalia
Manual Transmission
Federal Emissions
