How do I make the rear side marker lights blink?
tjet
tjet is offline
PostPosted: Sat Dec 26, 2015 9:25 am    Post subject: How do I make the rear side marker lights blink? Reply with quote
I want to modify the wiring to the rear side marker lights so they blink when the turn signal is on. They also need to illuminate normally as a side marker when the lights are on.
Is there a way to do this?
Cheers
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sat Dec 26, 2015 9:28 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
It is simple enough to make them do that but not both things at the same time.
Mark
Zeitgeist 13
Zeitgeist 13 is offline
PostPosted: Sat Dec 26, 2015 9:31 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
I believe you need to use LED bulbs in the side markers, and then attach the negative lead to the positive post on the rear turn signal. From memory, that's how I wired it on my van.
I got the idea from Dan.
Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE.
T3 Pilot
T3 Pilot is offline
PostPosted: Sat Dec 26, 2015 9:33 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
LMGTFY
http://www.thesamba.com/vw/forum/viewtopic.php?t=444581&view=previous
1988 Vanagon
The most important part in every vehicle is the nut behind the wheel......
Terry Kay
Banned
Terry Kay is offline
PostPosted: Sat Dec 26, 2015 9:36 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
Ahh--I do believe your going to need a dual filament bulb in each side marker light to get this to work and then wired to the corresponding signal wire, without back feeding through the rest of the lighting system.
T.K.
Zeitgeist 13
PostPosted: Sat Dec 26, 2015 9:40 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
I guarantee it works as described on my van. Side marker lights function as normal, and then flash intermittently (opposite the rear lights) when that side's turn signal is engaged.
Casey--
'89 Bluestar ALH
NEAT, no ICE.
Ahwahnee
Ahwahnee is offline
PostPosted: Sat Dec 26, 2015 9:46 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
Terry Kay wrote:
... without back feeding through the rest of the lighting system.
Sounds like the one-way nature of the diode keeps that from happening - a pretty clever solution.
Zeitgeist 13
PostPosted: Sat Dec 26, 2015 9:51 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
Here's where I got the idea:
danfromsyr wrote:
...for extra effect I also hook the +12v to the proper tail/running light
but I hook the -Neg to the +Pos of the blinker (turn signal) circuit..
by doing this it'll illuminate normally as a side light
but when your turn signal is on it'll interupt the LEDs -neg path and then the side light will blink as well.
I find this makes the van much more visible.. just be sure to make good weatherproof electrical connections for longevity
Casey--
'89 Bluestar ALH
NEAT, no ICE.
eplater
eplater is offline
PostPosted: Sat Dec 26, 2015 9:54 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
x2 on the LED mod. Works perfectly as described. About a 30 minute job and simple. My next project will be to add amber LED blinkers/ markers to the lower end of my LT truck mirrors.
'90 Syncro Westy EJ22 w/ decoupler & rear locker
'12 Touareg TDI
'08 RS4 Cabriolet
insyncro
Banned
insyncro is offline
PostPosted: Sat Dec 26, 2015 10:06 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
Wire them through a powered brake controller.
syncrodoka
syncrodoka is offline
PostPosted: Sat Dec 26, 2015 10:15 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
syncrodoka wrote:
Cut the ground leg of the stock side marker assemblies and tie it to the flashing power leg of the rear turn signals
fxr
fxr is offline
The LED solution above is the easiest method by far. It's the same principle used on motorbikes for turn signal reminder bleepers, where the -ve of the bleeper is fed to the +ve side of the brake light bulb. Thus the bleeper goes silent when the brakes are on, so saving the rider's sanity at long stop lights.
Jim Crowther
Vespa GTS 300
tjet
tjet is offline
PostPosted: Sat Dec 26, 2015 10:29 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
I kinda get the idea.
Is it like this?
Wildthings
Wildthings is offline
PostPosted: Sat Dec 26, 2015 10:33 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
Just take the ground wire from the side marker light and connect it to the hot side of the turn signal light. The marker light will glow normally when the running lights are on, but will go off each time the turn signal flashes.
Zeitgeist 13
PostPosted: Sat Dec 26, 2015 10:36 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
Sorta, except you don't use the chassis ground on the side marker at all. Grounding for the LED comes solely from the positive side of the rear turn signal.
Casey--
'89 Bluestar ALH
NEAT, no ICE.
tjet
tjet is offline
PostPosted: Sat Dec 26, 2015 10:47 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
So this, right?
Zeitgeist 13
PostPosted: Sat Dec 26, 2015 10:49 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
Yes
Casey--
'89 Bluestar ALH
NEAT, no ICE.
danfromsyr
danfromsyr is offline
PostPosted: Sat Dec 26, 2015 10:55 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
love seeing more vans with this essential (IMNSHO) update.. I don't even consider it a mod.
and kinda cool to see me quoted above..
disconnect/don't use the oem side light -Neg wire it'll pop your turn fuse the way you have it drawn
danfromsyr wrote:
what I do on the stock units is replace the whole bulb& holder with a red 3/4in LED Jammie
they're pretty cheap on fleabay.
http://www.ebay.com/sch/i.html?_from=R40&_trks...p;_sacat=0
they stuff right into the housing using the supplied 3/4in grommet
they're 100% waterproof and will never fail again..
but I hook the LEDs -Neg to the +Pos of the blinker (turn signal) circuit..
Abscate wrote:
Zeitgeist 13
PostPosted: Sat Dec 26, 2015 11:11 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
I used that exact LED assembly (without the rubber seal), but drilled an aftermarket reflector and then glued to light to the assembly. This makes the dome stick out so you can see the light fore/aft and from the side. Highly visible.
Casey--
'89 Bluestar ALH
NEAT, no ICE.
syncrodoka
PostPosted: Sat Dec 26, 2015 11:21 am    Post subject: Re: How do I make the rear side marker lights blink? Reply with quote
I used the stock hardware, just a wiring mod.
I do have a red LED bulb in the side marker assembly but that just happened to be installed prior.
