Windshield Washer '79 Super Beetle
Page: Previous  1, 2, 3
chefpeon
chefpeon is offline
PostPosted: Tue Jan 05, 2016 4:43 pm    Post subject: Re: Windshield Washer '79 Super Beetle Reply with quote
Thank you very much Tim Donahoe! Would you possibly be able to post a link to the part, or tell me what it's called so I can do a search? My plan B was an electric pump, but that's only if I can't make this original system work. Thanks again!
Tim Donahoe
Tim Donahoe is offline
PostPosted: Tue Jan 05, 2016 6:24 pm    Post subject: Re: Windshield Washer '79 Super Beetle Reply with quote
Annie, Wolfsburg West part number:
111953519G
Go to their site and punch in the above in the Search function.
Tim
Let's do the Time Warp again!
Richard O'Brien
Tim Donahoe
PostPosted: Tue Jan 05, 2016 8:03 pm    Post subject: Re: Windshield Washer '79 Super Beetle Reply with quote
Oops! There is a problem with Wolfsburg West's description on the switch. An older catalog I have says one thing, their web site says something else.
Their tel # 1-888-965-3937
Tim
Richard O'Brien
chefpeon
chefpeon is offline
PostPosted: Tue Jan 05, 2016 8:04 pm    Post subject: Re: Windshield Washer '79 Super Beetle Reply with quote
Ah! OK, I see....I need to replace the entire wiper switch, is that right? Your link was to a wiper switch on a different year Beetle, so I found this, for my 72 Super: http://www.jbugs.com/product/111953519H&Store_Code=JBUGS.html
This is the thing I need, correct?
Thanks again again!
Annie
Tim Donahoe
PostPosted: Wed Jan 06, 2016 10:25 am    Post subject: Re: Windshield Washer '79 Super Beetle Reply with quote
Yep.
Tim
Richard O'Brien
quantumchaos
quantumchaos is offline
PostPosted: Tue Apr 06, 2021 10:12 am    Post subject: Re: Windshield Washer '79 Super Beetle Reply with quote
bikelash wrote:
I will try to find some pics but Joel did a write up on it. When you pull the washer stalk out some have a black wire that is attached to nothing.
If there is no black wire just look for the connection point at the same place as in the pic. It is simpler than it appears. When you pull the lever back it will energize that wire. Then use that to energize your pump. Been using a new for a couple of years now and it works great
BTW this pic is from Joel's write up.
Which wire would be the equivalent on the new stalk??
Gerrelt
Gerrelt is offline
PostPosted: Sun May 09, 2021 3:19 am    Post subject: Re: Windshield Washer '79 Super Beetle Reply with quote
Beetlebaum asked a question about a super beetle window washer pump in the Mexican/Brazillian beetles thread.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9633402&highlight=#9633402
I though it would answer it here, as it is more appropiate.
Beetlebaum wrote:
How does that pump work? Maybe I should get one for my (US-spec) '73 Super Beetle, which has never had a working windshield washer system.
I think you would be better off with a kit like this:
https://www.paruzzi.com/nl/volkswagen/elektriciteit/ruitenwisser-ruitensproeier/2448/
You can place this pump inline the current tube, and then you can retain your standard washer fluid reservoir. The pictured mexi reservoir does not really fit in the front of a super beetle (as Paul already pointed out).
If you're handy, you can also only buy the pump, which is a lot cheaper.
Search for part number 431955651, you will find a lot of offerings.
But you will need a switch, cables etc. .
BTW, the little pipe on the side is the exit, the one on the top is the inlet.
I use this pump too in my super beetle:
I've modified the cap of the reservoir so it has a little hole for air to get in:
And I've modified my steering column stalk to accept a micro switch:
http://www.gerrelt.nl/section-modifications/window-washer-switch
homepage
Page 3 of 3
