boomtown Samba Member
Joined: July 05, 2008 Posts: 68 Location: Daytona Beach
Posted: Fri Feb 05, 2016 10:26 am Post subject: Generator Testing |
I'm trying to test the no load voltage on the generator on my 65 bug. this is the first step in trouble shooting the generator according to the Bentley manual. Located on page 16 of the electrical section of the manual has me disconnecting the wire on the B+ terminal on the regulator and attaching the VOM meter according to the illustration Fig. 6-1. Problem, the engine stops when either of the two wires attached to the B+ terminal are removed. The wiring diagram for a 65 bug has two wires connected to terminal B+ , one goes to the starter and the other runs through the light switch and on to the fuse box.
My question, what am I doing wrong or what is hooked up incorrect?
David _________________ When the children get older and want to know where the money went, show them your vacation videos. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36271 Location: Conejo Valley, CA
Posted: Fri Feb 05, 2016 10:30 am Post subject: Re: Generator Testing |
I believe you remove the two wires from the B+ terminal but then connect them together for the test. Don't the instructions say that?
Posted: Fri Feb 05, 2016 11:12 am Post subject: Re: Generator Testing |
The Bentley manual does not say that, it just says disconnect the wire from the B+ terminal and be careful not to ground it. When it said the wire I found it confusing because there are two wires. I tried one wire at a time but each single disconnect stop the engine.
So I understand this correctly you think I need to disconnect both wires and jumper then together? then run the test?
KTPhil  Samba Member
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 6041 Location: Brooklyn
Posted: Fri Feb 05, 2016 12:41 pm Post subject: Re: Generator Testing |
I have done this test successfully. Yes even though the Bentley does not explicitly say it, you need to disconnect the red wires from B+ and then connect them together (you can use an alligator clip or something, just make sure they cannot ground on anything).
The reason this is necessary becomes obvious if you understand the current flow from the battery. To do the no-load test, you must take the battery out of the circuit which is what happens when you remove the wires from B+. Of course when you do this, you are cutting power from the battery to the fuse box. No power to fuse box = no power to coil = ignition system no worky = engine stops.
So. Turn off engine. Pull wires from B+ and connect them together. Start engine and perform no-load test. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Sat Feb 06, 2016 7:29 pm Post subject: Re: Generator Testing |
Thanks sjbartnik for your input. Since starting this thread I have taken the bug to a local man to have the generator checked. It is bad and my next step is to remove the generator and replace it with a new or rebuilt one. thanks for the excellent help and the quick response . as I have found here on the Samba and at local Volkswagen shows and meets, the VW community is most friendly and helpful groups in the automotive hobby.
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2983 Location: Thornton, CO
Posted: Mon Jul 30, 2018 2:32 pm Post subject: Re: Generator Testing |
Could a faulty generator be the cause of no spark from the coil? I'm running out of ideas as to why I'm not getting spark. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
– D. Tartt, 'The Goldfinch' |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33403 Location: Hot Arizona
Posted: Mon Jul 30, 2018 3:25 pm Post subject: Re: Generator Testing |
| scottyrocks wrote: |
| Could a faulty generator be the cause of no spark from the coil? I'm running out of ideas as to why I'm not getting spark. |
Not likely.
If your engine spins at normal speed when you try to start, then you need to first determine whether the issue is fuel-related or spark-related. That's always the first step, use aerosol starting fluid, spray into carb, floor pedal, try to start (do this all several times). If it runs for a few seconds, then likely fuel related; if not, likely spark related.
Or bring VW to Arizona once it gets below 110F here, I'll fix or determine exactly what's the cause in under 15 minutes. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Jul 30, 2018 6:31 pm Post subject: Re: Generator Testing |
| Cusser wrote: |
Not likely.
Or bring VW to Arizona once it gets below 110F here, I'll fix or determine exactly what's the cause in under 15 minutes. |
Well, I'm not getting to Arizona anytime soon, so I'll have to rely on guidance here and/or from local sources.
I'm almost positive I'm not getting spark from the coil, not with 2 separate coils, and two different wires, and a new spark plug.
I traced all the wires attached to the coil and can't find any issues. Everything is attached to where it was when the car ran. I even swapped out the proper fuse (#1) under the dash.
I'll try the spray test. _________________ “If you care for a thing long enough, it takes on a life of its own, doesn't it? Mending old things, preserving them, looking after them – on some level there's no rational grounds for it.”
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Mon Jul 30, 2018 6:53 pm Post subject: Re: Generator Testing |
| boomtown wrote: |
David |
Just to let you know, there is a company in Orlando(Pine Hills) called TRS. They recently rebuilt my 12v generator. Quick and have a good rep. May be worth a call. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Posted: Tue Jul 31, 2018 7:52 am Post subject: Re: Generator Testing |
I'll try the spray test. |
Just so you know, the coil is not fused. It will work whether or not the fuse is in place - assuming your car is wired correctly as VW wired it from the factory.
Not sure how you can be almost positive you don't have spark? You either have spark or you don't. Pull one of the plug wires off and hold it near the case and crank the engine by hand or have someone crank it over using the starter. Look for the spark.
If you're not getting spark and you've tried 2 different coils, my first thing would be to get my VOM out and make sure the coil is getting 12v on terminal 15 and then my second thing would be to check out the points. _________________ 1965 Volkswagen 1500 Variant S
Cusser Samba Member
