boinzy Samba Member
Joined: October 04, 2013 Posts: 59 Location: Boulder, CO
Posted: Wed Jan 27, 2016 3:56 pm Post subject: Steering Position Sensor & now Yaw Rate Sensor |
2002 EuroVan MV Weekender.
My ABS and triangle dash warning lights came on some months ago and had a shop diagnose it as a failed steering position sensor.
Just turned over 120,000 miles and was getting the 120k service done at a new shop and they confirmed the previous diagnosis, so I had them replace it.
Now that they have it in, those same dash warning lights came back on, they took a look and they're saying the yaw rate sensor is reporting as bad.
"Which seems really weird to have TWO rarely failed items fail together!" as Cole says.
Anyone with experience with this? Any guidance?
I have half a mind to just live without it and ABS due to the expense.
Thanks all. |
jakehenes Samba Member
Joined: March 18, 2007 Posts: 96 Location: milwaukee wisconsin
Posted: Wed Jan 27, 2016 7:23 pm Post subject: Re: Clock Spring/Steering Position Sensor and now Yaw Rate S |
try to clear the code with vag com. if the sensor is actually good in needs calibration which is also something you do with software. check out ross tech website there are directions there. _________________ Owner and mechanic - riverwest auto. |
Posted: Wed Jan 27, 2016 7:25 pm Post subject: Re: Clock Spring/Steering Position Sensor and now Yaw Rate S |
there is a guy in silverthorne who helped me out while i was on vacation with my eurovan a few years back.. chiefs autohaus his name is jason. _________________ Owner and mechanic - riverwest auto. |
boinzy Samba Member
Posted: Thu Jan 28, 2016 8:24 am Post subject: Re: Clock Spring/Steering Position Sensor and now Yaw Rate S |
Thank you for this, I'll look into this further, much appreciated.
| jakehenes wrote: |
| try to clear the code with vag com. if the sensor is actually good in needs calibration which is also something you do with software. check out ross tech website there are directions there. |
boinzy Samba Member
Posted: Thu Jan 28, 2016 8:25 am Post subject: Re: Clock Spring/Steering Position Sensor and now Yaw Rate S |
I'm too far away to visit, do you think he'd chat with me over the phone? I don't want to bother a guy who's busy with paying customers.
| jakehenes wrote: |
| there is a guy in silverthorne who helped me out while i was on vacation with my eurovan a few years back.. chiefs autohaus his name is jason. |
boinzy Samba Member
Posted: Thu Jan 28, 2016 8:27 am Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
After sleeping on it, I have some specific questions around all of this.
Why would the steering position sensor affect the ABS?
Would a bad ABS module throw a code for the steering position sensor?
If the ABS module went bad, would that also result in the steering position sensor not outputting any data on position when hooked up to a computer, even if the sensor was actullay working fine? (note: after replacement, it's now outputting data as expected.)
Is it true that the yaw position sensor wouldn't throw a code until the steering position sensor was fixed?
Thanks all. |
Posted: Wed Feb 03, 2016 7:55 pm Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
do you have access to vag-com? if so go into abs module for codes, there is an adaption because abs uses the steering angle sensor to make driving compensations. _________________ Owner and mechanic - riverwest auto. |
Xtremjeepn Samba Member
Joined: October 21, 2012 Posts: 1543 Location: Colorado
Posted: Thu Feb 04, 2016 7:59 am Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
You are welcome to use my VAG-COM. _________________ http://www.cavevan.com |
boinzy Samba Member
Posted: Fri Feb 05, 2016 12:24 pm Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
I'll definitely take you up on that if I find myself down in your neck of the woods! Thank you!
| Xtremjeepn wrote: |
| You are welcome to use my VAG-COM. |
Jonwid Samba Member
Joined: August 18, 2013 Posts: 163 Location: Long Beach
Posted: Fri Feb 05, 2016 1:33 pm Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
Boinzy,
Wondering how much your clock spring with steering angle sensor cost you? |
boinzy Samba Member
Posted: Tue Feb 09, 2016 8:26 am Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
Hey Jonwid,
The part itself was just under $600 + about an hour of labor to put in. There is a place you can buy online for $590 if you're DIY.
| Jonwid wrote: |
Boinzy,
Itsamoto Samba Member
Posted: Tue Feb 09, 2016 8:54 am Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
That is steep!
Any thoughts on whether this part can be poached off another VW in scrapyard? |
d-9 Samba Member
Posted: Tue Feb 09, 2016 9:53 am Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
Not according to vagcat, T4 only
If anyone has a slipring with a broken steering angle sensor they want to sell, please drop me a PM, I have no need for the ESP functionality but am desperately after the ring! |
Jonwid Samba Member
Posted: Tue Feb 09, 2016 10:41 am Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
| Itsamoto wrote: |
That is steep!
That's my next plan to look in the salvage yard. Now that I know how to treat these gadgets, I'm willing to give it a try, before I fork over the $580 my local dealer wants. Costliest goof I've ever made on a DIY project.  |
Posted: Mon Aug 15, 2016 11:04 am Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
Steering wheel sensor just died over the weekend on my 2002 GLS. Dashboard lit up like a christmas tree. Van seems drive-able despite the failure -- its just that the traction control isn't working. Perhaps some ABS effectiveness is reduced (I'm not sure).
The item's housing seems unique to the Eurovan - it nestles into the back of the van's steering wheel. Other similar vintage VW's that I looked at the sensor is covered by the steering column covers. If I had more time I would explore that type of swap -- as I have MK4 leather steering wheel (flat on the back) that I want to employ.
I used VAG-COM to check the codes from the ABS brake module:
P1628 - 35-00 - Missing Message from Steering Angle Sensor
Measuring blocks showed no angle data being transmitted.
Luckily I have second van on hand (Lucille's not going anywhere this month) - so I was able to swap in a known good clockspring/wheel-angle-sensor to verify the part was problematic and get everything back up.
Part (7D0959654) is expensive, although I did find it quickly at ECS tunning for $427.
https://www.ecstuning.com/b-genuine-volkswagen-audi-parts/clockspring/7d0959654/
I would like to repair first before replacing. I took the suspect unit apart -- ribbon cable intact and continuity (this is the clockspring portion) -- but the wheel angle sensor looks to have board level damage. I will try and get a picture and upload it to update the post. |
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1468 Location: Bethlehem, PA
Posted: Mon Aug 15, 2016 1:34 pm Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
| With a steering angle sensor, the stability, traction and diff lock will not work. As for the ABS, it works just fine. In racing the common thing we do is unhook the steering angle sensor to keep those systems off all of the time. ABS still works like a champ. You can accomplish the same with unhooking the yaw sensor. |
Posted: Fri Aug 19, 2016 9:34 am Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
| jjvincent wrote: |
Good to know -- I can frame the repair as an optional upgrade.
I hit a patch of heavy rain while travelling an uphill section of highway (doing about 100-120km/hr) - and I could immediately feel the absence of the traction control. I guess I've come to expect this being present in the van - it works very very well for those exact situations. |
Posted: Fri Aug 19, 2016 11:39 am Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
Some details of the failed steering wheel sensor:
Here is the failed unit -- I have separated the clock spring (left) from the wheel sensor components (right) - -there is little spring washer ring that rides in between.
The steering angle sensor reads the posting of the steering wheel based on the coding of this brass disc/ring. You can see where the ring passes through the photoelectric reader. Very cool!
What's not cool - is that somehow the sensor disc/ring has been rubbing on the board beneath -- removing traces. No smoking gun of something loose in there - just plastic dust from the components wearing down on their own friction.
I don't know if this failure is all that common - but I do know that on this van the previous owner had replaced the ignition switch and perhaps the re-assembly put more pressure on the clock spring and wheel sensor -- thus causing failure. Anyhow - something to watch for. |
Posted: Sat Aug 20, 2016 1:18 pm Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
| That's a common unit. They wear out quite often on older vehicles today. |
Posted: Mon Aug 22, 2016 11:23 pm Post subject: Re: Steering Position Sensor & now Yaw Rate Sensor |
| @JJV Do you think the board is common then among other VWs? I see the form factor on other VW's of this generation is larger and more square - makes me think the components are spread out a bit more - perhaps saving itself from this wear-down. |
