Unknown Switch on Engine Case
JCockrill
JCockrill is offline
PostPosted: Mon Mar 07, 2016 10:43 am    Post subject: Unknown Switch on Engine Case Reply with quote
I could not find this in the Bentley or the Wilson book. I tried search Samba but didn't have any lucky probably because I don't know what it is so it makes keyword search very difficult.
Can anyone tell me what this switch/sensor/or other electrical device this is on the right side of the engine case facing the flywheel for a 1974 VW Type 1 stock sedan standard? (alternator version, fuel pump) Any help would be greatly appreciated.
Thank you!
Wide View
Close Up
View from flywheel side
[/img]
'15 Manxter on a '72 pan with '74 engine/trans/and axles. Just trying to work out the gremlins in the build
busdaddy
busdaddy is offline
PostPosted: Mon Mar 07, 2016 10:52 am    Post subject: Re: Unknown Switch on Engine Case Reply with quote
TDC sensor for VW diagnostic system used at the dealers.
I sure hope that's a before pic, all that RTV looks scary Shocked
Слава Україні!
JCockrill
PostPosted: Mon Mar 07, 2016 11:05 am    Post subject: Re: Unknown Switch on Engine Case Reply with quote
Thank you! No one could figure it out.
The engine is still in pieces so haven't cleaned up the RTV. Still have to trim and clean it up. Is it detrimental to the build?
olspeed
Location: In the shadow of Denali, I still don't give a damn how they do it outside
olspeed is offline
PostPosted: Mon Mar 07, 2016 11:08 am    Post subject: Re: Unknown Switch on Engine Case Reply with quote
If it looks like that on the outside just think what the inside looks like... oil pumps and passages don't like RTV sealant
66- Ghia
76-Beetle
JCockrill
PostPosted: Mon Mar 07, 2016 11:10 am    Post subject: Re: Unknown Switch on Engine Case Reply with quote
The RTV was placed on the middle to outside edge of the case halves before putting it together. There are no cylinders or anything else attached so will take a light and look in to see how the interior is faring. Any RTV and I will pull it apart to reseal.
Randy in Maine
Randy in Maine is offline
PostPosted: Mon Mar 07, 2016 12:01 pm    Post subject: Re: Unknown Switch on Engine Case Reply with quote
After you tear it all apart to get rid of all of that RTV use ths stuff to seal the case halves....
http://vwparts.aircooled.net/Curil-T-Engine-Sealant-75ml-Tube-p/curil-t.htm
JCockrill
PostPosted: Mon Mar 07, 2016 12:15 pm    Post subject: Re: Unknown Switch on Engine Case Reply with quote
Just ordered some. Will be here end of the week.
mark tucker
mark tucker is offline
PostPosted: Mon Mar 07, 2016 1:43 pm    Post subject: Re: Unknown Switch on Engine Case Reply with quote
I love that color of rtv.
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Mon Mar 07, 2016 4:23 pm    Post subject: Re: Unknown Switch on Engine Case Reply with quote
Rtv room temperature vulcanizing. Looks like shit I'd use aviation permatex or pretty girl AKA gasgacinch. The hardcore here like curil or even hylamar or yamabond anything but rtv . Rtv doesn't completely squeeze out and it's been known to get into the oil supply and foul things up.
ldj1002
ldj1002 is offline
PostPosted: Mon Mar 07, 2016 5:23 pm    Post subject: Re: Unknown Switch on Engine Case Reply with quote
I think you are lucky you didn't know what that switch was and showed a photo of it. Otherwise you would have put that in service with all that RTV. Evil or Very Mad
PostPosted: Mon Mar 07, 2016 5:40 pm    Post subject: Re: Unknown Switch on Engine Case Reply with quote
I'd run it as is what's the worst that could happen ?
Bashr52
Bashr52 is offline
PostPosted: Tue Mar 08, 2016 5:22 am    Post subject: Re: Unknown Switch on Engine Case Reply with quote
I'm sure it would be fine, like just pounding a bad rod bearing back into place and putting the engine back together.
PostPosted: Tue Mar 08, 2016 7:41 am    Post subject: Re: Unknown Switch on Engine Case Reply with quote
I can see humor is wasted on you, chill out please.
