tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Thu Mar 31, 2016 7:54 pm Post subject: Turbo 70 single cab project |
I've been driving bay window buses for as long as I've been driving. My dream vehicle has always been a VW pickup. Well I got the opportunity to snatch one up and took it. I've been collecting parts for about a year now and am ready to begin.
The vehicle in question:
The engine thus far:
2161cc
It's an aluminum super case. Some machining was necessary to get it ready. The decks were not square so I had it decked. The case is not machined properly for the distributor drive so I had to take some material out there. Also a tiny bit had to be taken off one of the cam bearing saddles for clearance.
It contains a DPR 84mm crank with chevy rod journals, balanced along with the flywheel, which is wedgemated. It has 5.5 Scat H-beam rods. The cam and lifters are from Jason at Paradise Motorsports. The cam is not too wild, just a little bit bigger than a 110. I'm using AA 40mm intake 35.5mm exhaust heads that I ported myself. I also had a friend unshroud the valves. I'm using EMPI 1.25 ratio rockers.
The pistons and cylinders are cima, forged 90.5 'b' pistons. I'm using Grant chrome top rings and totalseal seconds.
Sequential fuel/air and spark will be via megasquirt and a turbo.
Throttle body is a 2 incher from a saturn found in a junkyard. It has the tps and iacv on it and they are GM which is good.
Intake manifold is an old holly bug spray that I will have to modify a little. It's really close though.
It's gonna have coil on plugs from a 1.8t vw engine.
Map sensor is also from a 1.8t and I got a weld-on bung that I'll weld to the charge pipe.
Cam sync from CB:
Injectors are 30lb bosch red tops originally fitted to the ford thunderbird and GMC typhoon. They are saturated injectors which means megasquirt can drive them directly from the computer.
_________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's)
Last edited by tootype2crazy on Sat Apr 16, 2016 11:29 am; edited 2 times in total |
Posted: Thu Mar 31, 2016 8:00 pm Post subject: Re: Turbo single cab project |
I'm building the exhaust myself. It's gonna be 100% stainless steel. I'm going to take it forward and have it exit in front of the passenger rear tire. I want this engine quiet hence the length. Here are some of the bits:
The VW flanges are SS from aerovee. The vbands are vibrant performance. The little ones will be where the j pipes meet the collector. The t3/t4 flanges I got on amazon. The merge kit is from cone engineering. I have pipes and a magnaflow muffler and a vibrant super quiet resonator too.
I'm modifying stock VW end castings to accept the injectors and building my own fuel rail.
I have a MST pulley and I got a trigger wheel setup from Mario at the dubshop.
I haven't bought the turbo yet but I got a TiAL 38mm air cooled wastegate and a TiAL recirculating blow-off valve. I'm planning on letting megasquirt control boost, but don't want anything above 12psi as I'm planning on making this a daily driver.
I also am converting it to a late bay beam and vanagon self-adjusting backing plates in the rear. That will get the bolt pattern to 5x112, giving more choices for wheels.
I'm gonna put a 6 rib in it which I'm having rebuilt with taller 3rd and 4th gears.
Cc'd the heads, worked out to 58cc
Had to have the pistons dish cut by my machinist extraordinaire friend. This will add 12 cc to the chamber volume
My deck height is -.160. Ouch. With .180 cylinder spacers bringing deck height to .020" and .060" copper head gaskets and 70cc chamber volume I'll have a compression ratio of 7.3:1. Perfect with 10lbs of boost for some decent horsepower with minimal heat. _________________ air-cooled or nothing for me
2001 GTI VR6 (wife's) |
Joined: January 01, 2007 Posts: 17984 Location: sticksville, ct.
Posted: Thu Mar 31, 2016 8:56 pm Post subject: Re: Turbo single cab project |
nice!!
how much boooossstttt you *really* going to stuff down it's throat? _________________
| gprudenciop wrote: |
| Jake Raby wrote: |
| Thanks for the correction. I used to be a nice guy, then I ruined it by exposing myself to the public. |
| Brian wrote: |
| Also the fact that people are agreeing with Skills, it's a turn of events for samba history |
levi20AE Samba Member
Joined: June 24, 2005 Posts: 485 Location: Las Vegas, NV
Posted: Thu Mar 31, 2016 8:58 pm Post subject: Re: Turbo single cab project |
Fun project! V-bands are the way to go. I have found that the coil packs from the 2.0T FSI motors spark hotter and don't die as fast. They have the same harness connectors as the 1.8T ones. _________________ 1973 Campmobile http://www.thesamba.com/vw/forum/viewtopic.php?t=524511&postdays=0&postorder=asc&start=0
20th AE VW GTI - 369hp 340tq @ 26 PSI
1982 Rabbit Pickup - German AAZ 1.9TD - daily with lots of MPGs |
Posted: Thu Mar 31, 2016 9:12 pm Post subject: Re: Turbo single cab project |
| skills@eurocarsplus wrote: |
nice!!
how much boooossstttt you *really* going to stuff down it's throat? |
I'm thinking max 12 psi. This is gonna be a daily and I don't really want to tear down the engine every month so I'm trying to be conservative. Buses need a lot more mods to go crazy fast anyway. Although Wagenswest's airbag beam and rear airbag kit are on my wishlist.
Megasquirt does allow multiple fuel/air and spark table maps, and with an electronic boost controller I could switch between "eco" and "sport" mode if I really wanted. I don't plan on racing it but, you know, things change. _________________ air-cooled or nothing for me
Busstom Samba Member
Joined: November 23, 2014 Posts: 4591 Location: San Jose, CA
Posted: Thu Mar 31, 2016 9:35 pm Post subject: Re: Turbo single cab project |
Nice! Looking forward to seeing this come together. That bottom end is similar to an engine I'm building for my '64 Bus (I'm using a CB case and CB H-beams with 90.5 B's).
Have you been scheming this build for a year and keeping it secret from the forum?? That takes patience! |
Posted: Thu Mar 31, 2016 10:09 pm Post subject: Re: Turbo single cab project |
| tootype2crazy wrote: |
| I'm thinking max 12 psi.. |
well, I saw that if 12 is fun, how much more fun would 14 be?  _________________
| Jake Raby wrote: |
| Brian wrote: |
Posted: Fri Apr 01, 2016 6:12 am Post subject: Re: Turbo single cab project |
well, I saw that if 12 is fun, how much more fun would 14 be?  |
It's gonna be like meth. You keep craving more until you destroy yourself.
You guys have to keep me in check, I'm counting on you. _________________ air-cooled or nothing for me
Posted: Fri Apr 01, 2016 7:22 am Post subject: Re: Turbo single cab project |
can I ask why MS? I know it's possibilities are endless. I have played with one some years ago, and it was fun...very time consuming, but good learning experience.
I liked SDS...pretty much ran right out of the box and "self adjusted" with the use of a wideband o2. more money up front, but it did save a bunch of time on the back side. it was easily programmable too. _________________
| Jake Raby wrote: |
| Brian wrote: |
Posted: Fri Apr 01, 2016 7:32 am Post subject: Re: Turbo single cab project |
I'm a diehard do-it-yourselfer. Megasquirt appeals to me because of this. I've long thought about how I would set it up, what parts I wanted to use, so on, so forth. Also, MS has a huge and vocal online user base with plenty of them willing to help and share. It's the people's FI. It fits for the people's car. _________________ air-cooled or nothing for me
Posted: Fri Apr 01, 2016 11:26 am Post subject: Re: Turbo single cab project |
Tapped a hole in the top of the case to install a breather filter. I'm using a fuel injected bug filler neck with the big hose. I will run a line off of it up to a catch can then down to the air filter side of the of the turbo. This hole I tapped will have a breather filter on it. It will serve as an intake for the case while the oil filler breather will have a slight vacuum on it from the intake. This is necessary with a turbo or else the case can get mighty pressurized and start spewing oil out of the seals. I'm not a fan of tapping the valve covers as half the time oil has the pushrod tubes blocked.
And yes I got all the chips out.  _________________ air-cooled or nothing for me
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3388 Location: Memphis
Posted: Fri Apr 01, 2016 11:45 am Post subject: Re: Turbo single cab project |
| scrivyscriv wrote: |
| But... But... But... It's not... STOCK!!! |
LOL. I knew I'd hear it at some point. I have this thread going on ultimateaircooled.com too just in case it gets too rowdy here. You guys are cool though, all in good fun. That's what this project is supposed to be, after all.
Also, at least it's not a subaru.  _________________ air-cooled or nothing for me
Brian Samba Moderator
Posted: Fri Apr 01, 2016 11:53 am Post subject: Re: Turbo single cab project |
Also, at least it's not a subaru.  |
Ayeeee. Can't wait to see how this turns out _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Also, at least it's not a subaru. yet.  |
^^^^ much better now  _________________
| Jake Raby wrote: |
| Brian wrote: |
Posted: Fri Apr 01, 2016 11:55 am Post subject: Re: Turbo single cab project |
All kidding aside, what's up with your gallery plugs? Looks like you have already finished the bottom end, but the gallery plugs haven't been pulled? _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Fri Apr 01, 2016 12:03 pm Post subject: Re: Turbo single cab project |
| All kidding aside, what's up with your gallery plugs? Looks like you have already finished the bottom end, but the gallery plugs haven't been pulled? |
The threaded ones have been out while I was cleaning the case. I put the case in a parts washer in my friend's shop and let the cleaner go through the oil cooler output for about a day. We did that at the shop I used to work at and never had a problem. I have yet to seal the back threaded plug and the front one is for the full flow.
If you mean pulling all of them to tap them, I don't find it necessary. My friend has a 2332 that's turbo'd with about 500hp with the same case and it's held up up for years. _________________ air-cooled or nothing for me
Posted: Fri Apr 01, 2016 12:06 pm Post subject: Re: Turbo single cab project |
Just figured for having a brand new case with the money involved you'd want to pull all the gallery plugs for a scrub. Always heard that preached as shop etiquette when building an engine... _________________ Robert in Memphis
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2270 Location: Detroit, Michigan
Posted: Fri Apr 01, 2016 12:19 pm Post subject: Re: Turbo single cab project |
Nice! Please tell me you're gonna keep the body the way it is? _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
