Restoration of our 66 Bug in Arizona
Page: Previous  1, 2, 3, 4, 5, 6
Stock66
Stock66 is offline
PostPosted: Tue Feb 10, 2015 12:02 am    Post subject: Reply with quote
Looks great!
Where did you guys go for the wheel alignment?
I'm having a hard time finding a place that will do ours in the Gilbert / Chandler area..
1966 Beetle - Our Build thread http://www.thesamba.com/vw/forum/viewtopic.php?t=611939
AZ66Bug
AZ66Bug is offline
PostPosted: Tue Feb 10, 2015 6:35 am    Post subject: Reply with quote
We dialed in the camber with the index marks on the ball joints and then Dan over at Competition Engineering checked out that and everything else. Seems to run nice and straight. We had the tires mounted by Discount - one shop near us had the proper equipment for the 5-wides. But then we later discovered that they did not balance the tires because they don't have the equipment for that. We have had it on the freeway at 65+ and it is nice and smooth so I guess we don't need to worry too much about that. Thought about the beads but Dan at CE says he has the balance set up rig at his shop, one of the few around for the 5-wides.
66 Beetle Sedan, restored 2014
66 Mustang: Original Owner, restored 2008
66 Ford F250: 4th Owner, restored 2013
57BLITZ
57BLITZ is offline
PostPosted: Tue Feb 10, 2015 3:44 pm    Post subject: Reply with quote
grandpa pete wrote:
The before and after photo set is GREAT !!
I agree 100% . . . coolest thing I've seen today! Cool
Jesucristo es mi SeƱor y Salvador!
Buscowboy
Buscowboy is offline
PostPosted: Wed Feb 11, 2015 11:32 am    Post subject: Reply with quote
well done on a great save. Enjoy the fruits of your labour now.
1962 Gulf Blue Patina Deluxe Beetle
1963 SubHatch Westfalia MG/PW
1970 FI Auto Squareback
1990 Doka RHD
http://www.youtube.com/@BuscowboyClassics
https://www.instagram.com/buscowboy/
AZ66Bug
AZ66Bug is offline
PostPosted: Wed Feb 11, 2015 6:20 pm    Post subject: Reply with quote
Now that we have drive the car a bit we are noticing some little tics. One annoying one is front disc brake noise - a rattling sound that goes away as soon a you apply any pressure to the brake pedal. Almost certainly this is due to the lack of anti-rattle shims for our EMPI front brake set up. Apparently, EMPI does not provide or even have anti-rattle shims for their brakes. A local shop told us to use Disc brake quiet to essentially "glue" the disk pads to the calipers.
Does anyone know if there is an anti-rattle shim that would work on the EMPI set up or will the "brake quiet" do the job. Not worried about brake function - they work just fine, but the noise is very distracting.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Thu Feb 12, 2015 6:25 am    Post subject: Reply with quote
The disk brake quiet (glue) does hold the pads in place to dampen the noise from the pads sliding around in the calipers. The layer of glue between the two steel surfaces acts like a insulation.
The Samba member since 2004.
AZ66Bug
AZ66Bug is offline
PostPosted: Thu Feb 12, 2015 6:47 pm    Post subject: Reply with quote
Great to hear. Got a project for the weekend Very Happy
AZ66Bug
AZ66Bug is offline
PostPosted: Sun Feb 15, 2015 4:49 pm    Post subject: Reply with quote
Picked up some Disc brake quiet at NAPA and it did the job. Took the calipers off, painted on an even coat of the quiet material on the back side of the pads, let dry for 15 minutes, reinstalled and then stepped on the brakes. Can't believe EMPI does not provide some sort of anti-rattle shim.
AZ66Bug
AZ66Bug is offline
PostPosted: Sun May 10, 2015 8:41 pm    Post subject: Reply with quote
Been hitting a few car shows with the bug. Always gets a lot of looks. Of course it helps that we seem to go to shows with few bugs, so we stand out a bit!
Goodguys
Pavillions
Chandler Car Show
So-Cal Second Saturday
Yorvo
Yorvo is offline
PostPosted: Sun May 10, 2015 11:39 pm    Post subject: Reply with quote
Love your car! Do you go to Buses By The Bridge in Lake Havadu City? I'd love to see your car in person.
AZ66Bug
AZ66Bug is offline
PostPosted: Mon May 11, 2015 6:45 am    Post subject: Reply with quote
Didn't know about that one - its possible. What time of year is that?
Yorvo
Yorvo is offline
PostPosted: Mon May 11, 2015 1:26 pm    Post subject: Reply with quote
Usually Janurary. It's a bus event where many of them camp out for the weekend but some other VW's show up. It's less of a car show and more of an event.
http://www.busesbythebridge.com/Buses_By_The_Bridge/LONDON_BRIDGE_BULLIS.html
planenut
planenut is offline
PostPosted: Mon May 11, 2015 4:19 pm    Post subject: Reply with quote
What a great project and great, great results. I'd give anything if me and my son could do a project. But, he's in the Air Force several states away, and may never be close to home again. Cherish your time together. I envy you. Great job.
AZ66Bug
AZ66Bug is offline
PostPosted: Tue Apr 19, 2016 9:17 pm    Post subject: Re: Restoration of our 66 Bug in Arizona Reply with quote
Been a while since we checked in. The 66 is running great - if not leaving a little trail of oil wherever we park it Smile Seems like we miss every VW show in town for some reason or another, but we did pick up a top 10 award at a Toys for Tots show featuring mostly Mustangs and other Fords a few month ago.
Grizly1
Grizly1 is offline
PostPosted: Wed Apr 20, 2016 10:55 am    Post subject: Re: Restoration of our 66 Bug in Arizona Reply with quote
The car looks really good! You both did an awesome job. If you want, there is a BBQ/Picnic on April 30 in Phoenix.
Page 6 of 6
